Hugo is killed when building
When I build the project, it will be killed. the log is below:
Command was killed with SIGKILL (Forced termination): hugo --gc --minify
Is there some way to solve the problem? or what’s the reason? too many post files?
epic-wescoff-fe8106.netlify.app
Hi there, @wxtoutiao :wave:
Could you share your package.json and a screenshot of your build settings please? Additionally, we have a few other threads that discuss SIGKILL. Take a look and see if the suggestions / solutions are applicable:
Let us know!
thanks, I use Hugo, no package.json. Is netlify has files limited? I update almost 100k post files. I think the problem may be related with files amount. Is there a way for publish over 1000k post files with netlify?
Hi, @wxtoutiao. The issue appears to be that hugo is running out of memory and this is causing the OS to stop the running process.
There are several possible ways to resolve this:
Thanks a lot.
I would switch Hugo to other tool because Hugo has no incremental static generation.
Is there a way to incremental publish over 1000,000 posts with starter plan in netlify?
Incremental generation is a SSG-specific feature, not something that Netlify controls. Netlify will run the command you ask it to and deploy if the build succeeds.
With that being said, Hugo is one of the fastest builders out there. If it’s getting killed because of memory issues, chances are other builders might be killed due to build timeout limit as the number of posts is too high. I’d advise you to test before you make a switch.
Thanks for your reply.
How much the memory limited with starter plan?
Hi Luke,
Is manual deploy with ‘netlify deploy’ incremental?
It’s mentioned here: [Support Guide] Making sure your builds use appropriate resources for Netlify's build system.
About incremental builds, I repeat, it’s not a Netlify feature. In Manual Deploy, you build your website locally and only upload the publish files to Netlify. So, if your SSG supports it, you should be able to run an incremental deploy locally and publish it.
Thanks for your quickly reply.
My site could potentially have 200,000 files, but it would grow little by little. Rather than doing a manual deployment from my local machine with netlify deploy, what if I only pushed prebuilt HTML files to GitLab? I already have my own Python script for this. No SSGs in use.
I’m new to Netlify, and the netlify deploy command has me worried…cuz it wants my public directory name as input each time I invoke it, which would contain everything. Is there no way to tell this command exactly which file(s) to deploy?
Rather than doing a manual deployment from my local machine each time a new file is created, what if I only push fully-generated HTML files to GitLab? Would this completely alleviate the build phase and any bottlenecks associated with a gigantic site with ~200,000 files?
Or should I just throw in the Netlify towel and set up a Go+Fiber VPS and CloudFlare CDN?
Hi @mph,
Yeah, that could work. You can commit your pre-built files to your repo and ask Netlify to simply publish it by keeping build command as a blank string (or simply echo Hi!).
Thanks, @hrishikesh. That’s really good news! So what is the upper limit on number of files for Netlify Pro/Business plans?
Number of files has no realistic limit that I know of on any of the plans.
