Hello! I’m trying to deploy my website by means of
gatsby build
And while locally it works ok, on Netlify I’m getting a SIGKILL and no real explanation.
My website is at gianlucabelvisi.com
Git repo is: GitHub - gianlucabelvisi/gianlucabelvisi.com
3:50:59 PM: Build ready to start
3:51:01 PM: build-image version: 0582042f4fc261adc7bd8333f34884959c577302
3:51:01 PM: build-image tag: v3.7.6
3:51:01 PM: buildbot version: 3934dc3e65fec0466cd25051c676f6e727c64ab1
3:51:01 PM: Building without cache
3:51:01 PM: Starting to prepare the repo for build
3:51:01 PM: No cached dependencies found. Cloning fresh repo
3:51:01 PM: git clone https://github.com/gianlucabelvisi/personalpage
3:51:03 PM: Preparing Git Reference refs/heads/master
3:51:04 PM: Parsing package.json dependencies
3:51:05 PM: Different publish path detected, going to use the one specified in the Netlify configuration file: 'public' versus 'public/' in the Netlify UI
3:51:05 PM: Starting build script
3:51:05 PM: Installing dependencies
3:51:05 PM: Python version set to 2.7
3:51:06 PM: Attempting node version 'v16.1.0' from .nvmrc
3:51:06 PM: Downloading and installing node v16.1.0...
3:51:06 PM: Downloading https://nodejs.org/dist/v16.1.0/node-v16.1.0-linux-x64.tar.xz...
3:51:07 PM: Computing checksum with sha256sum
3:51:07 PM: Checksums matched!
3:51:10 PM: Now using node v16.1.0 (npm v7.11.2)
3:51:10 PM: Started restoring cached build plugins
3:51:10 PM: Finished restoring cached build plugins
3:51:10 PM: Attempting ruby version 2.7.1, read from environment
3:51:12 PM: Using ruby version 2.7.1
3:51:12 PM: Using PHP version 5.6
3:51:12 PM: Started restoring cached node modules
3:51:12 PM: Finished restoring cached node modules
3:51:12 PM: Installing NPM modules using NPM version 7.11.2
3:51:26 PM: npm WARN deprecated urix@0.1.0: Please see https://github.com/lydell/urix#deprecated
3:51:26 PM: npm WARN deprecated resolve-url@0.2.1: https://github.com/lydell/resolve-url#deprecated
3:51:29 PM: npm WARN deprecated chokidar@2.1.8: Chokidar 2 will break on node v14+. Upgrade to chokidar 3 with 15x less dependencies.
3:51:43 PM: npm WARN deprecated babel-eslint@10.1.0: babel-eslint is now @babel/eslint-parser. This package will no longer receive updates.
3:51:44 PM: npm WARN deprecated @hapi/topo@3.1.6: This version has been deprecated and is no longer supported or maintained
3:51:44 PM: npm WARN deprecated @hapi/bourne@1.3.2: This version has been deprecated and is no longer supported or maintained
3:51:45 PM: npm WARN deprecated @hapi/address@2.1.4: Moved to 'npm install @sideway/address'
3:51:45 PM: npm WARN deprecated @hapi/hoek@8.5.1: This version has been deprecated and is no longer supported or maintained
3:51:47 PM: npm WARN deprecated @hapi/joi@15.1.1: Switch to 'npm install joi'
3:51:56 PM: npm WARN deprecated core-js@2.6.12: core-js@<3.3 is no longer maintained and not recommended for usage due to the number of issues. Because of the V8 engine whims, feature detection in old core-js versions could cause a slowdown up to 100x even if nothing is polyfilled. Please, upgrade your dependencies to the actual version of core-js.
3:52:03 PM: added 2297 packages, and audited 2298 packages in 51s
3:52:03 PM: 280 packages are looking for funding
3:52:03 PM: run `npm fund` for details
3:52:03 PM: 22 vulnerabilities (17 moderate, 5 high)
3:52:03 PM: To address issues that do not require attention, run:
3:52:03 PM: npm audit fix
3:52:03 PM: To address all issues possible (including breaking changes), run:
3:52:03 PM: npm audit fix --force
3:52:03 PM: Some issues need review, and may require choosing
3:52:03 PM: a different dependency.
3:52:03 PM: Run `npm audit` for details.
3:52:04 PM: NPM modules installed
3:52:04 PM: Started restoring cached go cache
3:52:04 PM: Finished restoring cached go cache
3:52:04 PM: go version go1.14.4 linux/amd64
3:52:04 PM: Installing missing commands
3:52:04 PM: Verify run directory
3:52:06 PM:
3:52:06 PM: ────────────────────────────────────────────────────────────────
3:52:06 PM: Netlify Build
3:52:06 PM:
3:52:06 PM: ❯ Version
3:52:06 PM: @netlify/build 11.17.0
3:52:06 PM:
3:52:06 PM: ❯ Flags
3:52:06 PM: deployId: 609fd1c383ec5af184038638
3:52:06 PM:
3:52:06 PM: ❯ Current directory
3:52:06 PM: /opt/build/repo
3:52:06 PM:
3:52:06 PM: ❯ Config file
3:52:06 PM: No config file was defined: using default values.
3:52:06 PM:
3:52:06 PM: ❯ Context
3:52:06 PM: production
3:52:06 PM:
3:52:06 PM: 1. Build command from Netlify app
3:52:06 PM:
3:52:06 PM: $ gatsby build --verbose
3:52:07 PM: verbose 1.035803017 set gatsby_log_level: "verbose"
3:52:07 PM: verbose 1.037492119 set gatsby_executing_command: "build"
3:52:07 PM: verbose 1.03830031 loading local command from: /opt/build/repo/node_modules/gatsby/dist/commands/build.js
3:52:09 PM: verbose 2.94146894 running command: build
3:52:09 PM: success open and validate gatsby-configs - 0.063s
3:52:10 PM: success load plugins - 1.002s
3:52:10 PM: success onPreInit - 0.040s
3:52:10 PM: success initialize cache - 0.007s
3:52:10 PM: success copy gatsby files - 0.062s
3:52:10 PM: success onPreBootstrap - 0.019s
3:52:10 PM: success createSchemaCustomization - 0.016s
3:52:10 PM: verbose 4.513965613 Checking for deleted pages
3:52:10 PM: verbose 4.5146345 Deleted 0 pages
3:52:10 PM: verbose 4.514805307 Found 0 changed pages
3:52:10 PM: success Checking for changed pages - 0.001s
3:52:11 PM: success source and transform nodes - 0.294s
3:52:11 PM: success building schema - 0.798s
3:52:11 PM: success createPages - 0.095s
3:52:11 PM: success createPagesStatefully - 0.104s
3:52:12 PM: info Total nodes: 89, SitePage nodes: 9 (use --verbose for breakdown)
3:52:12 PM: verbose 5.51578795 Number of node types: 10. Nodes per type: SitePlugin: 38, Site: 1, SiteBuildMetadata: 1, SiteFunction: 1, Directory: 5, File: 20, ImageSharp: 8, MarkdownRemark: 2, TripsJson: 4, SitePage: 9
3:52:12 PM: verbose 5.515983024 Checking for deleted pages
3:52:12 PM: verbose 5.516363167 Deleted 0 pages
3:52:12 PM: verbose 5.516897951 Found 9 changed pages
3:52:12 PM: success Checking for changed pages - 0.000s
3:52:12 PM: success update schema - 0.130s
3:52:12 PM: success onPreExtractQueries - 0.000s
3:52:12 PM: error (node:1716) [DEP0148] DeprecationWarning: Use of deprecated folder mapping "./" in the "exports" field module resolution of the package at /opt/build/repo/node_modules/postcss/package.json.
3:52:12 PM: Update this package.json to use a subpath pattern like "./*".
3:52:12 PM: (Use `node --trace-deprecation ...` to show where the warning was created)
3:52:18 PM: success extract queries from components - 6.448s
3:52:18 PM: success write out redirect data - 0.001s
3:52:18 PM: success Build manifest and related icons - 0.165s
3:52:18 PM: success onPostBootstrap - 0.168s
3:52:18 PM: info bootstrap finished - 12.270s
3:52:28 PM: success run static queries - 10.049s - 3/3 0.30/s
3:53:22 PM: success run page queries - 53.314s - 9/9 0.17/s
3:53:52 PM: success write out requires - 30.210s
3:54:08 PM:
3:54:08 PM: ────────────────────────────────────────────────────────────────
3:54:08 PM: "build.command" failed
3:54:08 PM:
3:54:08 PM: Error message
3:54:08 PM: Command was killed with SIGKILL (Forced termination): gatsby build --verbose
3:54:08 PM:
3:54:08 PM: Error location
3:54:08 PM: In Build command from Netlify app:
3:54:08 PM: gatsby build --verbose
3:54:08 PM:
3:54:08 PM: Resolved config
3:54:08 PM: build:
3:54:08 PM: command: gatsby build --verbose
3:54:08 PM: commandOrigin: ui
3:54:08 PM: publish: /opt/build/repo/public
3:54:09 PM: Caching artifacts
3:54:09 PM: Started saving node modules
3:54:09 PM: Finished saving node modules
3:54:09 PM: Started saving build plugins
3:54:09 PM: Finished saving build plugins
3:54:09 PM: Started saving pip cache
3:54:09 PM: Finished saving pip cache
3:54:09 PM: Started saving emacs cask dependencies
3:54:09 PM: Finished saving emacs cask dependencies
3:54:09 PM: Started saving maven dependencies
3:54:09 PM: Finished saving maven dependencies
3:54:09 PM: Started saving boot dependencies
3:54:09 PM: Finished saving boot dependencies
3:54:09 PM: Started saving rust rustup cache
3:54:09 PM: Finished saving rust rustup cache
3:54:09 PM: Started saving go dependencies
3:54:09 PM: Finished saving go dependencies
3:54:13 PM: Build failed due to a user error: Build script returned non-zero exit code: 2
3:54:13 PM: Creating deploy upload records
3:54:13 PM: Failing build: Failed to build site
3:54:13 PM: Failed during stage 'building site': Build script returned non-zero exit code: 2
3:54:13 PM: Finished processing build request in 3m12.419972264s
