This started happening on my nightly builds starting on the 28th and any subsequent commits to my GitHub repo to https://unrivaled-sawine-ed32a6.netlify.app/
Literally nothing had changed, so I’m not sure what is going on here.
6:06:54 PM: Start building sites … 6:06:54 PM: hugo v0.85.0-724D5DB5 linux/amd64 BuildDate=2021-07-05T10:46:28Z VendorInfo=gohugoio 6:06:59 PM: Error: Error building site: TOCSS: failed to transform "scss/style.scss" (text/x-scss). Check your Hugo installation; you need the extended version to build SCSS/SASS. 6:06:59 PM: Total in 5416 ms 6:06:59 PM: 6:06:59 PM: ──────────────────────────────────────────────────────────────── 6:06:59 PM: "build.command" failed 6:06:59 PM: ──────────────────────────────────────────────────────────────── 6:06:59 PM: 6:06:59 PM: Error message 6:06:59 PM: Command failed with exit code 255: hugo (https://ntl.fyi/exit-code-255) 6:06:59 PM: 6:06:59 PM: Error location 6:06:59 PM: In Build command from Netlify app: 6:06:59 PM: hugo 6:06:59 PM: 6:06:59 PM: Resolved config 6:06:59 PM: build: 6:06:59 PM: command: hugo 6:06:59 PM: commandOrigin: ui 6:06:59 PM: environment: 6:06:59 PM: - NETLIFY_GRAPH_TOKEN 6:06:59 PM: - ONEGRAPH_AUTHLIFY_TOKEN 6:06:59 PM: publish: /opt/build/repo/public 6:06:59 PM: publishOrigin: ui
Build settings:
