How to add same domain to other sites/projects?
So let’s say i have a domain www.example.com that is with Netlify.
Currently on my main site i have different projects that just have a Link to external hosting site. But i want to move all my projects from external host to Netlify as separate Netlify sites(*netlify.app).
But when entering those sites i don’t to have the default *netlify.app domain on them and want them to have www.example/projects/project_one
Is there a way for me to link these projects to my main site using my main domain?
hey Marius, I think what you are referring to is a Monorepo:
I’m just unsure, do i need to create two sites for those two projects? Because if i create two sites for them they will have their own domain and not sit under example.com/*?
So structure is like this
main_site (example.com)
   Project1 (example.com/project1)
   Project2 (example.com/project2)
So main_site will be main domain: example.com.
And then i want Project1 and Project2 to be accesses using these two links:
  • example.com/project1
  • example.com/project2
I think this is my solution [Support Guide] Can I deploy multiple repositories in a single site?
Yup, that sounds right. Let us know how it goes.
Yep the routing is working great, only thing i needed to add in my main domain:
[[redirects]]
from = "/app1"
to = "https://determined-curie-bc9b33.netlify.app/"
status = 200
BUT, having issues with axios posting to app1 from my main domain www.marius.dev/app1.
So if you open www.marius.dev/app1 you will see 3 buttons that onClick send post to https://determined-curie-bc9b33.netlify.app but the first two wont work and only the last button will because in axios i have hardcoded my actual domain name.
Full code app1:
import React from 'react'
import axios from 'axios'
export default function App() {
  const currentHost = window.location.href
  console.log(window.location)
  console.log('Current Host', currentHost)
  const submitLocalHost = async (value, actions) => {
    await axios
      .post(`${currentHost}_base`)
      .then((res) => {
        console.log(res)
      .catch((err) => {
        console.log(err)
  const submitLocalHostWithS = async (value, actions) => {
    await axios
      .post(`_base`)
      .then((res) => {
        console.log(res)
      .catch((err) => {
        console.log(err)
  const submitNetlifyApp = async (value, actions) => {
    await axios
      .post(`https://determined-curie-bc9b33.netlify.app/_base`)
      .then((res) => {
        console.log(res)
      .catch((err) => {
        console.log(err)
  return (
      <button type="button" onClick={submitLocalHost}>
        Test 1
      </button>
      <br />
      <button type="button" onClick={submitLocalHostWithS}>
        Test 2
      </button>
      <br />
      <button type="button" onClick={submitNetlifyApp}>
        Netlify App
      </button>
Ofcourse there is no issues when i do this from the actual app1 domain https://determined-curie-bc9b33.netlify.app/
So is there a way for me to have some kind of variable or maybe something else in config so that between my dev and prod environment i don’t need to think about what variable i need place in axios when doing these type of re-direct/proxy?
You can probably use one of the read-only env vars that we set for your deploy: Build environment variables | Netlify Docs. Maybe the CONTEXT var works for you?
