I would like to remove Netlify Large Media from my site scottsmith.netlify.app
I had used in the past, but changed my mind.
Thanks
Thanks
Thanks for letting us know you want to uninstall the Large Media add-on for your site. Would you please confirm you have read the following Support Guide?
If you have read that, please confirm you have backups of all files and that we should proceed with removing the Large Media add-on.
Yes, we are good to go. Thanks again.
Hi,
We have removed the Large Media add-on from the site now.
Would you please push the commit removing .lfsconfig
to the upstream repository? This will trigger a new build.
Please keep in mind that you might want to run the command below after deleting the .lfsconfig
file:
git lfs push --all origin
This will sync the local repo’s LFS objects with the Git LFS service at the original Git host. It pushes any new binary blobs to their LFS service which may have been added after you moved the LFS service to Large Media.
Please let us know if there are any issues with the new build or deployed site.
Thanks, it’s working now!
-scott
