my site jnchapmantest.tk
I looked at the _headers docs.
Is this valid for a _headers file?
I want the rule to apply to all .html files, I think.
I have a simple .html site deployed with github
I’m trying to comply with
and get my score above D+.
Block site from being framed with X-Frame-Options and CSP
/*.html
Content-Security-Policy: frame-ancestors ‘none’
X-Frame-Options: DENY
Content-Security-Policy: frame-ancestors ‘self’
X-Frame-Options: SAMEORIGIN
Did you use the search before posting?
What about reading through our Search results for 'common issue' - Netlify Support Forums ?
X-XSS-Protection: 1; mode=block
Referrer-Policy: no-referrer
X-Content-Type-Options: nosniff
This is a start. I think /* means apply the rules to all the files
Exactly 2 space indent for the 4 lines (not visible in this editor)
luke
February 27, 2020, 9:39am
3
Hi, @newschapmj1 , and welcome to our Netlify community site.
The * rule matches anything and cannot be used to match a partial line. If you use *, the html cannot appear after it or the rule won’t work. So, this is allowed:
While this is not:
/*.html
The header rule below would be applied to all files served by Netlify for this site:
If there are other questions, please let us know.
