Hello, I want to deploy from contentful or git to Netlify and I receive error
Please check error below:
3:57:53 PM: 144 packages are looking for funding
3:57:53 PM: runnpm fundfor details
3:57:53 PM: found 799 vulnerabilities (763 low, 4 moderate, 32 high)
3:57:53 PM: runnpm audit fixto fix them, ornpm auditfor details
3:57:54 PM: > swiftlane-web@1.0.0 build /opt/build/repo/swiftlane
3:57:54 PM: > gatsby build
3:57:57 PM: error Cannot read property ‘activities’ of undefined
3:57:57 PM:
3:57:57 PM: TypeError: Cannot read property ‘activities’ of undefined
3:57:57 PM:
3:57:57 PM: - utils.js:20 getGlobalStatus
3:57:57 PM: [swiftlane]/[gatsby]/[gatsby-cli]/lib/reporter/redux/utils.js:20:54
3:57:57 PM:
3:57:57 PM: - internal-actions.js:137 Object.startActivity
3:57:57 PM: [swiftlane]/[gatsby]/[gatsby-cli]/lib/reporter/redux/internal-actions.js:137 :51
3:57:57 PM:
3:57:57 PM: - redux.js:483 Object.startActivity
3:57:57 PM: [swiftlane]/[redux]/lib/redux.js:483:35
3:57:57 PM:
3:57:57 PM: - reporter-timer.js:24 Object.start
3:57:57 PM: [swiftlane]/[gatsby]/[gatsby-cli]/lib/reporter/reporter-timer.js:24:23
3:57:57 PM:
3:57:57 PM: - index.js:125 module.exports
3:57:57 PM: [swiftlane]/[gatsby]/dist/bootstrap/index.js:125:12
3:57:57 PM:
3:57:57 PM: - build.js:72 build
3:57:57 PM: [swiftlane]/[gatsby]/dist/commands/build.js:72:13
3:57:57 PM:
3:57:57 PM: - create-cli.js:174 cli.command.handler.getCommandHandler
3:57:57 PM: [swiftlane]/[gatsby]/[gatsby-cli]/lib/create-cli.js:174:14
3:57:57 PM:
3:57:57 PM: - create-cli.js:101 argv
3:57:57 PM: [swiftlane]/[gatsby]/[gatsby-cli]/lib/create-cli.js:101:24
3:57:57 PM:
3:57:57 PM: - create-cli.js:35 Object.args [as handler]
3:57:57 PM: [swiftlane]/[gatsby]/[gatsby-cli]/lib/create-cli.js:35:19
3:57:57 PM:
3:57:57 PM: - command.js:238 Object.runCommand
3:57:57 PM: [swiftlane]/[yargs]/lib/command.js:238:44
3:57:57 PM:
3:57:57 PM: - yargs.js:1063 Object.parseArgs [as _parseArgs]
3:57:57 PM: [swiftlane]/[yargs]/yargs.js:1063:30
3:57:57 PM:
3:57:57 PM: - yargs.js:566 Object.parse
3:57:57 PM: [swiftlane]/[yargs]/yargs.js:566:25
3:57:57 PM:
3:57:57 PM: - create-cli.js:404 module.exports.argv
3:57:57 PM: [swiftlane]/[gatsby]/[gatsby-cli]/lib/create-cli.js:404:6
3:57:57 PM:
3:57:57 PM: - index.js:141 Object.
3:57:57 PM: [swiftlane]/[gatsby]/[gatsby-cli]/lib/index.js:141:24
3:57:57 PM:
3:57:57 PM: - loader.js:778 Module._compile
3:57:57 PM: internal/modules/cjs/loader.js:778:30
3:57:57 PM:
3:57:57 PM: - loader.js:789 Object.Module._extensions…js
3:57:57 PM: internal/modules/cjs/loader.js:789:10
3:57:57 PM:
3:57:57 PM:
3:57:57 PM: error UNHANDLED REJECTION Cannot read property ‘activities’ of undefined
3:57:57 PM:
3:57:57 PM:
3:57:57 PM:
3:57:57 PM: - internal-actions.js:108 createPendingActivity
3:57:57 PM: [swiftlane]/[gatsby]/[gatsby-cli]/lib/reporter/redux/internal-actions.js:108 :51
3:57:57 PM:
3:57:57 PM:
3:57:57 PM: - catch-exit-signals.js:37 prematureEnd
3:57:57 PM: [swiftlane]/[gatsby]/[gatsby-cli]/lib/reporter/catch-exit-signals.js:37:38
3:57:57 PM:
3:57:57 PM: - reporter.js:71 Reporter [as panic]
3:57:57 PM: [swiftlane]/[gatsby]/[gatsby-cli]/lib/reporter/reporter.js:71:42
3:57:57 PM:
3:57:57 PM: - create-cli.js:35 Promise.resolve.then.err
3:57:57 PM: [swiftlane]/[gatsby]/[gatsby-cli]/lib/create-cli.js:35:74
3:57:57 PM:
3:57:57 PM: - next_tick.js:68 process._tickCallback
3:57:57 PM: internal/process/next_tick.js:68:7
3:57:57 PM:
3:57:57 PM: - loader.js:834 Function.Module.runMain
3:57:57 PM: internal/modules/cjs/loader.js:834:11
3:57:57 PM:
3:57:57 PM: - node.js:283 startup
3:57:57 PM: internal/bootstrap/node.js:283:19
3:57:57 PM:
3:57:57 PM: - node.js:623 bootstrapNodeJSCore
3:57:57 PM: internal/bootstrap/node.js:623:3
3:57:57 PM:
3:57:57 PM:
3:57:57 PM: error UNHANDLED EXCEPTION Cannot read property ‘activities’ of undefined
3:57:57 PM:
3:57:57 PM:
3:57:57 PM:
3:57:57 PM:
3:57:57 PM:
3:57:57 PM:
3:57:57 PM:
3:57:57 PM: - index.js:136 process.on.reason
3:57:57 PM: [swiftlane]/[gatsby]/[gatsby-cli]/lib/index.js:136:21
3:57:57 PM:
3:57:57 PM: - index.js:155 processEmit [as emit]
3:57:57 PM: [swiftlane]/[signal-exit]/index.js:155:32
3:57:57 PM:
3:57:57 PM: - promises.js:140 emitPromiseRejectionWarnings
3:57:57 PM: internal/process/promises.js:140:18
3:57:57 PM:
3:57:57 PM: - next_tick.js:69 process._tickCallback
3:57:57 PM: internal/process/next_tick.js:69:34
3:57:57 PM:
3:57:57 PM:
3:57:57 PM:
3:57:57 PM:
3:57:57 PM:
3:57:57 PM: /opt/build/repo/swiftlane/node_modules/gatsby/node_modules/gatsby-cli/lib/reporter/redux/utils.js:20
3:57:57 PM: const currentActivities = [id, …Object.keys(logs.activities)];
3:57:57 PM: ^
3:57:57 PM: at getGlobalStatus (/opt/build/repo/swiftlane/node_modules/gatsby/node_modules/gatsby-cli/lib/reporter/redux/utils.js:20:54)
3:57:57 PM: at createPendingActivity (/opt/build/repo/swiftlane/node_modules/gatsby/node_modules/gatsby-cli/lib/reporter/redux/internal-actions.js:108:51)
3:57:57 PM: at /opt/build/repo/swiftlane/node_modules/redux/lib/redux.js:483:35
3:57:57 PM: at prematureEnd (/opt/build/repo/swiftlane/node_modules/gatsby/node_modules/gatsby-cli/lib/reporter/catch-exit-signals.js:37:38)
3:57:57 PM: at Reporter [as panic] (/opt/build/repo/swiftlane/node_modules/gatsby/node_modules/gatsby-cli/lib/reporter/reporter.js:71:42)
3:57:57 PM: at process.on.error (/opt/build/repo/swiftlane/node_modules/gatsby/node_modules/gatsby-cli/lib/index.js:139:21)
3:57:57 PM: at process.emit (events.js:198:13)
3:57:57 PM: at processEmit [as emit] (/opt/build/repo/swiftlane/node_modules/signal-exit/index.js:155:32)
3:57:57 PM: at process._fatalException (internal/bootstrap/node.js:497:27)
3:57:57 PM: npm
3:57:57 PM: ERR! code
3:57:57 PM: ELIFECYCLE
3:57:57 PM: npm
3:57:57 PM: ERR! errno
3:57:57 PM: 7
3:57:57 PM: npm ERR!
3:57:57 PM: swiftlane-web@1.0.0 build:gatsby build
3:57:57 PM: npm
3:57:57 PM: ERR! Exit status 7
3:57:57 PM: npm ERR! Failed at the swiftlane-web@1.0.0 build script.
3:57:57 PM: npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
3:57:57 PM: npm
3:57:57 PM: ERR! A complete log of this run can be found in:
3:57:57 PM: npm ERR! /opt/buildhome/.npm/_logs/2020-04-19T13_57_57_130Z-debug.log
3:57:57 PM: Skipping functions preparation step: no functions directory set
3:57:57 PM: Caching artifacts
3:57:57 PM: Started saving node modules
3:57:57 PM: Finished saving node modules
3:57:57 PM: Started saving yarn cache
3:57:57 PM: Finished saving yarn cache
3:57:57 PM: Started saving pip cache
3:57:57 PM: Finished saving pip cache
3:57:57 PM: Started saving emacs cask dependencies
3:57:57 PM: Finished saving emacs cask dependencies
3:57:57 PM: Started saving maven dependencies
3:57:57 PM: Finished saving maven dependencies
3:57:57 PM: Started saving boot dependencies
3:57:57 PM: Finished saving boot dependencies
3:57:57 PM: Started saving go dependencies
3:57:57 PM: Finished saving go dependencies
3:58:02 PM: Error running command: Build script returned non-zero exit code: 7
3:58:02 PM: Failing build: Failed to build site
3:58:03 PM: failed during stage ‘building site’: Build script returned non-zero exit code: 7
3:58:03 PM: Finished processing build request in 4m33.087483175s
