Hi, could the timeout for functions on the site with ID
ffd506b8-7fd6-406b-a64b-b8356d8665e4 be increased to 25s? Thanks.
Hi @jayvin ! This is all set. Be sure to redeploy so the change takes effect. Thanks!
Hi netlify, could you also please increase our timeout for functions for our siteId: bcb0b3de-e9fa-42cd-b950-7d978d0346c5
to 25s? Thank you very much!! Will solve many problems for us. Would be awesome to have this option in the UI for pro plans!!
Best regards, Jörn
Hi @jdde,
Thanks for reaching out! I’ve increased the function time limit to 26 seconds for the site. You’ll need to re-deploy for the change to take effect.
Hi, could you please increase the timeout limit to the max for this site ID: 832fade9-7a33-4316-b9af-2c1b27066677
Thanks so much!
HI @jtepp,
Thanks for reaching out! I’ve increased the function time limited from 10 to 26 seconds (the maximum) for the site. You’ll need to re-deploy the site for this change to take effect.
Hi, could you please increase the timeout limit to the max for this site ID 28dcd134-be2d-40e6-ad64-83b761d3cd17 name = cobli
Thank you!
Hi, it looks like your function timeout for your site is already set to the max of 26s. If you are not seeing this can you please re-deploy ?
Hi could you set my timeout limit to 26seconds as well. Thanks
271ea8dd-59fd-49df-8b72-82a2f025777a
Done, please re-deploy.
Hi kindly increase the timeout for 2b01e583-6612-462a-805a-e3fac1fdf705.
Thank You
Hi thanks for reaching out! I have increased your function timeout. Please re-deploy your site to see this take effect. (:
Hey @SamO,
Could you please increase the timeout to 26s for site ID 3210af3e-8915-4c53-b265-1654557222b1 ?
Thank you!
Hi @ada,
Thanks for reaching out! I’ve increased the function time out to 26 seconds (the maximum) for the site. You’ll need to re-deploy for this change to take effect.
@Melvin thank you! That’s v helpful
Hello support team! Could someone please increase the function timeout to the max for site ID 201440de-aaa1-4d42-b63c-416db67ffbbf
? Thanks!
Hey there! This is done, just redeploy for the changes to take effect.
Hello support team! Could you please increase the function timeout to the max for site ID:
1adf383f-d7ff-40fb-bc81-ad4192556479
thank you!
@hoggMan, this is done, please re-deploy.
Hi, would it be possible for an increase to 30s on site id: 3920ac43-0dd8-4628-b212-c35925f18d4e
Thanks,
