Function timeout increase
hi, :wave:t6: thanks for reaching out! I have increased your function timeout to the max. You will need to re-deploy your site to see this take effect.
Could you also increase timeout for site ffbf681d-88a6-4cf2-9b7d-9000b4dcf402 to the max allowed amount?
@jsullivanlive I’ve updated the timeout to 26 seconds, please redeploy the site to see that change take effect.
Hey @sid.m can you increase the timeout for our sites to the max allowed amount?
  • fc573c3f-c265-4d4d-b1b2-c89556b126d4
  • 633a2194-ed88-45ba-8521-33a05c86abfb
We’re in the Pro Tier.
Hi @Univere,
Thanks for reaching out! I’ve increased the function time limit for both sites to the maximum of 26 seconds. Please re-deploy the two sites for the change to take effect.
Hi, can you please set te timeout limit of our site with id 76cc869f-83c6-4b12-be36-948a48b31a45
to 26s?
Thank you very much :slightly_smiling_face:
Hi :wave:t6: thanks for reaching out! I have increased your function timeout please re-deploy to see this take effect.
Hi, could you please also increase our function timeout to the max please?
Our site id is: 5227c19a-c1fa-4c20-b965-83bfeb062297
hi thanks for reaching out. I have increased your function timeout to 26s. Please re-deploy to see this take effect.
Hi, can you please increase the timeout limit for the site 76bd2f6f-ebc6-4f2f-9296-153c121cc7c7 ?
Thanks!
@frayu I’ve updated the timeout to 26 seconds, you’ll need to redeploy the site.
Hi can you increase the timeout for:
6ab9f482-79d6-47e4-a14d-5fc558a009e6
and
e0be5079-c2e7-4f3f-b4a1-f71e4fd3a642
and
cd4ac1b3-a46b-4323-9396-ff8f0eb7e4c2
Thanks
Hi @barnabas,
I’ve increased the function time limit for those three sites to 26 seconds (the maximum). Please re-deploy each site for the change to take effect.
Hi,
Can you increase the timeout to 25s for site 19646d80-f03c-4273-9044-39143bcb418c?
Thanks
Hi there,
I’ve increased the function time limit for the above site to 25s. Please re-deploy the site for the change to take effect.
Hello! Please increase the function timeout to the maximum for site c707a026-c186-4d80-92d7-965e8c6fb0db
Thank you!
b2ccf7a1-751d-4ac1-99b4-cd1c5802a675
When testing locally is there some way to edit .toml file?
Timeout has been increase, please re-deploy. As for local config, running netlify link will solve it.
Do you mean with netlify link there is No need to write to you to increase time out limit
Sendt fra Outlook til Android
@cphthomas Running netlify link connects your local project or repository to your site on Netlify (see docs to learn more) .You’ll still need to write in to request timeout increase :slight_smile:
