radek
May 15, 2020, 2:49pm
1
How to enforce the Dart SDK version for build?
Deploy: Netlify App
build log:
3:58:51 PM: Running “flutter pub get” in repo…
3:58:52 PM: The current Dart SDK version is 2.6.0-dev.5.0.flutter-d6c6d12ebf.
3:58:52 PM: Because xxxxxx requires SDK version >=2.6.0 <3.0.0, version solving failed.
3:58:52 PM: pub get failed (1)
Scott
May 19, 2020, 1:59pm
2
Hey @radek ,
You should be able to update this from “dependencies” within your package.json file. Let me know if this helps!
radek
May 19, 2020, 2:49pm
3
Actually the reason was that Flutter does not update .metadata files during its upgrades. So everything is correct on the Netlify side.
Resolved. Thanks
Hi mate, do you mind letting the rest of us know exactly what you did to build flutter apps on netlify? Thanks.
radek
July 8, 2020, 10:45am
6
I am building the web release of the flutter app from the last commit. So this is not related to the android / ios apps. Is the flutter web of your interest?
radek
July 8, 2020, 11:25am
8
I am using the master channel.
FLUTTER_BRANCH=grep channel: .metadata | sed 's/ channel: //g'
FLUTTER_REVISION=grep revision: .metadata | sed 's/ revision: //g'
git checkout $FLUTTER_BRANCH
git pull origin $FLUTTER_BRANCH
git checkout $FLUTTER_REVISION
Are you using what is mentioned on this?
flutter-netlify-build.sh
#!/bin/sh
FLUTTER_BRANCH=`grep channel: .metadata | sed 's/ channel: //g'`
FLUTTER_REVISION=`grep revision: .metadata | sed 's/ revision: //g'`
git clone https://github.com/flutter/flutter.git
cd flutter
cd ..
This file has been truncated. show original
netlify.toml
[build]
command = "./flutter-netlify-build.sh"
publish = "build/web"
radek
July 8, 2020, 7:53pm
10
