I’m trying to deploy a React Js App I saved on a Git Hub repo. But, when I start the deploy I get hit with the error: My Build Failed during stage ‘building site’: Build script returned non-zero exit code: 2. Also, when I build the React Js app locally, it builds successfully, for some reason it is just not deploying!
My Deploy log is shown below:
8:28:37 PM: build-image version: a2d22d22e4555d1ef0a972ed14a0a4b366ad20c4 (focal)
8:28:37 PM: build-image tag: v4.16.3
8:28:37 PM: buildbot version: 3bd65547ad0cc7e555b4d091bb1e3da5ef545973
8:28:37 PM: Fetching cached dependencies
8:28:37 PM: Failed to fetch cache, continuing with build
8:28:37 PM: Starting to prepare the repo for build
8:28:37 PM: No cached dependencies found. Cloning fresh repo
8:28:37 PM: git clone --filter=blob:none https://github.com/jethrolibutan/farm2clinic
8:29:03 PM: Preparing Git Reference refs/heads/main
8:29:04 PM: Parsing package.json dependencies
8:29:05 PM: Starting build script
8:29:06 PM: Installing dependencies
8:29:06 PM: Python version set to 2.7
8:29:06 PM: v16.19.0 is already installed.
8:29:06 PM: Now using node v16.19.0 (npm v8.19.3)
8:29:06 PM: Enabling Node.js Corepack
8:29:07 PM: Started restoring cached build plugins
8:29:07 PM: Finished restoring cached build plugins
8:29:07 PM: Attempting Ruby version 2.7.2, read from environment
8:29:08 PM: Using Ruby version 2.7.2
8:29:08 PM: Using PHP version 8.0
8:29:08 PM: Started restoring cached corepack dependencies
8:29:08 PM: mv: cannot move ‘/opt/build/cache/.node/corepack’ to ‘/opt/buildhome/.node/corepack’: No such file or directory
8:29:08 PM: Finished restoring cached corepack dependencies
8:29:08 PM: No npm workspaces detected
8:29:08 PM: Started restoring cached node modules
8:29:08 PM: Finished restoring cached node modules
8:29:08 PM: Bypassing sha validation. Running pre & post install scripts
8:29:08 PM: Installing npm packages using npm version 8.19.3
8:29:13 PM: npm WARN deprecated w3c-hr-time@1.0.2: Use your platform’s native performance.now() and performance.timeOrigin.npm WARN deprecated stable@0.1.8: Modern JS already guarantees Array#sort() is a stable sort, so this library is deprecated. See the compatibility table on MDN: Array.prototype.sort() - JavaScript | MDN
8:29:13 PM: npm WARN deprecated sourcemap-codec@1.4.8: Please use @jridgewell/sourcemap-codec instead
8:29:13 PM: npm WARN deprecated rollup-plugin-terser@7.0.2: This package has been deprecated and is no longer maintained. Please use @rollup/plugin-terser
8:29:16 PM: npm WARN deprecated svgo@1.3.2: This SVGO version is no longer supported. Upgrade to v2.x.x.
8:29:27 PM: added 1514 packages, and audited 1515 packages in 19s
8:29:27 PM: 235 packages are looking for funding
8:29:27 PM: run npm fund for details
8:29:27 PM: 7 high severity vulnerabilities
8:29:27 PM: To address issues that do not require attention, run:
8:29:27 PM: npm audit fix
8:29:27 PM: To address all issues (including breaking changes), run:
8:29:27 PM: npm audit fix --force
8:29:27 PM: Run npm audit for details.
8:29:27 PM: npm packages installed
8:29:28 PM: Started restoring cached go cache
8:29:28 PM: Finished restoring cached go cache
8:29:29 PM: Installing Go version 1.19.5 (requested 1.19.x)
8:29:34 PM: unset GOOS;
8:29:34 PM: unset GOARCH;
8:29:34 PM: export GOROOT=‘/opt/buildhome/.gimme/versions/go1.19.5.linux.amd64’;
8:29:34 PM: export PATH=“/opt/buildhome/.gimme/versions/go1.19.5.linux.amd64/bin:${PATH}”;
8:29:34 PM: go version >&2;
8:29:34 PM: export GIMME_ENV=“/opt/buildhome/.gimme/env/go1.19.5.linux.amd64.env”
8:29:34 PM: go version go1.19.5 linux/amd64
8:29:35 PM: Detected 1 framework(s)
8:29:35 PM: “create-react-app” at version “5.0.1”
8:29:35 PM: Installing missing commands
8:29:35 PM: Verify run directory
8:29:35 PM: Section completed: initializing
8:29:36 PM:
8:29:36 PM: Netlify Build
8:29:36 PM: ────────────────────────────────────────────────────────────────
8:29:36 PM:
8:29:36 PM: ❯ Version
8:29:36 PM: @netlify/build 29.5.0
8:29:36 PM:
8:29:36 PM: ❯ Flags
8:29:36 PM: baseRelDir: true
8:29:36 PM: buildId: 63c74b43ae0c7e6f7e47902d
8:29:36 PM: deployId: 63c74b43ae0c7e6f7e47902f
8:29:36 PM:
8:29:36 PM: ❯ Current directory
8:29:36 PM: /opt/build/repo
8:29:36 PM:
8:29:36 PM: ❯ Config file
8:29:36 PM: No config file was defined: using default values.
8:29:36 PM:
8:29:36 PM: ❯ Context
8:29:36 PM: production
8:29:36 PM:
8:29:36 PM: 1. Build command from Netlify app
8:29:36 PM:
8:29:36 PM: $ npm run build
8:29:37 PM: > farm2clinic@0.1.0 build
8:29:37 PM: > react-scripts build
8:29:38 PM: Creating an optimized production build…
8:30:05 PM:
8:30:05 PM: Treating warnings as errors because process.env.CI = true.
8:30:05 PM: Most CI servers set it automatically.
8:30:05 PM:
8:30:05 PM: Failed to compile.
8:30:05 PM:
8:30:05 PM: [eslint]
8:30:05 PM: src/Helper/SpanishData.js
8:30:05 PM: Line 1:8: ‘React’ is defined but never used no-unused-vars
8:30:05 PM: src/pages/GetInvolved.js
8:30:05 PM: Line 104:11:
any help is greatly appreciated, thank you so much!
