So I’m using React & a visual CMS called builder.io to make the front-end of a website. On builder’s website they recommended using netlify for deployment but I’m having issues with the building process. I’m sorry if this is a rookie question but this is my 2nd time deploying a website & my 1st time using this service.
Site Name:
Build Log:
9:30:58 AM: build-image version: 6501259a85bcb5b09824d72c8b1321d814d28904 (focal)
9:30:58 AM: buildbot version: 6501259a85bcb5b09824d72c8b1321d814d28904
9:30:58 AM: Fetching cached dependencies
9:30:58 AM: Failed to fetch cache, continuing with build
9:30:58 AM: Starting to prepare the repo for build
9:30:58 AM: No cached dependencies found. Cloning fresh repo
9:30:58 AM: git clone --filter=blob:none GitHub - AaronBrinkley/Alone-Builder
9:30:59 AM: Preparing Git Reference refs/heads/main
9:30:59 AM: Parsing package.json dependencies
9:31:00 AM: Starting build script
9:31:00 AM: Installing dependencies
9:31:00 AM: Python version set to 2.7
9:31:01 AM: v16.19.0 is already installed.
9:31:01 AM: Now using node v16.19.0 (npm v8.19.3)
9:31:01 AM: Enabling Node.js Corepack
9:31:02 AM: Started restoring cached build plugins
9:31:02 AM: Finished restoring cached build plugins
9:31:02 AM: Attempting Ruby version 2.7.2, read from environment
9:31:02 AM: Using Ruby version 2.7.2
9:31:03 AM: Using PHP version 8.0
9:31:03 AM: Started restoring cached corepack dependencies
9:31:03 AM: mv: cannot move ‘/opt/build/cache/.node/corepack’ to ‘/opt/buildhome/.node/corepack’: No such file or directory
9:31:03 AM: Finished restoring cached corepack dependencies
9:31:03 AM: No npm workspaces detected
9:31:03 AM: Started restoring cached node modules
9:31:03 AM: Finished restoring cached node modules
9:31:03 AM: Bypassing sha validation. Running pre & post install scripts
9:31:03 AM: Installing npm packages using npm version 8.19.3
9:31:08 AM: npm WARN deprecated w3c-hr-time@1.0.2: Use your platform’s native performance.now() and performance.timeOrigin.npm WARN deprecated stable@0.1.8: Modern JS already guarantees Array#sort() is a stable sort, so this library is deprecated. See the compatibility table on MDN: Array.prototype.sort() - JavaScript | MDN
9:31:08 AM: npm WARN deprecated sourcemap-codec@1.4.8: Please use jridgewell/sourcemap-codec instead
9:31:09 AM: npm WARN deprecated rollup-plugin-terser@7.0.2: This package has been deprecated and is no longer maintained. Please use rollup/plugin-terser
9:31:13 AM: npm WARN deprecated svgo1.3.2: This SVGO version is no longer supported. Upgrade to v2.x.x.
9:31:18 AM: added 1499 packages, and audited 1500 packages in 15s
9:31:18 AM: 232 packages are looking for funding
9:31:18 AM: run npm fund for details
9:31:18 AM: 6 high severity vulnerabilities
9:31:18 AM: To address all issues (including breaking changes), run:
9:31:18 AM: npm audit fix --force
9:31:18 AM: Run npm audit for details.
9:31:18 AM: npm packages installed
9:31:18 AM: Started restoring cached go cache
9:31:18 AM: Finished restoring cached go cache
9:31:18 AM: go version go1.19.5 linux/amd64
9:31:18 AM: Detected 1 framework(s)
9:31:19 AM: “create-react-app” at version “5.0.1”
9:31:19 AM: Installing missing commands
9:31:19 AM: Verify run directory
9:31:19 AM: Section completed: initializing
9:31:20 AM:
9:31:20 AM: Netlify Build
9:31:20 AM: ────────────────────────────────────────────────────────────────
9:31:20 AM:
9:31:20 AM: ❯ Version
9:31:20 AM: @netlify/build 29.5.1
9:31:20 AM:
9:31:20 AM: ❯ Flags
9:31:20 AM: baseRelDir: true
9:31:20 AM: buildId: 63da779f0cc95205a0a8e2b9
9:31:20 AM: deployId: 63da779f0cc95205a0a8e2bb
9:31:20 AM:
9:31:20 AM: ❯ Current directory
9:31:20 AM: /opt/build/repo
9:31:20 AM:
9:31:20 AM: ❯ Config file
9:31:20 AM: No config file was defined: using default values.
9:31:20 AM:
9:31:20 AM: ❯ Context
9:31:20 AM: production
9:31:20 AM:
9:31:20 AM: 1. Build command from Netlify app
9:31:20 AM:
9:31:20 AM: $ npm run build
9:31:20 AM: > my-app@0.1.0 build
9:31:20 AM: > react-scripts build
9:31:21 AM: Creating an optimized production build…
9:31:28 AM:
9:31:28 AM: Treating warnings as errors because process.env.CI = true.
9:31:28 AM: Most CI servers set it automatically.
9:31:28 AM:
9:31:28 AM: Failed to compile.
9:31:28 AM:
9:31:28 AM: [eslint]
9:31:28 AM: src/App.js
9:31:28 AM: Line 11:9: ‘isPreviewingInBuilder’ is assigned a value but never used no-unused-vars
9:31:28 AM: Line 12:10: ‘notFound’ is assigned a value but never used no-unused-vars
9:31:28 AM: Line 28:6: React Hook useEffect has an unnecessary dependency: ‘window.location.pathname’. Either exclude it or remove the dependency array. Outer scope values like ‘window.location.pathname’ aren’t valid dependencies because mutating them doesn’t re-render the component react-hooks/exhaustive-deps
9:31:28 AM:
9:31:28 AM: “build.command” failed
9:31:28 AM: ────────────────────────────────────────────────────────────────
9:31:28 AM:
9:31:28 AM: Error message
9:31:28 AM: Command failed with exit code 1: npm run build (Search results for '"non-zero exit code: 1"' - Netlify Support Forums)
9:31:28 AM:
9:31:28 AM: Error location
9:31:28 AM: In Build command from Netlify app:
9:31:28 AM: npm run build
9:31:28 AM:
9:31:28 AM: Resolved config
9:31:28 AM: build:
9:31:28 AM: command: npm run build
9:31:28 AM: commandOrigin: ui
9:31:28 AM: publish: /opt/build/repo/build
9:31:28 AM: publishOrigin: ui
9:31:29 AM: Failed during stage ‘building site’: Build script returned non-zero exit code: 2 (Search results for '"non-zero exit code: 2"' - Netlify Support Forums)
9:31:29 AM: Caching artifacts
9:31:29 AM: Started saving node modules
9:31:29 AM: Finished saving node modules
9:31:29 AM: Started saving build plugins
9:31:29 AM: Finished saving build plugins
9:31:29 AM: Started saving pip cache
9:31:29 AM: Finished saving pip cache
9:31:29 AM: Started saving emacs cask dependencies
9:31:29 AM: Finished saving emacs cask dependencies
9:31:29 AM: Started saving maven dependencies
9:31:29 AM: Finished saving maven dependencies
9:31:29 AM: Started saving boot dependencies
9:31:29 AM: Finished saving boot dependencies
9:31:29 AM: Started saving rust rustup cache
9:31:29 AM: Finished saving rust rustup cache
9:31:29 AM: Started saving go dependencies
9:31:29 AM: Finished saving go dependencies
9:31:29 AM: Build failed due to a user error: Build script returned non-zero exit code: 2
9:31:29 AM: Failing build: Failed to build site
9:31:29 AM: Finished processing build request in 31.514s
10:53:13 AM: [ERROR] Deploy logs are currently unavailable. We are working on resolving the issue.
