Hi,
I’m using the generated eleventy-edge function with an extra cookie added and the filter changed:
import { EleventyEdge } from "eleventy:edge";
import precompiledAppData from "./_generated/eleventy-edge-app-data.js";
export default async (request, context) => {
try {
console.log("Eleventy Edge function running");
let edge = new EleventyEdge("edge", {
request,
context,
precompiled: precompiledAppData,
// default is [], add more keys to opt-in e.g. ["appearance", "username"]
cookies: ["bv-cookie-policy"],
edge.config((eleventyConfig) => {
// Add some custom Edge-specific configuration
// e.g. Fancier json output
eleventyConfig.addFilter("json", (string) => JSON.parse(string));
return await edge.handleResponse();
} catch (e) {
console.log("ERROR", { e });
return context.next(e);
This is being used to decide whether a cookie banner is shown or not:
{% edge %}
{% set cookiePolicy = eleventy.edge.cookies['bv-cookie-policy'] %}
{% if not cookiePolicy %}
<div id="cookie-banner">
<div class="container">
<h2>Let us know you agree to cookies</h2>
<p>We use some essential cookies to make this website work. We'd like to set additional cookies to give you the best online experience.</p>
<div><button type="button" data-button="accept-cookies">Accept all cookies</button></div>
<div><a href="/manage-cookies" class="btn">Manage cookies</a></div>
</div>
</div>
{% endif %}
{% endedge %}
and this is my netlify.toml (there is another Netlify function in there that handles site search, this is working fine)
[build]
command = "npm run prod"
publish = "dist"
[[headers]]
for = "/*"
[headers.values]
X-Frame-Options = "DENY"
X-XSS-Protection = "1; mode=block"
X-Content-Type-Options = "nosniff"
Referrer-Policy = "same-origin"
Permissions-Policy = "microphone=(self), camera=(self)"
Content-Security-Policy = "upgrade-insecure-requests;"
[[edge_functions]]
function = "site-search"
path = "/search"
[[edge_functions]]
path = "/search/"
[[edge_functions]]
function = "eleventy-edge"
path = "/*"
If I run netlify dev locally and the cookie I’m looking for doesn’t exist then the cookie banner content will show. However when I deploy this to an actual Netlify server nothing shows at all. The function is running as I can see the console log in the Netlify edge function log.
Package versions:
“@11ty/eleventy”: “^v2.0.0-canary.7”
“@netlify/functions”: “^1.0.0”
Am I doing anything wrong here?
Cheers
Mark
