Hello there!
Completely understand Edge Functions are still new, though this issue seems less to do with an edge function and more DNS related.
Two sites, with identical HTML/CSS and Lambda/Edge Functions, both created and deployed using Netlify CLI
On both sites everything works correctly: press a button; see a response: Hello World! or Hello from the Edge!
The issue appears when using via the custom domain.
coelmay-com.netlify.app
:coelmay.com
; andcoelmay-org.netlify.app
:coelmay.org
; and
For both custom domains the lambda function works.
In the case of coelmay.com
, the Edge Function works, but for coelmay.org
it does not: 404 Not Found is returned.
Using the getSite
API endpoint it appears all site configuration (other than name, ID, et.al.) is the same.
The only difference (I know of) between the two is the DNS. coelmay.com
it is configured externally (Cloudflare; unproxied), with A
and CNAME
, and coelmay.org
is configured in Netlify DNS.
Is this the expected behaviour? A bug? Or me?
