- netlify site name: subtle-lolly-b23fec
.netlify.app (but it doesn't work now cause building has failed)
I am experiencing a consistent build failure during the “Edge Functions bundling” stage when deploying a Qwik City project to Netlify (i just tried building a brand new hello-world project and the result is the same). The build works perfectly on my local machine, but fails on Netlify CI with an ENOENT error looking for a temporary path that seems to be related to Qwik’s `qwik-city-not-found-paths.js` modules.
8:09:11 PM: Packaging Edge Functions from .netlify/edge-functions directory:
8:09:11 PM: - entry.netlify-edge
8:09:11 PM: node:internal/process/promises:394
8:09:11 PM: triggerUncaughtException(err, true /* fromPromise */);
8:09:11 PM: ^
8:09:11 PM: [Error: ENOENT: no such file or directory, stat '/tmp/tmp-2269-6qAdCcbGEFml/qwik-city-not-found-paths.js'] {
8:09:11 PM: errno: -2,
8:09:11 PM: code: 'ENOENT',
8:09:11 PM: syscall: 'stat',
8:09:11 PM: path: '/tmp/tmp-2269-6qAdCcbGEFml/qwik-city-not-found-paths.js'
8:09:11 PM: }
Environment:
Framework: Qwik City v1.19.2
Vite Version: v7.2.6
Node Version: v22.22.1 (Netlify Build Environment)
Adapter:
@builder.io/qwik-city/adapters/netlify-edge/vite
- During the Qwik build process, a virtual module
@qwik-city-not-found-pathsis generated. - When the Netlify Edge Bundler starts packaging
entry.netlify-edge, it attempts tostatthis file. However, since the build process has already finished or the bundler is running in a different context, the file in/tmpis missing, leading to theENOENTerror.
I’ve also tried:
Upgraded all dependencies to the latest versions (Qwik 1.19.2, Vite 7 (as qwik doesnt support vite 8 yet), @netlifynetlify/edge-functions 2.0.0 to 3.0.5).
Cleared build cache and redeployed.
Local builds succeed without issues but still the same error on Netlify Edge Functions build
I’ve put the full log on here: 11:36:34 AM: Netlify Build 11: - Pastebin.com
How can I resolve this ENOENT error?
