Hello everyone I am new here on the platform and already have faced to a problem
When I try to deploy a site using drag and drop(I mean my create react app build folder) I constantly get an error
It might be a temporary problem or might be some extensions. Try changing browser or device. If that does not work, it would be great if you can share the folder for others to diagnose.
Thank you for your responses
This issue slipped out of my mind because I didn’t have to use Netlify until today when I tried drag and drop from different browsers but still get the same error. My index.html file is at the top level inside the build folder (I don’t use zip archive)
Ooh sorry to bother you I’ve just fixed the problem
It’s my Linux OS related problem, specifically uploading files from non-root HDD
Still appreciate your support <3
