Gulp-responsive does not work with Netlify.
I can see it in DeployLog, but I can’t access it.
Is Gulp-responsive not working on Netlify?
DeployLog
11:28:46 AM: [02:28:46]
11:28:46 AM: gulp-responsive: IMGP4000.jpg -> IMGP4000-500-tmb.jpeg
On WebSite
https://2001y.me/img/IMGP4000-500-tmb.jpeg
ALL DeployLog
11:27:57 AM: Build ready to start
11:27:58 AM: build-image version: 9e0f207a27642d0115b1ca97cd5e8cebbe492f63
11:27:58 AM: build-image tag: v3.3.2
11:27:58 AM: buildbot version: 8727aab446158e7b8c8ad2e96fe74b0154505a4e
11:27:59 AM: Fetching cached dependencies
11:27:59 AM: Starting to download cache of 413.4MB
11:28:01 AM: Finished downloading cache in 2.119917249s
11:28:01 AM: Starting to extract cache
11:28:12 AM: Finished extracting cache in 10.82743151s
11:28:12 AM: Finished fetching cache in 13.092456473s
11:28:12 AM: Starting to prepare the repo for build
11:28:12 AM: Netlify Large Media is enabled, running git commands with GIT_LFS_SKIP_SMUDGE=1
11:28:12 AM: Preparing Git Reference refs/heads/master
11:28:18 AM: Starting build script
11:28:18 AM: Installing dependencies
11:28:18 AM: Started restoring cached node version
11:28:21 AM: Finished restoring cached node version
11:28:22 AM: v8.16.2 is already installed.
11:28:22 AM: Now using node v8.16.2 (npm v6.4.1)
11:28:23 AM: Attempting ruby version 2.3.6, read from environment
11:28:23 AM: Started restoring cached ruby version
11:28:23 AM: Finished restoring cached ruby version
11:28:25 AM: Using ruby version 2.3.6
11:28:32 AM: Successfully installed bundler-2.0.2
11:28:32 AM: Parsing documentation for bundler-2.0.2
11:28:32 AM: Installing ri documentation for bundler-2.0.2
11:28:32 AM: Done installing documentation for bundler after 5 seconds
11:28:32 AM: 1 gem installed
11:28:32 AM: Using PHP version 5.6
11:28:32 AM: Started restoring cached node modules
11:28:32 AM: Finished restoring cached node modules
11:28:32 AM: Installing Hugo 0.55.6
11:28:33 AM: Hugo Static Site Generator v0.55.6-A5D4C82D2/extended linux/amd64 BuildDate: 2019-05-18T08:08:34Z
11:28:33 AM: Started restoring cached go cache
11:28:34 AM: Finished restoring cached go cache
11:28:34 AM: Installing Go version 1.10
11:28:34 AM: unset GOOS;
11:28:34 AM: unset GOARCH;
11:28:34 AM: export GOROOT='/opt/buildhome/.gimme_cache/versions/go1.10.linux.amd64';
11:28:34 AM: export PATH="/opt/buildhome/.gimme_cache/versions/go1.10.linux.amd64/bin:${PATH}";
11:28:34 AM: go version >&2;
11:28:34 AM: export GIMME_ENV='/opt/buildhome/.gimme_cache/env/go1.10.linux.amd64.env';
11:28:34 AM: go version go1.10 linux/amd64
11:28:34 AM: Installing missing commands
11:28:34 AM: Verify run directory
11:28:34 AM: Executing user command: hugo --minify && gulp html img
11:28:34 AM: Building sites …
11:28:35 AM: WARN 2019/10/12 02:28:35 Page's .URL is deprecated and will be removed in a future release. Use .Permalink or .RelPermalink. If what you want is the front matter URL value, use .Params.url.
11:28:35 AM: |
11:28:35 AM: EN
11:28:35 AM: +------------------+----+
11:28:35 AM: Pages | 26
11:28:35 AM: Paginator pages | 0
11:28:35 AM: Non-page files
11:28:35 AM: | 0
11:28:35 AM: Static files | 68
11:28:35 AM: Processed images | 0
11:28:35 AM: Aliases | 7
11:28:35 AM: Sitemaps | 1
11:28:35 AM: Cleaned | 0
11:28:35 AM: Total in 620 ms
11:28:36 AM: [02:28:36]
11:28:36 AM: Using gulpfile /opt/build/repo/gulpfile.js
11:28:36 AM: Starting 'html'...
11:28:36 AM: Starting 'img'...
11:28:36 AM: Finished 'html' after 86 ms
11:28:37 AM: [02:28:37]
11:28:37 AM: gulp-responsive: hello-tmb.jpg -> hello-tmb-700.jpeg
11:28:37 AM: [02:28:37] gulp-responsive: hello-tmb.jpg -> hello-tmb-700.webp
11:28:37 AM: gulp-responsive: hello-tmb.jpg -> hello-tmb.jpeg
11:28:37 AM: [02:28:37] gulp-responsive: hello-tmb.jpg -> hello-tmb-100.jpeg
11:28:37 AM: gulp-responsive: hello-tmb.jpg -> hello-tmb-100.webp
11:28:38 AM: [02:28:38]
11:28:38 AM: gulp-responsive: hello-tmb.jpg -> hello-tmb-500-tmb.jpeg
11:28:38 AM: gulp-responsive: hello-tmb.jpg -> hello-tmb-500-tmb.webp
11:28:38 AM: gulp-responsive: hello-tmb.jpg -> hello-tmb.webp
11:28:38 AM: gulp-responsive: aa.jpg -> aa-100.webp
11:28:38 AM: gulp-responsive: aa.jpg -> aa.jpeg
11:28:38 AM: [02:28:38] gulp-responsive: aa.jpg -> aa-700.jpeg
11:28:38 AM: [02:28:38] gulp-responsive: aa.jpg -> aa-700.webp
11:28:39 AM: [02:28:39]
11:28:39 AM: gulp-responsive: aa.jpg -> aa-500-tmb.jpeg
11:28:39 AM: gulp-responsive: aa.jpg -> aa-100.jpeg
11:28:39 AM: gulp-responsive: aa.jpg -> aa-500-tmb.webp
11:28:39 AM: gulp-responsive: aa.jpg -> aa.webp
11:28:43 AM: [02:28:43] gulp-imagemin: Minified 3 images (saved 2.05 MB - 50.2%)
11:28:44 AM: [02:28:44] gulp-responsive: IMGP4000.jpg -> IMGP4000-700.jpeg
11:28:44 AM: [02:28:44] gulp-responsive: IMGP4000.jpg -> IMGP4000-700.webp
11:28:45 AM: [02:28:45]
11:28:45 AM: gulp-responsive: IMGP4000.jpg -> IMGP4000-100.webp
11:28:45 AM: gulp-responsive: IMGP4000.jpg -> IMGP4000-100.jpeg
11:28:46 AM: gulp-responsive: IMGP4000.jpg -> IMGP4000.jpeg
11:28:46 AM: [02:28:46] gulp-responsive: IMGP4000.jpg -> IMGP4000-500-tmb.webp
11:28:48 AM: [02:28:48] gulp-responsive: IMGP4000.jpg -> IMGP4000.webp
11:28:48 AM: gulp-responsive: Created 24 images (matched 3 of 3 images)
11:28:48 AM: Finished 'img' after 12 s
11:28:48 AM: Skipping functions preparation step: no functions directory set
11:28:48 AM: Caching artifacts
11:28:48 AM: Started saving node modules
11:28:48 AM: Finished saving node modules
11:28:48 AM: Started saving pip cache
11:28:49 AM: Finished saving pip cache
11:28:49 AM: Started saving emacs cask dependencies
11:28:49 AM: Finished saving emacs cask dependencies
11:28:49 AM: Started saving maven dependencies
11:28:49 AM: Finished saving maven dependencies
11:28:49 AM: Started saving boot dependencies
11:28:49 AM: Finished saving boot dependencies
11:28:49 AM: Started saving go dependencies
11:28:50 AM: Finished saving go dependencies
11:28:50 AM: Build script success
11:28:50 AM: Starting to deploy site from 'public'
11:28:50 AM: Creating deploy tree
11:28:50 AM: 7 new files to upload
11:28:50 AM: 0 new functions to upload
11:28:51 AM: Starting post processing
11:28:52 AM: Post processing done
11:28:52 AM: Site is live
11:29:52 AM: Finished processing build request in 1m53.963015981s
