Deploy issue Build command failed code 254
Hello , i am robj1851 have an issue with the deploy of my site .
I am still getting the
“build.command” failed
Command failed with exit code 254: CI= npm run build (Search results for '"non-zero exit code: 254"' - Netlify Support Forums)
This are the deploy details:
Thanks in advance for the help
2:12:58 PM: Build ready to start
2:13:00 PM: build-image version: 195fbe127e5c374d9c4758652cb62e3b8936a395 (focal)
2:13:00 PM: build-image tag: v4.6.0
2:13:00 PM: buildbot version: 4ac77ee15240cafa5a14a04b6ca18d8959fa98e6
2:13:00 PM: Fetching cached dependencies
2:13:00 PM: Failed to fetch cache, continuing with build
2:13:00 PM: Starting to prepare the repo for build
2:13:01 PM: No cached dependencies found. Cloning fresh repo
2:13:01 PM: git clone GitHub - robjchacon/SuitTurtlesClub
2:13:01 PM: Preparing Git Reference refs/heads/main
2:13:01 PM: Parsing package.json dependencies
2:13:02 PM: Different build dir detected, going to use the one specified in the Netlify configuration file: ‘’ versus ‘/’ in the Netlify UI
2:13:02 PM: Starting build script
2:13:02 PM: Installing dependencies
2:13:02 PM: Python version set to 2.7
2:13:03 PM: Downloading and installing node v16.14.2…
2:13:03 PM: Downloading https://nodejs.org/dist/v16.14.2/node-v16.14.2-linux-x64.tar.xz
2:13:03 PM: Computing checksum with sha256sum
2:13:04 PM: Checksums matched!
2:13:06 PM: Now using node v16.14.2 (npm v8.5.0)
2:13:06 PM: Started restoring cached build plugins
2:13:06 PM: Finished restoring cached build plugins
2:13:06 PM: Attempting ruby version 2.7.2, read from environment
2:13:08 PM: Using ruby version 2.7.2
2:13:08 PM: Using PHP version 8.0
2:13:08 PM: Started restoring cached go cache
2:13:08 PM: Finished restoring cached go cache
2:13:08 PM: go version go1.16.5 linux/amd64
2:13:08 PM: Installing missing commands
2:13:08 PM: Verify run directory
2:13:10 PM: ​
2:13:10 PM: ────────────────────────────────────────────────────────────────
2:13:10 PM: Netlify Build
2:13:10 PM: ​
2:13:10 PM: ❯ Version
2:13:10 PM: @netlify/build 26.5.0
2:13:10 PM: ​
2:13:10 PM: ❯ Flags
2:13:10 PM: baseRelDir: true
2:13:10 PM: buildId: 6238c02a0f488212d67daecc
2:13:10 PM: deployId: 6238c02a0f488212d67daece
2:13:10 PM: ​
2:13:10 PM: ❯ Current directory
2:13:10 PM: /opt/build/repo
2:13:10 PM: ​
2:13:10 PM: ❯ Config file
2:13:10 PM: No config file was defined: using default values.
2:13:10 PM: ​
2:13:10 PM: ❯ Context
2:13:10 PM: production
2:13:10 PM: ​
2:13:10 PM: 1. Build command from Netlify app
2:13:10 PM: ​
2:13:10 PM: $ CI= npm run build
2:13:10 PM: npm ERR! code ENOENT
2:13:10 PM: npm ERR! syscall open
2:13:10 PM: npm ERR! path /opt/build/repo/package.json
2:13:10 PM: npm ERR! errno -2
2:13:10 PM: npm ERR! enoent ENOENT: no such file or directory, open ‘/opt/build/repo/package.json’
2:13:10 PM: npm ERR! enoent This is related to npm not being able to find a file.
2:13:10 PM: npm ERR! A complete log of this run can be found in:
2:13:10 PM: npm ERR! /opt/buildhome/.npm/_logs/2022-03-21T18_13_10_251Z-debug-0.log
2:13:10 PM: ​
2:13:10 PM: “build.command” failed
2:13:10 PM: ​
2:13:10 PM: Error message
2:13:10 PM: Command failed with exit code 254: CI= npm run build (Search results for '"non-zero exit code: 254"' - Netlify Support Forums)
2:13:10 PM: ​
2:13:10 PM: Error location
2:13:10 PM: In Build command from Netlify app:
2:13:10 PM: CI= npm run build
2:13:10 PM: ​
2:13:10 PM: Resolved config
2:13:10 PM: build:
2:13:10 PM: base: /opt/build/repo
2:13:10 PM: command: CI= npm run build
2:13:10 PM: commandOrigin: ui
2:13:10 PM: publish: /opt/build/repo/build
2:13:10 PM: publishOrigin: ui
2:13:10 PM: Caching artifacts
2:13:10 PM: Started saving build plugins
2:13:10 PM: Finished saving build plugins
2:13:10 PM: Started saving pip cache
2:13:10 PM: Finished saving pip cache
2:13:10 PM: Started saving emacs cask dependencies
2:13:10 PM: Finished saving emacs cask dependencies
2:13:10 PM: Started saving maven dependencies
2:13:10 PM: Finished saving maven dependencies
2:13:12 PM: Creating deploy upload records
2:13:10 PM: Started saving boot dependencies
2:13:10 PM: Finished saving boot dependencies
2:13:10 PM: Started saving rust rustup cache
2:13:10 PM: Finished saving rust rustup cache
2:13:10 PM: Started saving go dependencies
2:13:10 PM: Finished saving go dependencies
2:13:12 PM: Failed during stage ‘building site’: Build script returned non-zero exit code: 2 (Search results for '"non-zero exit code: 2"' - Netlify Support Forums)
2:13:12 PM: Build failed due to a user error: Build script returned non-zero exit code: 2
2:13:12 PM: Failing build: Failed to build site
2:13:12 PM: Finished processing build request in 12.336408482s
Hiya, sorry you are having trouble with your build.
This Support Guide contains a ton of useful debugging tips that can likely help you solve your problem :slight_smile: Additionally, this Support Guide houses all of our resources for debugging build and deploy issues.
We also recommend trying to search the forums with the build error you encountered - it’s likely your question was already asked by someone else!
If you are still having problems, please provide as much information as you can on what you have already tried, what your build settings are, your package.json, etc. Thanks!
