Deploy Failed - fatal: Could not read from remote repository
Hi Everyone,
I try to publish my angular project. But the deploy failed…
1st problem : There is many WARN messages like :
npm WARN tar ENOENT: no such file or directory, open ‘/opt/build/repo/node_modules/.staging/quagga-ab2f7e21/bower.json’
2nd problem : The deploy failed because I use a remote repository package. There is a message to tell “fatal: Could not read from remote repository.”
I need some Help, Thanks a lot for your response.
2:09:26 PM: Build ready to start
2:09:29 PM: build-image version: 3fa6e2800752667ac56af498951f923e208f7404 (xenial)
2:09:29 PM: build-image tag: v3.10.3
2:09:29 PM: buildbot version: 895c4040e8502673de1e642dd5f16dde00e3964c
2:09:29 PM: Building without cache
2:09:29 PM: Starting to prepare the repo for build
2:09:30 PM: No cached dependencies found. Cloning fresh repo
2:09:30 PM: git clone https://github.com/kabouchef/stockmanager-frontend
2:09:34 PM: Preparing Git Reference refs/heads/master
2:09:35 PM: Parsing package.json dependencies
2:09:36 PM: Starting build script
2:09:36 PM: Installing dependencies
2:09:36 PM: Python version set to 2.7
2:09:37 PM: Downloading and installing node v10.24.1...
2:09:38 PM: Downloading https://nodejs.org/dist/v10.24.1/node-v10.24.1-linux-x64.tar.xz...
2:09:38 PM: Computing checksum with sha256sum
2:09:38 PM: Checksums matched!
2:09:41 PM: Now using node v10.24.1 (npm v6.14.12)
2:09:41 PM: Started restoring cached build plugins
2:09:41 PM: Finished restoring cached build plugins
2:09:41 PM: Attempting ruby version 2.7.2, read from environment
2:09:43 PM: Using ruby version 2.7.2
2:09:43 PM: Using PHP version 5.6
2:09:43 PM: Started restoring cached node modules
2:09:43 PM: Finished restoring cached node modules
2:09:44 PM: Installing NPM modules using NPM version 6.14.12
2:09:57 PM: npm WARN read-shrinkwrap This version of npm is compatible with lockfileVersion@1, but package-lock.json was generated for lockfileVersion@2. I'll try to do my best with it!npm WARN tar ENOENT: no such file or directory, lstat '/opt/build/repo/node_modules/.staging/ngx-qrcode2-ff0f8329/esm5/lib'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/ngx-qrcode2-ff0f8329/esm5/ngx-qrcode2.js'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/ngx-barcode-scanner-4aea23d4/bundles/ngx-barcode-scanner.umd.min.js.map'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/ngx-qrcode2-ff0f8329/esm5/public-api.js'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/ngx-qrcode2-ff0f8329/fesm2015/ngx-qrcode2.js'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/ngx-qrcode2-ff0f8329/fesm2015/ngx-qrcode2.js.map'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/ng-inline-svg-0510e5a6/lib_commonjs/index.d.ts'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/ng-inline-svg-0510e5a6/lib_commonjs/inline-svg.component.d.ts'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/chart.js-6d3ed11a/dist/Chart.bundle.min.js'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/ngx-qrcode2-ff0f8329/fesm5/ngx-qrcode2.js'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/ngx-gravatar-44a40062/esm5/public-api.js'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/ng-inline-svg-0510e5a6/lib_commonjs/inline-svg.config.d.ts'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/angular-bootstrap-md-a65591a6/public_api.d.ts'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/ngx-qrcode2-ff0f8329/fesm5/ngx-qrcode2.js.map'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/protractor-ff660472/built/frameworks/debugprint.js'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/ngx-avatar-0ee4a2ed/esm5/lib/sources/github.js'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/ng-inline-svg-0510e5a6/lib_commonjs/inline-svg.directive.d.ts'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/angular-bootstrap-md-a65591a6/README.md'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/protractor-ff660472/built/driverProviders/direct.js'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/angularx-social-login-c3bb10ad/esm2015/providers/vk-login-provider.js'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/@angular/platform-browser-dynamic-f1edbec7/esm2015/src/compiler_reflector.js'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/ngx-qrcode2-ff0f8329/lib/qrcode.component.d.ts'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/ng2-charts-419c4ec3/esm2015/public_api.js'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/ngx-gravatar-44a40062/fesm2015/ngx-gravatar.js.map'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/ngx-avatar-0ee4a2ed/esm5/lib/sources/google.js'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/ng-inline-svg-0510e5a6/lib_commonjs/inline-svg.module.d.ts'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/ngx-qrcode2-ff0f8329/lib/qrcode.constants.d.ts'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/protractor-ff660472/built/driverProviders/driverProvider.js'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/ng2-charts-419c4ec3/esm2015/lib/theme.service.js'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/ng-inline-svg-0510e5a6/lib_commonjs/inline-svg.service.d.ts'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/@angular/service-worker-b7b8c3dc/esm5/config/src/generator.js'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/ngx-qrcode2-ff0f8329/lib/qrcode.module.d.ts'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/ng-inline-svg-0510e5a6/lib_commonjs/svg-cache.service.d.ts'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/@angular/forms-60b87f4a/esm2015/src/directives/control_container.js'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/ngx-qrcode2-ff0f8329/lib/qrcode.types.d.ts'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/ngx-avatar-0ee4a2ed/esm5/lib/sources/gravatar.js'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/ng-inline-svg-0510e5a6/lib_commonjs/svg-util.d.ts'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/ngx-qrcode2-ff0f8329/esm2015/lib/qrcode.component.js'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, lstat '/opt/build/repo/node_modules/.staging/parse5-78a51d0d/lib/extensions'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/@angular/forms-60b87f4a/esm2015/src/directives/control_value_accessor.js'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/ngx-avatar-0ee4a2ed/esm5/lib/sources/initials.js'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/typescript-1d5bbf27/lib/diagnosticMessages.generated.json'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/parse5-78a51d0d/lib/parser/open-element-stack.js'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/typescript-48bc870c/lib/diagnosticMessages.generated.json'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/ng2-charts-419c4ec3/fesm2015/ng2-charts.js.map'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/parse5-78a51d0d/lib/extensions/error-reporting/parser-mixin.js'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/@angular/platform-browser-088f8539/esm2015/animations/src/animations.js'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/protractor-ff660472/bin/elementexplorer.js'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/ngx-avatar-0ee4a2ed/esm5/lib/sources/instagram.js'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/@ngx-translate/core-4af196ca/esm2015/lib/translate.store.js'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/@angular/forms-60b87f4a/esm2015/src/directives/default_value_accessor.js'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/@ngx-translate/core-4af196ca/esm2015/lib/util.js'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/parse5-78a51d0d/lib/extensions/error-reporting/preprocessor-mixin.js'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/protractor-ff660472/example/example_spec.js'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/@angular/router-fd5e74a9/esm5/src/operators/apply_redirects.js'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/@angular/platform-browser-088f8539/esm5/animations/src/animations.js'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/parse5-78a51d0d/lib/tokenizer/preprocessor.js'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/parse5-78a51d0d/lib/extensions/error-reporting/tokenizer-mixin.js'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/ngx-toastr-edca3beb/fesm2015/ngx-toastr.js.map'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/bootstrap-3419c89a/dist/css/bootstrap.min.css'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/@auth0/angular-jwt-90907ceb/fesm2015/auth0-angular-jwt.js.map'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/@angular/router-fd5e74a9/esm5/src/operators/check_guards.js'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/parse5-78a51d0d/lib/common/unicode.js'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/parse5-78a51d0d/package.json'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/parse5-78a51d0d/README.md'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/protractor-ff660472/built/frameworks/explorer.js'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, lstat '/opt/build/repo/node_modules/.staging/@angular/router-fd5e74a9/esm2015/src/utils'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/font-awesome-5a9b7307/fonts/fontawesome-webfont.eot'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/protractor-ff660472/built/driverProviders/hosted.js'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/protractor-ff660472/built/driverProviders/index.js'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/canvasjs-ff62039c/dist/canvasjs.3.js'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/@angular/forms-60b87f4a/esm2015/src/directives/error_examples.js'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/@angular/forms-60b87f4a/esm5/src/directives/error_examples.js'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/protractor-ff660472/example/angular_material/input_spec.js'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/@angular/router-fd5e74a9/esm2015/src/config.js'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/protractor-ff660472/built/frameworks/jasmine.js'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/protractor-ff660472/built/driverProviders/kobiton.js'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/protractor-ff660472/built/driverProviders/local.js'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, lstat '/opt/build/repo/node_modules/.staging/@angular/forms-60b87f4a/esm2015/src/directives/reactive_directives'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, lstat '/opt/build/repo/node_modules/.staging/@angular/forms-60b87f4a/esm5/src/directives/reactive_directives'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/tslint-992fd035/lib/configs/all.d.ts'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/protractor-ff660472/example/angular_material/mat_paginator_spec.js'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/ngx-avatar-0ee4a2ed/esm5/lib/sources/skype.js'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/protractor-ff660472/built/frameworks/mocha.js'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/ngx-avatar-0ee4a2ed/esm5/lib/sources/source.creator.js'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/protractor-ff660472/built/driverProviders/mock.js'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/ngx-avatar-0ee4a2ed/esm5/lib/sources/source.factory.js'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/ngx-avatar-0ee4a2ed/esm5/lib/sources/source.js'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/ngx-avatar-0ee4a2ed/esm5/lib/sources/twitter.js'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/ngx-avatar-0ee4a2ed/esm5/lib/sources/value.js'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/protractor-ff660472/built/driverProviders/sauce.js'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/protractor-ff660472/built/frameworks/setupAfterEach.js'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/ngx-avatar-0ee4a2ed/esm5/lib/sources/vkontakte.js'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/protractor-ff660472/built/driverProviders/testObject.js'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/protractor-ff660472/built/driverProviders/useExistingWebDriver.js'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/protractor-ff660472/built/debugger/clients/wddebugger.js'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/@angular/forms-60b87f4a/esm2015/src/directives/form_interface.js'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/@angular/forms-60b87f4a/esm5/src/directives/form_interface.js'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/quagga-ab2f7e21/.eslintrc'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/quagga-ab2f7e21/bower.json'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/@angular/forms-60b87f4a/esm5/src/form_providers.js'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/@babel/parser-4551b83e/CHANGELOG.md'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/@angular/forms-60b87f4a/esm5/src/forms.js'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/protractor-ff660472/exampleTypescript/asyncAwait/README.md'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/protractor-ff660472/built/driverProviders/attachSession.d.ts'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/protractor-ff660472/built/bpRunner.d.ts'
2:09:57 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/protractor-ff660472/built/browser.d.ts'
2:09:58 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/@angular/forms-60b87f4a/esm2015/index.js'
2:09:58 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/@angular/forms-60b87f4a/esm5/index.js'
2:09:58 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/@angular/forms-60b87f4a/esm2015/src/model.js'
2:09:58 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/@angular/platform-browser-088f8539/esm2015/animations/index.js'
2:09:58 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/@angular/platform-browser-088f8539/esm2015/testing/src/matchers.js'
2:09:58 PM: npm WARN tar ENOENT: no such file or directory, lstat '/opt/build/repo/node_modules/.staging/pdfmake-aba22e1a/src/browser-extensions'
2:09:58 PM: npm WARN tar ENOENT: no such file or directory, open '/opt/build/repo/node_modules/.staging/pdfmake-aba22e1a/build/pdfmake.min.js'
2:09:59 PM: npm ERR! Error while executing:
2:09:59 PM: npm ERR! /usr/bin/git ls-remote -h -t ssh://git@github.com/ericblade/quagga2.git
2:09:59 PM: npm ERR! Host key verification failed.
2:09:59 PM: npm ERR! fatal: Could not read from remote repository.
2:09:59 PM: npm ERR! Please make sure you have the correct access rights
2:09:59 PM: npm ERR! and the repository exists.
2:09:59 PM: npm ERR! exited with error code: 128
2:10:02 PM: npm ERR! A complete log of this run can be found in:
2:10:02 PM: npm ERR!     /opt/buildhome/.npm/_logs/2022-01-24T13_09_59_853Z-debug.log
2:10:02 PM: Error during NPM install
2:10:02 PM: Build was terminated: Build script returned non-zero exit code: 1
2:10:02 PM: Creating deploy upload records
2:10:02 PM: Failing build: Failed to build site
2:10:02 PM: Failed during stage 'building site': Build script returned non-zero exit code: 1
2:10:02 PM: Finished processing build request in 33.111973302s
Hi @MisterFarouk
I suggest the following Support Guide should offer some guidance in this instance
@colemay Thanks a Lot !
The post has solved my problem :slight_smile:
There no error by replacing http://git@github.com by https://github.com in my package-lock.json
Have a nice day !
