12:35:47 PM: Deploy did not succeed: Deploy directory ‘build’ does not exist
This error message is found in your log, this means that in the deploy settings in the Netlify UI your publish directory/build command has been set to build and Netlify can’t find a directory named build in your project. I would just leave these settings blank unless you need to change them to abide by a certain SSG’s configuration
Hello,
When I tried the build command as npm run build it failed but when I tried it with CI= npm run build it worked, also I used the publish directory: /client/public it is published but the page doesnot show up, nothing when clicked on the link.
Hi there! Thanks for your interest in Netlify CMS. Looks like you posted your question a little while ago, but that you haven’t received a solution yet. Here’s where you might get more help:
netlifycms.org - the site houses our extensive documentation that likely contains helpful information to get you back on track.
netlify cms slack - join our friendly slack channel and chat with other cms pros to get the help you need.
GitHub Issues - think you’ve found a bug, or would like to make a feature request? Make your voice heard here. Netlify CMS is open source - PRs and other contributions are also welcome!
Stack Overflow Check StackOverflow for questions tagged “Netlify CMS” if you don’t get an answer in the Slack or the GH issues. StackOverflow reaches a worldwide audience of knowledgeable people.
Your question will be left open here for anyone to comment - but we encourage you to check out the above resources if you are still looking for a solution!
