Site not deploying due to unclear build failure
- https://velero-k.netlify.app/
- Build problems:
2:51:14 PM: build-image version: 0143b4617dd9b5b3faed2aefa29c54a846e69aae (focal)
2:51:14 PM: buildbot version: 0143b4617dd9b5b3faed2aefa29c54a846e69aae
2:51:14 PM: Fetching cached dependencies
2:51:14 PM: Failed to fetch cache, continuing with build
2:51:14 PM: Starting to prepare the repo for build
2:51:14 PM: No cached dependencies found. Cloning fresh repo
2:51:14 PM: git clone --filter=blob:none https://github.com/kaovilai/velero
2:51:14 PM: Preparing Git Reference refs/heads/main
2:51:16 PM: Custom build path detected. Proceeding with the specified path: "site"
2:51:16 PM: Custom publish path detected. Proceeding with the specified path: "site/site/public"
2:51:16 PM: Custom build command detected. Proceeding with the specified command: "hugo --gc --minify"
2:51:17 PM: Starting to install dependencies
2:51:17 PM: Python version set to 3.8
2:51:17 PM: Attempting Ruby version 2.7.2, read from environment
2:51:17 PM: Using Ruby version 2.7.2
2:51:18 PM: Started restoring cached go cache
2:51:18 PM: Finished restoring cached go cache
2:51:18 PM: go version go1.19.13 linux/amd64
2:51:18 PM: Using PHP version 8.0
2:51:19 PM: Installing Hugo 0.73.0
2:51:20 PM: Hugo Static Site Generator v0.73.0-428907CC/extended linux/amd64 BuildDate: 2020-06-23T16:40:09Z
2:51:21 PM: v18.18.0 is already installed.
2:51:21 PM: Now using node v18.18.0 (npm v9.8.1)
2:51:21 PM: Enabling Node.js Corepack
2:51:21 PM: Started restoring cached build plugins
2:51:21 PM: Finished restoring cached build plugins
2:51:21 PM: Install dependencies script success
2:51:21 PM: Starting build script
2:51:22 PM: Detected 1 framework(s)
2:51:22 PM: "hugo" at version "unknown"
2:51:22 PM: Section completed: initializing
2:51:24 PM:
2:51:24 PM: Netlify Build
2:51:24 PM: ────────────────────────────────────────────────────────────────
2:51:24 PM:
2:51:24 PM: ❯ Version
2:51:24 PM: @netlify/build 29.21.1
2:51:24 PM:
2:51:24 PM: ❯ Flags
2:51:24 PM: baseRelDir: true
2:51:24 PM: buildId: 65171ca08d9792130670f408
2:51:24 PM: deployId: 65171ca08d9792130670f40a
2:51:24 PM:
2:51:24 PM: ❯ Current directory
2:51:24 PM: /opt/build/repo/site
2:51:24 PM:
2:51:24 PM: ❯ Config file
2:51:24 PM: /opt/build/repo/netlify.toml
2:51:24 PM:
2:51:24 PM: ❯ Context
2:51:24 PM: production
2:51:24 PM:
2:51:24 PM: build.command from netlify.toml
2:51:24 PM:
2:51:24 PM: $ hugo --gc --minify
2:51:24 PM: Building sites … WARN 2023/09/29 18:51:24 found no layout file for "HTML" for kind "page": You should create a template file which matches Hugo Layouts Lookup Rules for this combination.
2:51:24 PM: WARN 2023/09/29 18:51:24 found no layout file for "HTML" for kind "page": You should create a template file which matches Hugo Layouts Lookup Rules for this combination.
2:51:25 PM: WARN 2023/09/29 18:51:25 found no layout file for "HTML" for kind "page": You should create a template file which matches Hugo Layouts Lookup Rules for this combination.
2:51:26 PM: WARN 2023/09/29 18:51:26 found no layout file for "HTML" for kind "page": You should create a template file which matches Hugo Layouts Lookup Rules for this combination.
2:51:26 PM: WARN 2023/09/29 18:51:26 found no layout file for "HTML" for kind "taxonomy": You should create a template file which matches Hugo Layouts Lookup Rules for this combination.
2:51:26 PM: WARN 2023/09/29 18:51:26 found no layout file for "HTML" for kind "term": You should create a template file which matches Hugo Layouts Lookup Rules for this combination.
2:51:26 PM: | EN
2:51:26 PM: -------------------+-------
2:51:26 PM: Pages | 1971
2:51:26 PM: Paginator pages | 0
2:51:26 PM: Non-page files | 150
2:51:26 PM: Static files | 70
2:51:26 PM: Processed images | 0
2:51:26 PM: Aliases | 0
2:51:26 PM: Sitemaps | 1
2:51:26 PM: Cleaned | 0
2:51:26 PM: Total in 2400 ms
2:51:26 PM:
2:51:26 PM: (build.command completed in 2.4s)
2:51:26 PM:
2:51:26 PM: Deploy site
2:51:26 PM: ────────────────────────────────────────────────────────────────
2:51:26 PM:
2:51:26 PM: Section completed: deploying
2:51:26 PM:
2:51:26 PM: Configuration error
2:51:26 PM:
2:51:26 PM: Error message
2:51:26 PM: Deploy did not succeed: Deploy directory "site/site/public" does not exist
2:51:26 PM:
2:51:26 PM: Resolved config
2:51:26 PM: build:
2:51:26 PM: base: /opt/build/repo/site
2:51:26 PM: command: hugo --gc --minify
2:51:26 PM: commandOrigin: config
2:51:26 PM: environment:
2:51:26 PM: - HUGO_VERSION
2:51:26 PM: publish: /opt/build/repo/site/site/public
2:51:26 PM: publishOrigin: config
2:51:27 PM: Caching artifacts
2:51:27 PM: Started saving build plugins
2:51:27 PM: Finished saving build plugins
2:51:27 PM: Started saving pip cache
2:51:27 PM: Finished saving pip cache
2:51:27 PM: Started saving emacs cask dependencies
2:51:27 PM: Finished saving emacs cask dependencies
2:51:27 PM: Started saving maven dependencies
2:51:27 PM: Finished saving maven dependencies
2:51:27 PM: Started saving boot dependencies
2:51:27 PM: Finished saving boot dependencies
2:51:27 PM: Started saving rust rustup cache
2:51:27 PM: Finished saving rust rustup cache
2:51:27 PM: Started saving go dependencies
2:51:27 PM: Finished saving go dependencies
2:51:28 PM: Failed during stage "building site": Build script returned non-zero exit code: 2
2:51:28 PM: Build failed due to a user error: Build script returned non-zero exit code: 2
2:51:28 PM: Failing build: Failed to build site
2:51:29 PM: Finished processing build request in 14.82s
This site is a fork of https://velero.netlify.com/ so whatever settings they have there should make it work here too but I don’t know what the settings are.
In addition, I got the site working on vercel without any fuss.
Only set site/ as root dir and HUGO_VERSION env.
