Deploy did not succeed: Deploy directory ‘dist’ does not exist
What is this dist directory? How can I solve this?
8:09:36 PM: build-image version: 5e2052dbf11f1636a7bac1839aff8991d186d620 (focal)
8:09:36 PM: buildbot version: 5e2052dbf11f1636a7bac1839aff8991d186d620
8:09:36 PM: Fetching cached dependencies
8:09:36 PM: Starting to download cache of 88.2MB
8:09:37 PM: Finished downloading cache in 1.012s
8:09:37 PM: Starting to extract cache
8:09:37 PM: Finished extracting cache in 632ms
8:09:37 PM: Finished fetching cache in 1.693s
8:09:37 PM: Starting to prepare the repo for build
8:09:38 PM: Preparing Git Reference refs/heads/main
8:09:38 PM: Parsing package.json dependencies
8:09:39 PM: Starting to install dependencies
8:09:39 PM: Python version set to 3.8
8:09:39 PM: Started restoring cached go cache
8:09:39 PM: Finished restoring cached go cache
8:09:39 PM: Installing Go version 1.19.5 (requested 1.19.5)
8:09:45 PM: go version go1.19.5 linux/amd64
8:09:45 PM: Using PHP version 8.0
8:09:45 PM: Started restoring cached Node.js version
8:09:46 PM: Finished restoring cached Node.js version
8:09:46 PM: v16.19.1 is already installed.
8:09:46 PM: Now using node v16.19.1 (npm v8.19.3)
8:09:46 PM: Enabling Node.js Corepack
8:09:46 PM: Started restoring cached build plugins
8:09:46 PM: Finished restoring cached build plugins
8:09:46 PM: Started restoring cached corepack dependencies
8:09:46 PM: Finished restoring cached corepack dependencies
8:09:46 PM: No npm workspaces detected
8:09:46 PM: Started restoring cached node modules
8:09:46 PM: Finished restoring cached node modules
8:09:47 PM: Installing npm packages using npm version 8.19.3
8:09:55 PM: added 167 packages, removed 84 packages, changed 16 packages, and audited 211 packages in 8s
8:09:55 PM: 35 packages are looking for funding
8:09:55 PM: run `npm fund` for details
8:09:55 PM: found 0 vulnerabilities
8:09:55 PM: npm packages installed
8:09:55 PM: Attempting Ruby version 2.7.2, read from environment
8:09:56 PM: Using Ruby version 2.7.2
8:09:58 PM: Install dependencies script success
8:09:58 PM: Starting build script
8:09:58 PM: Using stage install dependencies
8:09:58 PM: Detected 1 framework(s)
8:09:58 PM: "next" at version "13.2.4"
8:09:58 PM: Section completed: initializing
8:10:00 PM:
8:10:00 PM: Netlify Build
8:10:00 PM: ────────────────────────────────────────────────────────────────
8:10:00 PM:
8:10:00 PM: ❯ Version
8:10:00 PM: @netlify/build 29.7.1
8:10:00 PM:
8:10:00 PM: ❯ Flags
8:10:00 PM: baseRelDir: true
8:10:00 PM: buildId: 6422222d6c754400081b4069
8:10:00 PM: deployId: 6422222d6c754400081b406b
8:10:00 PM:
8:10:00 PM: ❯ Current directory
8:10:00 PM: /opt/build/repo
8:10:00 PM:
8:10:00 PM: ❯ Config file
8:10:00 PM: No config file was defined: using default values.
8:10:00 PM:
8:10:00 PM: ❯ Context
8:10:00 PM: production
8:10:00 PM:
8:10:00 PM: 1. Build command from Netlify app
8:10:00 PM:
8:10:00 PM: $ npm run build
8:10:00 PM: > task-app@0.1.0 build
8:10:00 PM: > next build
8:10:00 PM: warn - No build cache found. Please configure build caching for faster rebuilds. Read more: https://nextjs.org/docs/messages/no-cache
8:10:00 PM: info - Linting and checking validity of types...
8:10:02 PM: info - Creating an optimized production build...
8:10:05 PM: info - Compiled successfully
8:10:05 PM: info - Collecting page data...
8:10:10 PM: info - Generating static pages (0/3)
8:10:10 PM: info - Generating static pages (3/3)
8:10:11 PM: info - Finalizing page optimization...
8:10:11 PM: Route (pages) Size First Load JS
8:10:11 PM: ┌ ○ / 3.76 kB 77 kB
8:10:11 PM: ├ /_app 0 B 73.3 kB
8:10:11 PM: ├ ○ /404 182 B 73.4 kB
8:10:11 PM: └ λ /api/hello 0 B 73.3 kB
8:10:11 PM: + First Load JS shared by all 74.2 kB
8:10:11 PM: ├ chunks/framework-2c79e2a64abdb08b.js 45.2 kB
8:10:11 PM: ├ chunks/main-7477d36a73a3487c.js 27 kB
8:10:11 PM: ├ chunks/pages/_app-cb4d59606a29a817.js 296 B
8:10:11 PM: ├ chunks/webpack-8fa1640cc84ba8fe.js 750 B
8:10:11 PM: └ css/e956ab2bf8369065.css 908 B
8:10:11 PM: λ (Server) server-side renders at runtime (uses getInitialProps or getServerSideProps)
8:10:11 PM: ○ (Static) automatically rendered as static HTML (uses no initial props)
8:10:11 PM:
8:10:11 PM: (build.command completed in 11.1s)
8:10:11 PM:
8:10:11 PM: 2. Deploy site
8:10:11 PM: ────────────────────────────────────────────────────────────────
8:10:11 PM:
8:10:11 PM: Section completed: deploying
8:10:11 PM:
8:10:11 PM: Configuration error
8:10:11 PM:
8:10:11 PM: Error message
8:10:11 PM: Deploy did not succeed: Deploy directory 'dist' does not exist
8:10:11 PM:
8:10:11 PM: Resolved config
8:10:11 PM: build:
8:10:11 PM: command: npm run build
8:10:11 PM: commandOrigin: ui
8:10:11 PM: publish: /opt/build/repo/dist
8:10:11 PM: publishOrigin: ui
8:10:11 PM: Caching artifacts
8:10:12 PM: Failed during stage 'building site': Build script returned non-zero exit code: 2 (https://ntl.fyi/exit-code-2)
8:10:11 PM: Started saving node modules
8:10:11 PM: Finished saving node modules
8:10:11 PM: Started saving build plugins
8:10:11 PM: Finished saving build plugins
8:10:11 PM: Started saving corepack cache
8:10:11 PM: Finished saving corepack cache
8:10:11 PM: Started saving pip cache
8:10:11 PM: Finished saving pip cache
8:10:11 PM: Started saving emacs cask dependencies
8:10:11 PM: Finished saving emacs cask dependencies
8:10:11 PM: Started saving maven dependencies
8:10:11 PM: Finished saving maven dependencies
8:10:11 PM: Started saving boot dependencies
8:10:11 PM: Finished saving boot dependencies
8:10:11 PM: Started saving rust rustup cache
8:10:11 PM: Finished saving rust rustup cache
8:10:11 PM: Started saving go dependencies
8:10:11 PM: Finished saving go dependencies
8:10:12 PM: Build failed due to a user error: Build script returned non-zero exit code: 2
8:10:12 PM: Failing build: Failed to build site
8:10:12 PM: Finished processing build request in 36.797s
