9:21:12 PM: Build ready to start
9:21:14 PM: build-image version: d7b3dbfb0846505993c9a131894d1858074c90b4 (focal)
9:21:14 PM: build-image tag: v4.10.1
9:21:14 PM: buildbot version: fe6512288e75c8fa5aadaebb51ed1f96e9314fd4
9:21:14 PM: Fetching cached dependencies
9:21:14 PM: Failed to fetch cache, continuing with build
9:21:14 PM: Starting to prepare the repo for build
9:21:14 PM: No cached dependencies found. Cloning fresh repo
9:21:14 PM: git clone GitHub - TetianaStrelnikova/tetiana-strelnikova-homework-week-3-responsive
9:21:15 PM: Preparing Git Reference refs/heads/main
9:21:15 PM: Parsing package.json dependencies
9:21:16 PM: Starting build script
9:21:16 PM: Installing dependencies
9:21:16 PM: Python version set to 2.7
9:21:16 PM: v16.16.0 is already installed.
9:21:17 PM: Now using node v16.16.0 (npm v8.11.0)
9:21:17 PM: Started restoring cached build plugins
9:21:17 PM: Finished restoring cached build plugins
9:21:17 PM: Attempting ruby version 2.7.2, read from environment
9:21:17 PM: Using ruby version 2.7.2
9:21:17 PM: Using PHP version 8.0
9:21:18 PM: No npm workspaces detected
9:21:18 PM: Started restoring cached node modules
9:21:18 PM: Finished restoring cached node modules
9:21:18 PM: Installing NPM modules using NPM version 8.11.0
9:21:18 PM: npm WARN config tmp This setting is no longer used. npm stores temporary files in a special
9:21:18 PM: npm WARN config location in the cache, and they are managed by
9:21:18 PM: npm WARN config cacache
9:21:21 PM: added 78 packages, and audited 79 packages in 2s
9:21:21 PM: 1 package is looking for funding
9:21:21 PM: run npm fund
for details
9:21:21 PM: 2 moderate severity vulnerabilities
9:21:21 PM: To address all issues (including breaking changes), run:
9:21:21 PM: npm audit fix --force
9:21:21 PM: Run npm audit
for details.
9:21:21 PM: NPM modules installed
9:21:21 PM: npm WARN config tmp This setting is no longer used. npm stores temporary files in a special
9:21:21 PM: npm WARN config location in the cache, and they are managed by
9:21:21 PM: npm WARN config cacache
9:21:21 PM: Started restoring cached go cache
9:21:21 PM: Finished restoring cached go cache
9:21:21 PM: Installing Go version 1.17 (requested 1.17)
9:21:25 PM: unset GOOS;
9:21:25 PM: unset GOARCH;
9:21:25 PM: export GOROOT=‘/opt/buildhome/.gimme/versions/go1.17.linux.amd64’;
9:21:25 PM: export PATH=“/opt/buildhome/.gimme/versions/go1.17.linux.amd64/bin:${PATH}”;
9:21:25 PM: go version >&2;
9:21:25 PM: export GIMME_ENV=“/opt/buildhome/.gimme/env/go1.17.linux.amd64.env”
9:21:25 PM: go version go1.17 linux/amd64
9:21:25 PM: Installing missing commands
9:21:25 PM: Verify run directory
9:21:27 PM:
9:21:27 PM: ────────────────────────────────────────────────────────────────
9:21:27 PM: Netlify Build
9:21:27 PM:
9:21:27 PM: ❯ Version
9:21:27 PM: @netlify/build 27.9.1
9:21:27 PM:
9:21:27 PM: ❯ Flags
9:21:27 PM: baseRelDir: true
9:21:27 PM: buildId: 62f1460819d7c40008578b9b
9:21:27 PM: deployId: 62f1460819d7c40008578b9d
9:21:27 PM: systemLogFile: 3
9:21:27 PM:
9:21:27 PM: ❯ Current directory
9:21:27 PM: /opt/build/repo
9:21:27 PM:
9:21:27 PM: ❯ Config file
9:21:27 PM: No config file was defined: using default values.
9:21:27 PM:
9:21:27 PM: ❯ Context
9:21:27 PM: production
9:21:27 PM:
9:21:27 PM: 1. Build command from Netlify app
9:21:27 PM:
9:21:27 PM: $ npm run build
9:21:27 PM: npm WARN config tmp This setting is no longer used. npm stores temporary files in a special
9:21:27 PM: npm WARN config location in the cache, and they are managed by
9:21:27 PM: npm WARN config cacache
9:21:27 PM: > advanced-bootstrap-homework-challenge@1.0.0 build
9:21:27 PM: > echo This is a static template, there is no bundler or bundling involved!
9:21:27 PM: This is a static template, there is no bundler or bundling involved!
9:21:27 PM:
9:21:27 PM: (build.command completed in 227ms)
9:21:27 PM:
9:21:27 PM: 2. Deploy site
9:21:27 PM:
9:21:27 PM:
9:21:27 PM: Configuration error
9:21:27 PM:
9:21:27 PM: Error message
9:21:27 PM: Deploy did not succeed: Deploy directory ‘dist’ does not exist
9:21:27 PM:
9:21:27 PM: Resolved config
9:21:27 PM: build:
9:21:27 PM: command: npm run build
9:21:27 PM: commandOrigin: ui
9:21:27 PM: publish: /opt/build/repo/dist
9:21:27 PM: publishOrigin: ui
9:21:27 PM: Caching artifacts
9:21:27 PM: Started saving node modules
9:21:27 PM: Finished saving node modules
9:21:27 PM: Started saving build plugins
9:21:27 PM: Finished saving build plugins
9:21:27 PM: Started saving pip cache
9:21:27 PM: Finished saving pip cache
9:21:27 PM: Started saving emacs cask dependencies
9:21:27 PM: Finished saving emacs cask dependencies
9:21:27 PM: Started saving maven dependencies
9:21:27 PM: Finished saving maven dependencies
9:21:27 PM: Started saving boot dependencies
9:21:27 PM: Finished saving boot dependencies
9:21:27 PM: Started saving rust rustup cache
9:21:27 PM: Finished saving rust rustup cache
9:21:27 PM: Started saving go dependencies
9:21:27 PM: Finished saving go dependencies
9:21:28 PM: Build failed due to a user error: Build script returned non-zero exit code: 2
9:21:28 PM: Creating deploy upload records
9:21:28 PM: Failing build: Failed to build site
9:21:28 PM: Failed during stage ‘building site’: Build script returned non-zero exit code: 2 (Search results for '"non-zero exit code: 2"' - Netlify Support Forums)
9:21:28 PM: Finished processing build request in 14.144068827s
