But the build process fails. Below is my config.ts and config.yml files:
config.yml:
backend:
branch: main # Branch to update (optional; defaults to master)
media_folder: “public/images” # Location where files will be stored in the repo
public_folder: “/images/uploads” # The src attribute for uploaded media
collections:
- name: ‘post’
label: ‘Post’
folder: ‘src/content/blog’
create: true
fields:
- { label: ‘Title’, name: ‘title’, widget: ‘string’ }
- { label: ‘Excerpt’, name: ‘excerpt’, widget: ‘string’ }
- { label: ‘Category’, name: ‘category’, widget: ‘string’ }
label: ‘Tags’,
widget: ‘list’,
allow_add: true,
allow_delete: true,
collapsed: false,
field: { label: ‘Tag’, name: ‘tag’, widget: ‘string’ },
- { label: “Featured Image”, name: “image”, widget: “image”,
fields: { label: “url”, name: “src”, widget: “string” },
{ label: “Alt Text”, name: “alt”, widget: “string” }
- { label: ‘Publish Date’, name: ‘publishDate’, widget: ‘datetime’, required: false }
- { label: ‘Author’, name: ‘author’, widget: ‘string’ }
- { label: ‘Content’, name: ‘body’, widget: ‘markdown’ }
config.ts:
const metadataDefinition = () =>
z
.object({
title: z.string().optional(),
ignoreTitleTemplate: z.boolean().optional(),
canonical: z.string().url().optional(),
robots: z
.object({
index: z.boolean().optional(),
follow: z.boolean().optional(),
.optional(),
description: z.string().optional(),
openGraph: z
.object({
url: z.string().optional(),
siteName: z.string().optional(),
images: z
.array(
z.object({
url: z.string(),
width: z.number().optional(),
height: z.number().optional(),
.optional(),
locale: z.string().optional(),
type: z.string().optional(),
.optional(),
twitter: z
.object({
handle: z.string().optional(),
site: z.string().optional(),
cardType: z.string().optional(),
.optional(),
.optional();
const postCollection = defineCollection({
schema: z.object({
publishDate: z.date().optional(),
updateDate: z.date().optional(),
draft: z.boolean().optional(),
title: z.string(),
excerpt: z.string().optional(),
image: z.string().optional(),
category: z.string().optional(),
tags: z.array(z.string()).optional(),
author: z.string().optional(),
metadata: metadataDefinition(),
export const collections = {
post: postCollection,
In DECAP CMS, the src and alt fields don’t appear so I can’t type them in.
