Netlify site name:
Custom site name:
Bird banding pliers: Ideal for address rings from Ø 15mm to Ø 30mm. Handcrafted, precise, and robust, perfect for falconry and ornithology.
The build on my custom domain does not work yesterday it has working, I have my domain correctly pointed to:
dns1.p03.nsone.net
dns2.p03.nsone.net
dns3.p03.nsone.net
dns4[dot]p03[dot]nsone[dot]net
The Lets encrypt SSL cannot be set up.
personal Domain is now working but SSL Lets encrypt will not activate @Melvin
Melvin
July 18, 2024, 5:00pm
3
Hi @schrrobe ,
Thanks for reaching out and welcome to Netlify’s Support Forums!
I see that you have a CNAME Record configured here:
If you remove the CNAME Record (but keep the NETLIFY Records) in the DNS Zone, are you then able to get an SSL Certificate? After removing the CNAME Record you may have to click Verify DNS configuration here .
hey mate,
i deleted the crecord SSL verification is still not working
Melvin
July 18, 2024, 5:34pm
5
Hi @schrrobe ,
I’m showing it’s working:
You can see that the SSL Certificate was provisioned here:
https://app.netlify.com/sites/beringungszange/domain-management#ssl-tls-certificate
Sometimes there’s a delay for DNS changes to propagate:
Last reviewed by Netlify Support on December 2024
How do time to live (TTL) values affect changes to DNS records?
People often ask why the changes to DNS (Domain Name System) records are not taking effect. The answer to this often involves a core mechanism of how DNS functions - the “time to live” (TTL) values for the DNS records themselves.
This topic is here to answer those questions! !
If you’d prefer a TL:DR; in the form of a video, check this out:
[ - YouTube]
(Link to…
You should see the changes, you may need to clear your browser cache if you’re not seeing the site properly.
thank you mate you helped me a lot <3
