Thanks! How can I connect to it? I get an HTTP 400 error, with a naive GET to either path. If it’s a POST with a body, or a cookie or header needs to be set, please let me know exactly what should be there.
It’s throwing an error because there is no cookie in the request header(which is my exact problem).
I am trying to extract the cookie, which is not being sent.
The cookie gets sent for /.netlify/functions/submitNote but not for /submitNote.
Please provide a command line with which I can see the difference between the two execution methods. It needs to have EVERYTHING I need to see the problem. So this probably includes:
a cookie (name and value)
potentially, some POST data (I am sending {} because you did not specify anything except “POST some data”).
I’d like to see you successfully call the function via curl in your response, so I can reproduce what you are seeing, to try to help undertstand the situation. Without more details, nobody can help you
