I have this website developed with nuxtjs and netlify functions.
This is the repo on github.
I exposed the FAUNADB_SECRET_KEY in the nuxt.config.js just for testing to make sure that was not the reason causing the issue.
The website works correctly locally with netlify dev
When deployed on netlify with nuxt generate all the content retrieved from Fauna db is missing.
Only the static content is rendered, see an example here
The generate routes on nuxt.config.js file is correct, because all the dynamic routes are generated (logged on the build log).
The functions and the redirects to load the data in the page are working correctly. As an example this one is used on the homepage.
The only suspect I have on the build logs is that there are multiple instances of this warning:
1:08:08 PM: [log] socket hang up
1:08:08 PM: at connResetException (node:internal/errors:692:14)
1:08:08 PM: at TLSSocket.socketOnEnd (node:_http_client:478:23)
1:08:08 PM: at TLSSocket.emit (node:events:539:35)
1:08:08 PM: at endReadableNT (node:internal/streams/readable:1345:12)
1:08:08 PM: at processTicksAndRejections (node:internal/process/task_queues:83:21)
Can this be related to the function calling the netlify function from the frontend or the netlify function calling the fauna db?
the full deploy log is here:
1:06:28 PM: Build ready to start
1:06:30 PM: build-image version: d2c6dbeac570350a387d832f64bc980dc964ad65 (focal)
1:06:30 PM: build-image tag: v4.8.0
1:06:30 PM: buildbot version: 17f6c1ab2fe6d61574ce02b038041b816bf6c085
1:06:30 PM: Building without cache
1:06:30 PM: Starting to prepare the repo for build
1:06:30 PM: No cached dependencies found. Cloning fresh repo
1:06:30 PM: git clone https://github.com/giovannilaperna/esc-py
1:06:31 PM: Preparing Git Reference refs/heads/main
1:06:32 PM: Parsing package.json dependencies
1:06:33 PM: Starting build script
1:06:33 PM: Installing dependencies
1:06:33 PM: Python version set to 2.7
1:06:33 PM: Downloading and installing node v16.15.0...
1:06:34 PM: Downloading https://nodejs.org/dist/v16.15.0/node-v16.15.0-linux-x64.tar.xz...
1:06:34 PM: Computing checksum with sha256sum
1:06:34 PM: Checksums matched!
1:06:36 PM: Now using node v16.15.0 (npm v8.5.5)
1:06:37 PM: Started restoring cached build plugins
1:06:37 PM: Finished restoring cached build plugins
1:06:37 PM: Attempting ruby version 2.7.2, read from environment
1:06:38 PM: Using ruby version 2.7.2
1:06:38 PM: Using PHP version 8.0
1:06:38 PM: No npm workspaces detected
1:06:38 PM: Started restoring cached node modules
1:06:38 PM: Finished restoring cached node modules
1:06:39 PM: Installing NPM modules using NPM version 8.5.5
1:06:47 PM: npm WARN deprecated source-map-url@0.4.1: See https://github.com/lydell/source-map-url#deprecated
1:06:47 PM: npm WARN deprecated urix@0.1.0: Please see https://github.com/lydell/urix#deprecated
1:06:48 PM: npm WARN deprecated resolve-url@0.2.1: https://github.com/lydell/resolve-url#deprecated
1:06:48 PM: npm WARN deprecated source-map-resolve@0.5.3: See https://github.com/lydell/source-map-resolve#deprecated
1:06:49 PM: npm WARN deprecated vue-analytics@5.22.1: Sorry but vue-analytics is no longer maintained. I would suggest you switch to vue-gtag, with love, the guy who made the package.
1:06:50 PM: npm WARN deprecated querystring@0.2.0: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
1:06:53 PM: npm WARN deprecated flatten@1.0.3: flatten is deprecated in favor of utility frameworks such as lodash.
1:06:54 PM: npm WARN deprecated nuxt-i18n@6.28.1: Please use the @nuxtjs/i18n package going forward
1:06:54 PM: npm WARN deprecated async-cache@1.1.0: No longer maintained. Use [lru-cache](http://npm.im/lru-cache) version 7.6 or higher, and provide an asynchronous `fetchMethod` option.
1:06:55 PM: npm WARN deprecated @types/browserslist@4.15.0: This is a stub types definition. browserslist provides its own type definitions, so you do not need this installed.
1:06:55 PM: npm WARN deprecated @types/anymatch@3.0.0: This is a stub types definition. anymatch provides its own type definitions, so you do not need this installed.
1:06:57 PM: npm WARN deprecated svgo@1.3.2: This SVGO version is no longer supported. Upgrade to v2.x.x.
1:06:58 PM: npm WARN deprecated chokidar@2.1.8: Chokidar 2 does not receive security updates since 2019. Upgrade to chokidar 3 with 15x fewer dependencies
1:07:02 PM: npm WARN deprecated core-js@2.6.12: core-js@<3.4 is no longer maintained and not recommended for usage due to the number of issues. Because of the V8 engine whims, feature detection in old core-js versions could cause a slowdown up to 100x even if nothing is polyfilled. Please, upgrade your dependencies to the actual version of core-js.
1:07:04 PM: added 1524 packages, and audited 1525 packages in 25s
1:07:04 PM: 188 packages are looking for funding
1:07:04 PM: run `npm fund` for details
1:07:04 PM: 15 vulnerabilities (7 moderate, 8 high)
1:07:04 PM: To address issues that do not require attention, run:
1:07:04 PM: npm audit fix
1:07:04 PM: To address all issues (including breaking changes), run:
1:07:04 PM: npm audit fix --force
1:07:04 PM: Run `npm audit` for details.
1:07:04 PM: NPM modules installed
1:07:04 PM: Started restoring cached go cache
1:07:04 PM: Finished restoring cached go cache
1:07:05 PM: go version go1.16.5 linux/amd64
1:07:05 PM: Installing missing commands
1:07:05 PM: Verify run directory
1:07:06 PM:
1:07:06 PM: ────────────────────────────────────────────────────────────────
1:07:06 PM: Netlify Build
1:07:06 PM:
1:07:06 PM: ❯ Version
1:07:06 PM: @netlify/build 27.1.3
1:07:06 PM:
1:07:06 PM: ❯ Flags
1:07:06 PM: baseRelDir: true
1:07:06 PM: buildId: 6287bc846e13e0271e3f7873
1:07:06 PM: deployId: 6287bc846e13e0271e3f7875
1:07:06 PM:
1:07:06 PM: ❯ Current directory
1:07:06 PM: /opt/build/repo
1:07:06 PM:
1:07:06 PM: ❯ Config file
1:07:06 PM: /opt/build/repo/netlify.toml
1:07:06 PM:
1:07:06 PM: ❯ Context
1:07:06 PM: production
1:07:06 PM:
1:07:06 PM: 1. build.command from netlify.toml
1:07:06 PM:
1:07:06 PM: $ npm run generate
1:07:06 PM: > esc-py@1.0.0 generate
1:07:06 PM: > nuxt generate
1:07:08 PM: [info] [@nuxt/content] Parsed 3 files in 0.5 seconds
1:07:09 PM: [info] Production build
1:07:09 PM: [info] Bundling for server and client side
1:07:09 PM: [info] Target: static
1:07:09 PM: [info] Using components loader to optimize imports
1:07:09 PM: [info] Discovered Components: node_modules/.cache/nuxt/components/readme.md
1:07:09 PM: [success] Builder initialized
1:07:09 PM: [success] Nuxt files generated
1:07:10 PM: [info] [webpackbar] Compiling Client
1:07:49 PM: [success] [webpackbar] Client: Compiled successfully in 38.81s
1:07:49 PM: [info] [webpackbar] Compiling Server
1:07:59 PM: [success] [webpackbar] Server: Compiled successfully in 9.69s
1:07:59 PM: Hash: 9c7e1e324856be40b226
1:07:59 PM: Version: webpack 4.46.0
1:07:59 PM: Time: 38813ms
1:07:59 PM: Built at: 05/20/2022 4:07:49 PM
1:07:59 PM: Asset Size Chunks Chunk Names
1:07:59 PM: ../server/client.manifest.json 27 KiB [emitted]
1:07:59 PM: 01d4ee3.js 2.76 KiB 11 [emitted] [immutable]
1:07:59 PM: 06471f4.js 2.57 KiB 18 [emitted] [immutable]
1:07:59 PM: 0729048.js 1020 bytes 54 [emitted] [immutable] components/model-index-card
1:07:59 PM: 0d6aeb5.js 1 KiB 58 [emitted] [immutable] components/model-reviews-list
1:07:59 PM: 0e62bf0.js 2.89 KiB 28 [emitted] [immutable]
1:07:59 PM: 0e923d3.js 3.71 KiB 46 [emitted] [immutable]
1:07:59 PM: 11c45bd.js 2.67 KiB 43 [emitted] [immutable]
1:07:59 PM: 13ed1b2.js 4.99 KiB 55 [emitted] [immutable] components/model-modal-gallery
1:07:59 PM: 18c8ad0.js 880 bytes 66 [emitted] [immutable] pages/blog/_slug
1:07:59 PM: 1a1b63a.js 4.05 KiB 75 [emitted] [immutable]
1:07:59 PM: 1ca12d8.js 2.65 KiB 45 [emitted] [immutable]
1:07:59 PM: 1e8786c.js 2.86 KiB 39 [emitted] [immutable]
1:07:59 PM: 2d8a299.js 3.5 KiB 24 [emitted] [immutable]
1:07:59 PM: 31468e0.js 957 bytes 57 [emitted] [immutable] components/model-preview-gallery
1:07:59 PM: 3442aad.js 2.29 KiB 7 [emitted] [immutable]
1:07:59 PM: 344f06d.js 2.56 KiB 49 [emitted] [immutable]
1:07:59 PM: 35085e0.js 1.68 KiB 67 [emitted] [immutable] pages/blog/index
1:07:59 PM: 3f8f7b2.js 3.23 KiB 26 [emitted] [immutable]
1:07:59 PM: 3f99aa1.js 26.5 KiB 1 [emitted] [immutable] vendors/components/model-review-add/pages/_model
1:07:59 PM: 425c8f4.js 3.5 KiB 2 [emitted] [immutable]
1:07:59 PM: 44160d7.js 4.6 KiB 30 [emitted] [immutable]
1:07:59 PM: 45c34df.js 3.19 KiB 12 [emitted] [immutable]
1:07:59 PM: 467021b.js 1.27 KiB 64 [emitted] [immutable] pages/404.html
1:07:59 PM: 46c41ee.js 7.04 KiB 63 [emitted] [immutable] lang-pt.js
1:07:59 PM: 473430f.js 2.81 KiB 38 [emitted] [immutable]
1:07:59 PM: 48bc909.js 99.5 KiB 74 [emitted] [immutable] vendors/content/plugin.js
1:07:59 PM: 4fcae81.js 5.53 KiB 17 [emitted] [immutable]
1:07:59 PM: 524ceeb.js 2.73 KiB 40 [emitted] [immutable]
1:07:59 PM: 598ebd6.js 3.68 KiB 4 [emitted] [immutable]
1:07:59 PM: 5b3d22e.js 2.76 KiB 6 [emitted] [immutable]
1:07:59 PM: 5eb2801.js 2.81 KiB 35 [emitted] [immutable]
1:07:59 PM: 5f236b6.js 4.07 KiB 37 [emitted] [immutable]
1:07:59 PM: 63eef6a.js 3.79 KiB 9 [emitted] [immutable]
1:07:59 PM: 64c8b08.js 4.18 KiB 44 [emitted] [immutable]
1:07:59 PM: 67363a9.js 3.21 KiB 22 [emitted] [immutable]
1:07:59 PM: 6ca617b.js 2.63 KiB 25 [emitted] [immutable]
1:07:59 PM: 6eeb8e5.js 3.77 KiB 23 [emitted] [immutable]
1:07:59 PM: 75530ff.js 605 bytes 56 [emitted] [immutable] components/model-phone-icon
1:07:59 PM: 779a4a2.js 3.36 KiB 41 [emitted] [immutable]
1:07:59 PM: 7ae9121.js 2.62 KiB 29 [emitted] [immutable]
1:07:59 PM: 7ce009f.js 3.08 KiB 21 [emitted] [immutable]
1:07:59 PM: 7ec9b6b.js 289 bytes 69 [emitted] [immutable] pages/favorite
1:07:59 PM: 88a810f.js 2.68 KiB 20 [emitted] [immutable]
1:07:59 PM: 8d68f47.js 2.56 KiB 31 [emitted] [immutable]
1:07:59 PM: 8fa7957.js 14.2 KiB 61 [emitted] [immutable] lang-en.js
1:07:59 PM: 90514d7.js 1.49 KiB 52 [emitted] [immutable] components/model-bookmark-icon
1:07:59 PM: 9187cab.js 2.93 KiB 47 [emitted] [immutable]
1:07:59 PM: 977a5c4.js 3.19 KiB 72 [emitted] [immutable] runtime
1:07:59 PM: 984177c.js 2.56 KiB 48 [emitted] [immutable]
1:07:59 PM: 985d166.js 3.19 KiB 33 [emitted] [immutable]
1:07:59 PM: 9e2aeda.js 3.12 KiB 3 [emitted] [immutable]
1:07:59 PM: LICENSES 949 bytes [emitted]
1:07:59 PM: a933929.js 315 KiB 51 [emitted] [immutable] [big] commons/app
1:07:59 PM: a95a3f2.js 625 bytes 60 [emitted] [immutable] components/model-whatsapp-icon
1:07:59 PM: a9f5687.js 19.5 KiB 0 [emitted] [immutable] components/model-review-add
1:07:59 PM: ae1fac1.js 2.93 KiB 70, 54 [emitted] [immutable] pages/index
1:07:59 PM: aed238b.js 2.81 KiB 5 [emitted] [immutable]
1:07:59 PM: b801af1.js 7.17 KiB 59 [emitted] [immutable] components/model-tags
1:07:59 PM: bab2500.js 2.9 KiB 8 [emitted] [immutable]
1:07:59 PM: bc9cda0.js 3.09 KiB 16 [emitted] [immutable]
1:07:59 PM: bdcea37.js 2.62 KiB 32 [emitted] [immutable]
1:07:59 PM: c25a6f7.js 2.98 KiB 36 [emitted] [immutable]
1:07:59 PM: c5b3fee.js 3.09 KiB 34 [emitted] [immutable]
1:07:59 PM: ca0dfd8.js 2.66 KiB 42 [emitted] [immutable]
1:07:59 PM: caf311b.js 16 KiB 62 [emitted] [immutable] lang-es.js
1:07:59 PM: ce1e3b0.js 3.87 KiB 27 [emitted] [immutable]
1:07:59 PM: cfde83d.js 3.28 KiB 13 [emitted] [immutable]
1:07:59 PM: d5e34a1.js 3.27 KiB 15 [emitted] [immutable]
1:07:59 PM: d87efa1.js 20.5 KiB 65, 52, 53, 55, 56, 57, 58, 59, 60 [emitted] [immutable] pages/_model
1:07:59 PM: db2f4e0.js 3.63 KiB 53, 52, 56, 60 [emitted] [immutable] components/model-header
1:07:59 PM: dd2e8a3.js 2.3 KiB 14 [emitted] [immutable]
1:07:59 PM: e309863.js 3.21 KiB 10 [emitted] [immutable]
1:07:59 PM: e9823b6.js 2.75 KiB 19 [emitted] [immutable]
1:07:59 PM: eac9734.js 336 bytes 68 [emitted] [immutable] pages/cb
1:07:59 PM: f63c369.js 665 bytes 71 [emitted] [immutable] pages/login-disabled
1:07:59 PM: f78b4e3.js 358 KiB 50 [emitted] [immutable] [big] app
1:07:59 PM: f87fe9a.js 1.29 MiB 73 [emitted] [immutable] [big] vendors/app
1:07:59 PM: + 2 hidden assets
1:07:59 PM: Entrypoint app [big] = 977a5c4.js a933929.js f87fe9a.js f78b4e3.js
1:07:59 PM: WARNING in asset size limit: The following asset(s) exceed the recommended size limit (244 KiB).
1:07:59 PM: This can impact web performance.
1:07:59 PM: Assets:
1:07:59 PM: f78b4e3.js (358 KiB)
1:07:59 PM: a933929.js (315 KiB)
1:07:59 PM: f87fe9a.js (1.29 MiB)
1:07:59 PM: WARNING in entrypoint size limit: The following entrypoint(s) combined asset size exceeds the recommended limit (1000 KiB). This can impact web performance.
1:07:59 PM: Entrypoints:
1:07:59 PM: app (1.95 MiB)
1:07:59 PM:
1:07:59 PM: Hash: b0844d538ffacdffab04
1:07:59 PM: Time: 9694ms
1:07:59 PM: Built at: 05/20/2022 4:07:59 PM
1:07:59 PM: 0.js 3.62 KiB 0 [emitted]
1:07:59 PM: 1.js 3.23 KiB 1 [emitted]
1:07:59 PM: 10.js 2.88 KiB 10 [emitted]
1:07:59 PM: 11.js 3.3 KiB 11 [emitted]
1:07:59 PM: 12.js 3.4 KiB 12 [emitted]
1:07:59 PM: 13.js 2.41 KiB 13 [emitted]
1:07:59 PM: 14.js 3.38 KiB 14 [emitted]
1:07:59 PM: 15.js 3.21 KiB 15 [emitted]
1:07:59 PM: 16.js 5.64 KiB 16 [emitted]
1:07:59 PM: 17.js 2.69 KiB 17 [emitted]
1:07:59 PM: 18.js 2.87 KiB 18 [emitted]
1:07:59 PM: 19.js 2.8 KiB 19 [emitted]
1:07:59 PM: 2.js 3.8 KiB 2 [emitted]
1:07:59 PM: 20.js 3.19 KiB 20 [emitted]
1:07:59 PM: 21.js 3.33 KiB 21 [emitted]
1:07:59 PM: 22.js 3.89 KiB 22 [emitted]
1:07:59 PM: 23.js 3.62 KiB 23 [emitted]
1:07:59 PM: 24.js 2.74 KiB 24 [emitted]
1:07:59 PM: 25.js 3.35 KiB 25 [emitted]
1:07:59 PM: 26.js 3.99 KiB 26 [emitted]
1:07:59 PM: 27.js 3 KiB 27 [emitted]
1:07:59 PM: 28.js 2.73 KiB 28 [emitted]
1:07:59 PM: 29.js 4.71 KiB 29 [emitted]
1:07:59 PM: 3.js 2.93 KiB 3 [emitted]
1:07:59 PM: 30.js 2.67 KiB 30 [emitted]
1:07:59 PM: 31.js 2.73 KiB 31 [emitted]
1:07:59 PM: 32.js 3.31 KiB 32 [emitted]
1:07:59 PM: 33.js 3.21 KiB 33 [emitted]
1:07:59 PM: 34.js 2.92 KiB 34 [emitted]
1:07:59 PM: 35.js 3.1 KiB 35 [emitted]
1:07:59 PM: 36.js 4.18 KiB 36 [emitted]
1:07:59 PM: 37.js 2.92 KiB 37 [emitted]
1:07:59 PM: 38.js 2.97 KiB 38 [emitted]
1:07:59 PM: 39.js 2.84 KiB 39 [emitted]
1:07:59 PM: 4.js 2.88 KiB 4 [emitted]
1:07:59 PM: 40.js 3.47 KiB 40 [emitted]
1:07:59 PM: 41.js 2.78 KiB 41 [emitted]
1:07:59 PM: 42.js 2.79 KiB 42 [emitted]
1:07:59 PM: 43.js 4.29 KiB 43 [emitted]
1:07:59 PM: 44.js 2.77 KiB 44 [emitted]
1:07:59 PM: 45.js 3.83 KiB 45 [emitted]
1:07:59 PM: 46.js 3.05 KiB 46 [emitted]
1:07:59 PM: 47.js 2.68 KiB 47 [emitted]
1:07:59 PM: 48.js 2.67 KiB 48 [emitted]
1:07:59 PM: 5.js 2.4 KiB 5 [emitted]
1:07:59 PM: 6.js 3.01 KiB 6 [emitted]
1:07:59 PM: 7.js 3.9 KiB 7 [emitted]
1:07:59 PM: 8.js 3.32 KiB 8 [emitted]
1:07:59 PM: 9.js 3.18 KiB 9 [emitted]
1:07:59 PM: components/model-bookmark-icon.js 2.8 KiB 50 [emitted] components/model-bookmark-icon
1:07:59 PM: components/model-header.js 9.92 KiB 51, 50, 54, 59 [emitted] components/model-header
1:07:59 PM: components/model-index-card.js 2.65 KiB 52 [emitted] components/model-index-card
1:07:59 PM: components/model-modal-gallery.js 17 KiB 53 [emitted] components/model-modal-gallery
1:07:59 PM: components/model-phone-icon.js 2.24 KiB 54 [emitted] components/model-phone-icon
1:07:59 PM: components/model-preview-gallery.js 2.51 KiB 55 [emitted] components/model-preview-gallery
1:07:59 PM: components/model-review-add.js 163 KiB 56 [emitted] components/model-review-add
1:07:59 PM: components/model-reviews-list.js 2.41 KiB 57 [emitted] components/model-reviews-list
1:07:59 PM: components/model-tags.js 9.3 KiB 58 [emitted] components/model-tags
1:07:59 PM: components/model-whatsapp-icon.js 2.33 KiB 59 [emitted] components/model-whatsapp-icon
1:07:59 PM: lang-en.js.js 12.3 KiB 60 [emitted] lang-en.js
1:07:59 PM: lang-es.js.js 13.6 KiB 61 [emitted] lang-es.js
1:07:59 PM: lang-pt.js.js 5.88 KiB 62 [emitted] lang-pt.js
1:07:59 PM: pages/404.html.js 6.16 KiB 63 [emitted] pages/404.html
1:07:59 PM: pages/_model.js 211 KiB 64, 50, 51, 53, 54, 55, 56, 57, 58, 59 [emitted] pages/_model
1:07:59 PM: pages/blog/_slug.js 2.12 KiB 65 [emitted] pages/blog/_slug
1:07:59 PM: pages/blog/index.js 2.28 KiB 66 [emitted] pages/blog/index
1:07:59 PM: pages/cb.js 1.68 KiB 67 [emitted] pages/cb
1:07:59 PM: pages/favorite.js 1.19 KiB 68 [emitted] pages/favorite
1:07:59 PM: pages/index.js 5.34 KiB 69, 52 [emitted] pages/index
1:07:59 PM: pages/login-disabled.js 1.67 KiB 70 [emitted] pages/login-disabled
1:07:59 PM: server.js 1.04 MiB 49 [emitted] app
1:07:59 PM: server.manifest.json 4.83 KiB [emitted]
1:07:59 PM: + 71 hidden assets
1:07:59 PM: Entrypoint app = server.js server.js.map
1:07:59 PM: [info] [@nuxt/content] Parsed 3 files in 0.0 seconds
1:07:59 PM: [info] Full static generation activated
1:07:59 PM: [info] Generating output directory: dist/
1:07:59 PM: [info] Generating pages with full static mode
1:08:08 PM: [success] Generated route "/blog"
1:08:08 PM: [success] Generated route "/404.html"
1:08:08 PM: [success] Generated route "/favorite"
1:08:08 PM: [success] Generated route "/cb"
1:08:08 PM: [success] Generated route "/login-disabled"
1:08:08 PM: [success] Generated route "/es/favorite"
1:08:08 PM: [success] Generated route "/en/blog/test"
1:08:08 PM: [success] Generated route "/pt/login-disabled"
1:08:08 PM: [success] Generated route "/en/login-disabled"
1:08:08 PM: [success] Generated route "/pt/favorite"
1:08:08 PM: [success] Generated route "/en/favorite"
1:08:08 PM: [success] Generated route "/es/login-disabled"
1:08:08 PM: [success] Generated route "/es/blog/test"
1:08:08 PM: [success] Generated route "/en/blog"
1:08:08 PM: [success] Generated route "/pt/blog/test"
1:08:08 PM: [success] Generated route "/es/blog"
1:08:08 PM: [success] Generated route "/pt/blog"
1:08:09 PM: [success] Generated route "/en"
1:08:09 PM: [success] Generated route "/es"
1:08:09 PM: [success] Generated route "/pt"
1:08:09 PM: [success] Generated route "/"
1:08:10 PM: [success] Generated route "/es/stefania-c"
1:08:11 PM: [success] Generated route "/es/horacio-andres-c"
1:08:11 PM: [success] Generated route "/pt/stefania-c"
1:08:11 PM: [success] Generated route "/en/horacio-andres-c"
1:08:12 PM: [success] Generated route "/pt/horacio-andres-c"
1:08:12 PM: [success] Generated route "/en/stefania-c"
1:08:12 PM: [success] Client-side fallback created: `200.html`
1:08:12 PM: [success] Static manifest generated
1:08:12 PM: [info] Generating sitemaps
1:08:12 PM: [success] Generated /sitemap.xml
1:08:13 PM:
1:08:13 PM: (build.command completed in 1m 6.8s)
1:08:13 PM:
1:08:13 PM: ────────────────────────────────────────────────────────────────
1:08:13 PM: 2. Functions bundling
1:08:13 PM:
1:08:13 PM: Packaging Functions from netlify/functions directory:
1:08:13 PM: - model-get.js
1:08:13 PM: - models-get.js
1:08:13 PM: - reviews-get.js
1:08:13 PM: - user.js
1:08:13 PM: - wa-send-code.js
1:08:13 PM: - wa-status.js
1:08:13 PM: - wa-verify-code.js
1:08:13 PM:
1:08:14 PM:
1:08:14 PM: (Functions bundling completed in 664ms)
1:08:14 PM:
1:08:14 PM: ────────────────────────────────────────────────────────────────
1:08:14 PM: 3. Deploy site
1:08:14 PM:
1:08:14 PM: Starting to deploy site from 'dist'
1:08:14 PM: Creating deploy upload records
1:08:14 PM: Creating deploy tree
1:08:14 PM: 60 new files to upload
1:08:14 PM: 0 new functions to upload
1:08:18 PM: Site deploy was successfully initiated
1:08:18 PM:
1:08:18 PM: (Deploy site completed in 3.8s)
1:08:18 PM:
1:08:18 PM: ────────────────────────────────────────────────────────────────
1:08:18 PM: Netlify Build Complete
1:08:18 PM:
1:08:18 PM: (Netlify Build completed in 1m 11.4s)
1:08:18 PM: Caching artifacts
1:08:18 PM: Started saving node modules
1:08:18 PM: Finished saving node modules
1:08:18 PM: Starting post processing
1:08:18 PM: Started saving build plugins
1:08:18 PM: Finished saving build plugins
1:08:18 PM: Started saving pip cache
1:08:18 PM: Finished saving pip cache
1:08:18 PM: Post processing - HTML
1:08:18 PM: Started saving emacs cask dependencies
1:08:18 PM: Finished saving emacs cask dependencies
1:08:18 PM: Started saving maven dependencies
1:08:18 PM: Finished saving maven dependencies
1:08:18 PM: Started saving boot dependencies
1:08:18 PM: Finished saving boot dependencies
1:08:18 PM: Started saving rust rustup cache
1:08:18 PM: Finished saving rust rustup cache
1:08:18 PM: Started saving go dependencies
1:08:18 PM: Finished saving go dependencies
1:08:19 PM: Build script success
1:08:26 PM: Post processing - header rules
1:08:26 PM: Post processing - redirect rules
1:08:26 PM: Post processing done
1:08:30 PM: Site is live ✨
1:08:39 PM: Finished processing build request in 2m9.592517839s
