I’m aware that there is ongoing work to enable context sensitive build plugins as part of Allow context sensitive build plugins config in netlify.toml · Issue #1169 · netlify/build · GitHub but I was wondering if there was any way to control the running of build plugins based on conditions other than context?
For example, an incoming webhook from a headless CMS will trigger a static site rebuild. For these occasions we might not want to run a particular plugin.
Is there any way to use the build hook metadata to ignore certain hooks when running build plugins?
TIA
