Bundling of edge functions failed
I have not been able to deploy due to the edge functions failing on bundling. I believe this is coming from my middleware. I am using Kinde middleware, GitHub - kinde-oss/kinde-auth-nextjs: Kinde NextJS SDK - authentication for server rendered apps.
I managed to bypass the bundling issue by upgrading to the Next.js canary version, enabling the experimental nodeMiddleware flag in my Next.js config, and explicitly setting runtime: “nodejs” in my middleware file. This bypasses the bundling issue but my website is not working properly. The middleware from Kinde does not use any Node api so I don’t get why it won’t bundle in Deno.
Here is the error:
Edge Functions bundling
8:34:17 PM: ────────────────────────────────────────────────────────────────
8:34:17 PM: ​
8:34:17 PM: Packaging Edge Functions from .netlify/edge-functions directory:
8:34:17 PM: - ___netlify-edge-handler-src-middleware
8:34:20 PM: Error: this method must be invoked in a node.js environment
8:34:20 PM: at file:///opt/build/repo/.netlify/edge-functions/___netlify-edge-handler-src-middleware/server/src/middleware.js:63:327119
8:34:20 PM: at Object.802 (file:///opt/build/repo/.netlify/edge-functions/___netlify-edge-handler-src-middleware/server/src/middleware.js:63:327381)
8:34:20 PM: at t (file:///opt/build/repo/.netlify/edge-functions/___netlify-edge-handler-src-middleware/server/src/middleware.js:47:127)
8:34:20 PM: at file:///opt/build/repo/.netlify/edge-functions/___netlify-edge-handler-src-middleware/server/src/middleware.js:141:53002
8:34:20 PM: at r (file:///opt/build/repo/.netlify/edge-functions/___netlify-edge-handler-src-middleware/server/src/middleware.js:47:1250)
8:34:20 PM: at file:///opt/build/repo/.netlify/edge-functions/___netlify-edge-handler-src-middleware/server/src/middleware.js:51:51
8:34:20 PM: ​
8:34:20 PM: Bundling of edge function failed
8:34:20 PM: ────────────────────────────────────────────────────────────────
8:34:20 PM: ​
8:34:20 PM: Error message
8:34:20 PM: Could not load edge function at ‘/opt/build/repo/.netlify/edge-functions/___netlify-edge-handler-src-middleware/___netlify-edge-handler-src-middleware.js’. More on the Edge Functions API at Edge Functions API | Netlify Docs.
8:34:20 PM: ​
8:34:20 PM: Error location
8:34:20 PM: While bundling edge function
You’ve not specified a site name. Please mention it along with the “issue” that you mentioned here:
test-deploy-5678.netlify.app
You seem to have successful deploys. Is this resolved?
Nope that’s just me reverting back to running the app with no middleware so i can continue developing. I still need a fix
Sorry for the delay! Are you still experiencing this issue? If so, could you send a link to a deploy where this issue is present?
