Build is not working and I don't know why
I’m struggling to build my portfolio: evenguyen.netlify.app
I already set the build command to CI=‘’ npm run build, I updated all the packages (I think) so I’m not sure what’s the problem. The error messages aren’t any help either
10:39:36 PM: npm ERR! | ^
10:39:36 PM: npm ERR! /opt/buildhome/.node-gyp/16.17.0/include/node/node.h:893:3: note: in expansion of macro ‘NODE_MODULE_X’
10:39:36 PM: npm ERR! 893 | NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage)
10:39:36 PM: npm ERR! | ^~~~~~~~~~~~~
10:39:36 PM: npm ERR! …/src/binding.cpp:358:1: note: in expansion of macro ‘NODE_MODULE’
10:39:36 PM: npm ERR! 358 | NODE_MODULE(binding, RegisterModule);
10:39:36 PM: npm ERR! make: *** [binding.target.mk:133: Release/obj.target/binding/src/binding.o] Error 1
10:39:36 PM: npm ERR! gyp ERR! build error
10:39:36 PM: npm ERR! gyp ERR! stack Error: make failed with exit code: 2
10:39:36 PM: npm ERR! gyp ERR! stack at ChildProcess.onExit (/opt/build/repo/node_modules/node-gyp/lib/build.js:262:23)
10:39:36 PM: npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:513:28)
10:39:36 PM: npm ERR! gyp ERR! stack at Process.ChildProcess._handle.onexit (node:internal/child_process:291:12)
10:39:36 PM: npm ERR! gyp ERR! System Linux 5.4.196-108.356.amzn2.x86_64
10:39:36 PM: npm ERR! gyp ERR! command “/opt/buildhome/.nvm/versions/node/v16.17.0/bin/node” “/opt/build/repo/node_modules/node-gyp/bin/node-gyp.js” “rebuild” “–verbose” “–libsass_ext=” “–libsass_cflags=” “–libsass_ldflags=” “–libsass_library=”
10:39:36 PM: npm ERR! gyp ERR! cwd /opt/build/repo/node_modules/node-sass
10:39:36 PM: npm ERR! gyp ERR! node -v v16.17.0
10:39:36 PM: npm ERR! gyp ERR! node-gyp -v v3.8.0
10:39:36 PM: npm ERR! gyp ERR! not ok
10:39:36 PM: npm ERR! Build failed with error code: 1
10:39:36 PM: npm ERR! A complete log of this run can be found in:
10:39:36 PM: npm ERR! /opt/buildhome/.npm/_logs/2022-09-03T05_37_01_447Z-debug-0.log
10:39:36 PM: Error during NPM install
10:39:36 PM: Build was terminated: Build script returned non-zero exit code: 1
10:39:36 PM: Creating deploy upload reds
10:39:36 PM: Failing build: Failed to build site
10:39:36 PM: Failed during stage ‘building site’: Build script returned non-zero exit code: 1 (Search results for '"non-zero exit code: 1"' - Netlify Support Forums)
10:39:36 PM: Finished processing build request in 2m42.215455381s
what’s the issue?
Hi @ENguyen25
Can you share the contents of your package.json, or the repository you are deploying from?
11:12:11 PM: Build ready to start
11:12:14 PM: build-image version: d7b3dbfb0846505993c9a131894d1858074c90b4 (focal)
11:12:14 PM: build-image tag: v4.10.1
11:12:14 PM: buildbot version: 67e75f1ba713a8213d4b5a8ccf9708af751e2390
11:12:14 PM: Fetching cached dependencies
11:12:14 PM: Starting to download cache of 198.6MB
11:12:16 PM: Finished downloading cache in 1.292485264s
11:12:16 PM: Starting to extract cache
11:12:18 PM: Finished extracting cache in 2.733337209s
11:12:18 PM: Finished fetching cache in 4.092300997s
11:12:18 PM: Starting to prepare the repo for build
11:12:19 PM: Preparing Git Reference refs/heads/master
11:12:19 PM: Parsing package.json dependencies
11:12:20 PM: Starting build script
11:12:20 PM: Installing dependencies
11:12:20 PM: Python version set to 2.7
11:12:20 PM: Started restoring cached node version
11:12:21 PM: Finished restoring cached node version
11:12:21 PM: Downloading and installing node v16.17.0...
11:12:21 PM: Downloading https://nodejs.org/dist/v16.17.0/node-v16.17.0-linux-x64.tar.xz...
11:12:22 PM: Computing checksum with sha256sum
11:12:22 PM: Checksums matched!
11:12:24 PM: Now using node v16.17.0 (npm v8.15.0)
11:12:24 PM: Started restoring cached build plugins
11:12:24 PM: Finished restoring cached build plugins
11:12:24 PM: Attempting ruby version 2.7.2, read from environment
11:12:25 PM: Using ruby version 2.7.2
11:12:25 PM: Using PHP version 8.0
11:12:25 PM: No npm workspaces detected
11:12:25 PM: Started restoring cached node modules
11:12:25 PM: Finished restoring cached node modules
11:12:25 PM: Installing NPM modules using NPM version 8.15.0
11:12:26 PM: npm WARN config tmp This setting is no longer used. npm stores temporary files in a special
11:12:26 PM: npm WARN config location in the cache, and they are managed by
11:12:26 PM: npm WARN config [`cacache`](http://npm.im/cacache).
11:12:30 PM: npm ERR! code ERESOLVE
11:12:30 PM: npm ERR! ERESOLVE unable to resolve dependency tree
11:12:30 PM: npm ERR! While resolving: gatsby-starter-hello-world@0.1.0
11:12:30 PM: npm ERR! Found: gatsby@2.32.13
11:12:30 PM: npm ERR! node_modules/gatsby
11:12:30 PM: npm ERR! gatsby@"^2.23.7" from the root project
11:12:30 PM: npm ERR! Could not resolve dependency:
11:12:30 PM: npm ERR! peer gatsby@"^4.0.0" from gatsby-plugin-netlify@5.0.1
11:12:30 PM: npm ERR! node_modules/gatsby-plugin-netlify
11:12:30 PM: npm ERR! dev gatsby-plugin-netlify@"^5.0.1" from the root project
11:12:30 PM: npm ERR! Fix the upstream dependency conflict, or retry
11:12:30 PM: npm ERR! this command with --force, or --legacy-peer-deps
11:12:30 PM: npm ERR! to accept an incorrect (and potentially broken) dependency resolution.
11:12:30 PM: npm ERR! See /opt/buildhome/.npm/eresolve-report.txt for a full report.
11:12:30 PM: npm ERR! A complete log of this run can be found in:
11:12:30 PM: npm ERR! /opt/buildhome/.npm/_logs/2022-09-03T06_12_26_253Z-debug-0.log
11:12:30 PM: Error during NPM install
11:12:30 PM: Build was terminated: Build script returned non-zero exit code: 1
11:12:30 PM: Creating deploy upload records
11:12:30 PM: Failing build: Failed to build site
11:12:30 PM: Failed during stage 'building site': Build script returned non-zero exit code: 1 (https://ntl.fyi/exit-code-1)
11:12:31 PM: Finished processing build request in 16.332789943s
tried again by downloading gatsby-plugin-netlify – it doesn’t like it
The Netlify plugin requires gatsby 4 as per this message:
Your package.json has "gatsby": "^2.23.7" but there is also mention of version 2.32.12
Given you are using gatsby v2 (which is about 2 years old) I suspect it doesn’t like NodeJS v16. You could try adding the --force or --legacy-peer-deps using NPM_FLAGS environment variable, downgrading NodeJS to v14 using the NODE_VERSION environment variable, or updating gatsby (and everything else in the project) to the latest versions. Check out npm outdated.
oh thank the Gods. thank you!!!
Great that you got it working @ENguyen25.
Can you say what specifically you did? Downgrade Node, NPM_FLAGS, update packages?
I updated the packages!
Thanks for coming back and letting us know! Glad everything is working now. Happy building :rocket:
