I am a newbie and I have been unable find any help trying to get to the root of this issue, it compiled successfully on my local machine.
I would greatly appreciate pointers.
The next debugging step is to ensure the package versions we use to build match the ones you use in your own development environment. You can find the settings for these in our Build Settings doc. That’s the leading cause of build failures.
