Hello,
My project builds locally just fine, but fails in Netlify with the following error:
error protobufjs@7.1.2: The engine "node" is incompatible with this module. Expected version ">=12.0.0". Got "10.24.1"
I’ve deleted and recreated my yarn.lock, redeployed (w/ cache clearing). I haven’t found anything out there regarding this package, outside of I think it’s used by Firebase which I’m using.
But I’m curious why the local build works, project runs, etc but build fails in Netlify?
Apologies if I missed including information.
Build settings:
Build log below:
7:58:24 PM: build-image version: d7b3813f01c06610bc1723ff1b22446513ee7941 (focal) 7:58:24 PM: build-image tag: v4.14.3 7:58:24 PM: buildbot version: 4f669c94b322d52f143cdcbb17e55d40094aa06d 7:58:24 PM: Building without cache 7:58:24 PM: Starting to prepare the repo for build 7:58:25 PM: No cached dependencies found. Cloning fresh repo 7:58:25 PM: git clone https://github.com/pnwnelson/project-egg 7:58:25 PM: Preparing Git Reference pull/213/head 7:58:26 PM: Parsing package.json dependencies 7:58:27 PM: Section completed: initializing 7:58:27 PM: Starting build script 7:58:27 PM: Installing dependencies 7:58:27 PM: Python version set to 2.7 7:58:28 PM: Downloading and installing node v10.24.1... 7:58:28 PM: Downloading https://nodejs.org/dist/v10.24.1/node-v10.24.1-linux-x64.tar.xz... 7:58:28 PM: Computing checksum with sha256sum 7:58:28 PM: Checksums matched! 7:58:29 PM: Now using node v10.24.1 (npm v6.14.12) 7:58:29 PM: Started restoring cached build plugins 7:58:29 PM: Finished restoring cached build plugins 7:58:29 PM: Attempting ruby version 2.6.2, read from environment 7:58:30 PM: Required ruby-2.6.2 is not installed - installing. 7:58:30 PM: Searching for binary rubies, this might take some time. 7:58:30 PM: Found remote file https://rvm_io.global.ssl.fastly.net/binaries/ubuntu/20.04/x86_64/ruby-2.6.2.tar.bz2 7:58:30 PM: Checking requirements for ubuntu. 7:58:30 PM: Requirements installation successful. 7:58:30 PM: ruby-2.6.2 - #configure 7:58:30 PM: ruby-2.6.2 - #download 7:58:31 PM: ruby-2.6.2 - #validate archive 7:58:34 PM: ruby-2.6.2 - #extract 7:58:35 PM: ruby-2.6.2 - #validate binary 7:58:36 PM: ruby-2.6.2 - #setup 7:58:36 PM: ruby-2.6.2 - #gemset created /opt/buildhome/.rvm/gems/ruby-2.6.2@global 7:58:36 PM: ruby-2.6.2 - #importing gemset /opt/buildhome/.rvm/gemsets/global.gems........................................ 7:58:37 PM: ruby-2.6.2 - #generating global wrappers........ 7:58:37 PM: ruby-2.6.2 - #gemset created /opt/buildhome/.rvm/gems/ruby-2.6.2 7:58:37 PM: ruby-2.6.2 - #importing gemsetfile /opt/buildhome/.rvm/gemsets/default.gems evaluated to empty gem list 7:58:37 PM: ruby-2.6.2 - #generating default wrappers........ 7:58:37 PM: Using /opt/buildhome/.rvm/gems/ruby-2.6.2 7:58:37 PM: Using ruby version 2.6.2 7:58:38 PM: Using PHP version 8.0 7:58:38 PM: Started restoring cached yarn cache 7:58:38 PM: Finished restoring cached yarn cache 7:58:38 PM: Found yarn version (1.22.19) that doesn't match expected (1.17.0)up to date in 0.019s 7:58:38 PM: Installing yarn at version 1.17.0 7:58:38 PM: Installing Yarn! 7:58:38 PM: > Downloading tarball... 7:58:38 PM: [1/2]: https://yarnpkg.com/downloads/1.17.0/yarn-v1.17.0.tar.gz --> /tmp/yarn.tar.gz.6bUaT5UBUn 7:58:38 PM: % Total % Received % Xferd Average Speed Time Time Time Current 7:58:38 PM: Dload Upload Total Spent Left Speed 7:58:38 PM: 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 7:58:38 PM: 100 79 100 79 0 0 652 0 --:--:-- --:--:-- --:--:-- 652 7:58:39 PM: 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 7:58:39 PM: 100 93 100 93 0 0 379 0 --:--:-- --:--:-- --:--:-- 861 7:58:39 PM: 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 7:58:39 PM: 100 1213k 100 1213k 0 0 2328k 0 --:--:-- --:--:-- --:--:-- 2328k 7:58:39 PM: [2/2]: https://yarnpkg.com/downloads/1.17.0/yarn-v1.17.0.tar.gz.asc --> /tmp/yarn.tar.gz.6bUaT5UBUn.asc 7:58:39 PM: % Total % Received % Xferd Average Speed Time Time Time Current 7:58:39 PM: Dload Upload Total Spent Left Speed 7:58:39 PM: 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 7:58:39 PM: 100 83 100 83 0 0 1220 0 --:--:-- --:--:-- --:--:-- 1220 7:58:39 PM: 100 97 100 97 0 0 970 0 --:--:-- --:--:-- --:--:-- 970 7:58:39 PM: 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 7:58:39 PM: 100 832 100 832 0 0 3495 0 --:--:-- --:--:-- --:--:-- 3495 7:58:39 PM: > Verifying integrity... 7:58:39 PM: gpg: Signature made Fri 14 Jun 2019 06:55:58 PM UTC 7:58:39 PM: gpg: using RSA key 6D98490C6F1ACDDD448E45954F77679369475BAA 7:58:39 PM: gpg: Good signature from "Yarn Packaging <yarn@dan.cx>" [unknown] 7:58:39 PM: gpg: WARNING: This key is not certified with a trusted signature! 7:58:39 PM: gpg: There is no indication that the signature belongs to the owner. 7:58:39 PM: Primary key fingerprint: 72EC F46A 56B4 AD39 C907 BBB7 1646 B01B 86E5 0310 7:58:39 PM: Subkey fingerprint: 6D98 490C 6F1A CDDD 448E 4595 4F77 6793 6947 5BAA 7:58:39 PM: > GPG signature looks good 7:58:39 PM: > Extracting to ~/.yarn... 7:58:39 PM: > Adding to $PATH... 7:58:39 PM: > Successfully installed Yarn 1.17.0! Please open another terminal where the yarn command will now be available. 7:58:39 PM: No yarn workspaces detected 7:58:39 PM: Started restoring cached node modules 7:58:39 PM: Finished restoring cached node modules 7:58:40 PM: Installing NPM modules using Yarn version 1.17.0 7:58:40 PM: yarn install v1.17.0 7:58:40 PM: [1/4] Resolving packages... 7:58:40 PM: [2/4] Fetching packages... 7:58:57 PM: error protobufjs@7.1.2: The engine "node" is incompatible with this module. Expected version ">=12.0.0". Got "10.24.1" 7:58:57 PM: error Found incompatible module. 7:58:57 PM: info Visit https://yarnpkg.com/en/docs/cli/install for documentation about this command. 7:58:57 PM: Creating deploy upload records 7:58:57 PM: Error during Yarn install 7:58:57 PM: Build was terminated: Build script returned non-zero exit code: 1 7:58:57 PM: Failing build: Failed to build site 7:58:57 PM: Failed during stage 'building site': Build script returned non-zero exit code: 1 (https://ntl.fyi/exit-code-1) 7:58:57 PM: Finished processing build request in 33.116620732s
