My Zola site builds started failing few days ago.
netlify site name. happy-lalande-63e62a
DNS issues? No
Relevant build log
The zola build itself works - I think.
12:30:26 PM: Building site...
12:30:26 PM: Checking all internal links with anchors.
12:30:26 PM: > Successfully checked 0 internal link(s) with anchors.
12:30:26 PM: -> Creating 63 pages (0 orphan) and 31 sections
12:30:27 PM: Done in 761ms.
12:30:27 PM: Unhandled rejectionβ¦
12:30:27 PM: TypeError: Cannot read properties of undefined (reading 'packageName')
12:30:27 PM: at title (file:///opt/buildhome/node-deps/node_modules/@netlify/build/lib/error/type.js:111:31)
12:30:27 PM: at getTitle (file:///opt/buildhome/node-deps/node_modules/@netlify/build/lib/error/parse/parse.js:66:12)
12:30:27 PM: at getFullErrorInfo (file:///opt/buildhome/node-deps/node_modules/@netlify/build/lib/error/parse/parse.js:13:20)
12:30:27 PM: at logBuildError (file:///opt/buildhome/node-deps/node_modules/@netlify/build/lib/log/messages/core.js:17:27)
12:30:27 PM: at handleBuildError (file:///opt/buildhome/node-deps/node_modules/@netlify/build/lib/error/handle.js:17:9)
12:30:27 PM: at async buildSite (file:///opt/buildhome/node-deps/node_modules/@netlify/build/lib/core/main.js:65:30)
12:30:27 PM: at async runCli (file:///opt/buildhome/node-deps/node_modules/@netlify/build/lib/core/bin.js:20:36)
12:30:27 PM: /opt/buildhome/node-deps/node_modules/.bin/netlify-build exited with exit code 0 without finishing the build.
12:30:28 PM: Build failed due to an internal system error: Build script returned non-zero exit code: 4
12:30:28 PM: Failing build: Failed to build site
12:30:29 PM: Finished processing build request in 18.525s
build settings : You can refer to netlify.toml here
Yes, my obsidian-zola build has failed as well:
11:21:34 PM: build.command from netlify.toml
11:21:34 PM: ββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββ
11:21:34 PM: β
11:21:34 PM: $ rm -rf __obsidian __site && mkdir __obsidian && mv * __obsidian || true && git clone https://github.com/ppeetteerrs/obsidian-zola.git __site && __site/run.sh
11:21:34 PM: mv: cannot move '__obsidian' to a subdirectory of itself, '__obsidian/__obsidian'
11:21:34 PM: Cloning into '__site'...
11:21:38 PM: Failed during stage 'building site': Build script returned non-zero exit code: 4 (https://ntl.fyi/exit-code-4)
Here is the full log:
https://pastebin.pl/view/55280ee9
site name:
https://mova.alafghani.info
toml file:
Hi @mandarvaze ,
Checking your deploy history, you seem to have resolved the issue. Are you still having issues?
If youβve resolved, mind sharing your solution, so @movanet can try that?
Having the same problem as well. Spent a few hours debugging it but no luck. Looks to me like something internally happening at Netlify CI. Iβve tried to make sure the build script has no error but for some reasons netlify-build keeps exiting code 4
This has been escalated to the devs.
Same problem here! Any update from devs?
SamO
June 26, 2023, 7:10pm
8
Hi, no updates yet but our devs are investigating now and will follow on this thread when we find a solution.
@hrishikesh @movanet I didnβt resolve the issue specifically.
I switched from obsidian-zola to GitHub - orditeck/cheap-publish: A fork of obsidian-zola & obsidian-zola-plus with a few more features and an honest name. - which seemed to have resolved the issue.
It could be completely timing Though I would like to believe it is switching to cheap-publish helped
BTW, I had problem for my hugo site as well. Turns out the details are hidden under Deploying stage - which is shown as Complete (marked in green)
Read about it here : Interesting Netlify Build Problem Β· @mandarvazeβs microblog if you are curious.
itβs back to normal now for me. Not sure what about anyone else
As I mentioned above, it is working for me as well. But Iβm not sure if it was just timing or my changes helped
This has been resolved from our end as of yesterday.
must be from netlify changes because iβm not using your setup. Thanks @hrishikesh and the team for the help
