Getting this error message only when I do a “Clean cache & deploy site” If I just update my site through a change in my Gitthub Repo it builds fine. The site also builds fine on my local box.
11:10:55 AM: Build ready to start
11:10:58 AM: build-image version: 3031d4c9e432fd7016f6279fc9ad706f9205d845
11:10:58 AM: build-image tag: v3.3.17
11:10:58 AM: buildbot version: 1f35b3abd6e2bf5230d8edf68072840fdec1513f
11:10:58 AM: Fetching cached dependencies
11:10:58 AM: Starting to download cache of 254.3KB
11:10:58 AM: Finished downloading cache in 65.084838ms
11:10:58 AM: Starting to extract cache
11:10:58 AM: Failed to fetch cache, continuing with build
11:10:58 AM: Starting to prepare the repo for build
11:10:59 AM: No cached dependencies found. Cloning fresh repo
11:10:59 AM: git clone
11:11:12 AM: Preparing Git Reference refs/heads/master
11:11:15 AM: Different publish path detected, going to use the one specified in the Netlify configuration file: ‘public’ versus ‘public/’ in the Netlify UI
11:11:15 AM: Starting build script
11:11:15 AM: Installing dependencies
11:11:15 AM: Python version set to 2.7
11:11:16 AM: Downloading and installing node v10.21.0…
11:11:16 AM: Downloading https://nodejs.org/dist/v10.21.0/node-v10.21.0-linux-x64.tar.xz…
11:11:17 AM: Computing checksum with sha256sum
11:11:17 AM: Checksums matched!
11:11:19 AM: Now using node v10.21.0 (npm v6.14.4)
11:11:19 AM: Started restoring cached build plugins
11:11:19 AM: Finished restoring cached build plugins
11:11:19 AM: Attempting ruby version 2.6.2, read from environment
11:11:21 AM: Using ruby version 2.6.2
11:11:21 AM: Using PHP version 5.6
11:11:21 AM: 5.2 is already installed.
11:11:21 AM: Using Swift version 5.2
11:11:21 AM: Started restoring cached node modules
11:11:24 AM: Finished restoring cached node modules
11:11:24 AM: Installing NPM modules using NPM version 6.14.4
11:11:36 AM: > core-js@2.6.11 postinstall /opt/build/repo/node_modules/core-js
11:11:36 AM: > node -e “try{require(‘./postinstall’)}catch(e){}”
11:11:36 AM: npm WARN repo No description
11:11:36 AM: npm WARN repo No repository field.
11:11:36 AM: npm WARN repo No README data
11:11:36 AM: npm WARN repo No license field.
11:11:36 AM: added 92 packages from 81 contributors in 11.086s
11:11:36 AM: 13 packages are looking for funding
11:11:36 AM: run npm fund for details
11:11:36 AM: found 0 vulnerabilities
11:11:36 AM: NPM modules installed
11:11:36 AM: Started restoring cached go cache
11:11:36 AM: Finished restoring cached go cache
11:11:36 AM: Installing Go version 1.12
11:11:41 AM: unset GOOS;
11:11:41 AM: unset GOARCH;
11:11:41 AM: export GOROOT=‘/opt/buildhome/.gimme_cache/versions/go1.12.linux.amd64’;
11:11:41 AM: export PATH=“/opt/buildhome/.gimme_cache/versions/go1.12.linux.amd64/bin:${PATH}”;
11:11:41 AM: go version >&2;
11:11:41 AM: export GIMME_ENV=“/opt/buildhome/.gimme_cache/env/go1.12.linux.amd64.env”
11:11:41 AM: go version go1.12 linux/amd64
11:11:41 AM: Installing missing commands
11:11:41 AM: Verify run directory
11:11:43 AM:
11:11:43 AM: ┌─────────────────────────────┐
11:11:43 AM: │ Netlify Build │
11:11:43 AM: └─────────────────────────────┘
11:11:43 AM:
11:11:43 AM: ❯ Version
11:11:43 AM: @netlify/build 2.0.10
11:11:43 AM:
11:11:43 AM: ❯ Flags
11:11:43 AM: deployId: 5ef8dd2f240cd513f9a474ac
11:11:43 AM: mode: buildbot
11:11:43 AM:
11:11:43 AM: ❯ Current directory
11:11:43 AM: /opt/build/repo
11:11:43 AM:
11:11:43 AM: ❯ Config file
11:11:43 AM: No config file was defined: using default values.
11:11:43 AM:
11:11:43 AM: ❯ Context
11:11:43 AM: production
11:11:43 AM:
11:11:43 AM: ┌────────────────────────────────┐
11:11:43 AM: │ 1. Build command from settings │
11:11:43 AM: └────────────────────────────────┘
11:11:43 AM:
11:11:43 AM: $ gatsby build
11:11:43 AM: bash: gatsby: command not found
11:11:43 AM:
11:11:43 AM: │ “build.command” failed │
11:11:43 AM:
11:11:43 AM: Error message
11:11:43 AM: Command failed with exit code 127: gatsby build
11:11:43 AM:
11:11:43 AM: Error location
11:11:43 AM: In Build command from settings:
11:11:43 AM: gatsby build
11:11:43 AM:
11:11:43 AM: Resolved config
11:11:43 AM: build:
11:11:43 AM: command: gatsby build
11:11:43 AM: publish: /opt/build/repo/public
11:11:43 AM: Caching artifacts
11:11:43 AM: Started saving node modules
11:11:43 AM: Finished saving node modules
11:11:43 AM: Started saving build plugins
11:11:43 AM: Finished saving build plugins
11:11:43 AM: Started saving pip cache
11:11:50 AM: Finished saving pip cache
11:11:50 AM: Started saving emacs cask dependencies
11:11:50 AM: Finished saving emacs cask dependencies
11:11:50 AM: Started saving maven dependencies
11:11:50 AM: Finished saving maven dependencies
11:11:50 AM: Started saving boot dependencies
11:11:50 AM: Finished saving boot dependencies
11:11:51 AM: Started saving go dependencies
11:11:52 AM: Finished saving go dependencies
11:11:55 AM: Error running command: Build script returned non-zero exit code: 1
11:11:55 AM: Failing build: Failed to build site
11:11:55 AM: Failed during stage ‘building site’: Build script returned non-zero exit code: 1
11:11:55 AM: Finished processing build request in 57.514287866s
