Hi
I try to configure Netlify builds and deployments with the Netlify CLI for a sample Next.js project. Running a build on Netlify via GitHub works as expected, but with the Netlify CLI, I have a few questions.
My netlify.toml looks like this:
[[plugins]]
package = "@netlify/plugin-nextjs"
I get this error when running netlify build
> netlify build
Netlify Build
❯ Version
@netlify/build 29.39.1
❯ Flags
dry: false
offline: false
❯ Current directory
C:\Users\paula\git\next-app-test-2
❯ Config file
C:\Users\paula\git\next-app-test-2\netlify.toml
❯ Context
production
❯ Using Next.js Runtime - v5.2.1
@netlify/plugin-nextjs (onPreBuild event)
(@netlify/plugin-nextjs onPreBuild completed in 14ms)
build.command automatically detected
$ npm run build
> next-app-test@0.1.0 build
> next build
▲ Next.js 14.2.3
Creating an optimized production build ...
✓ Compiled successfully
✓ Linting and checking validity of types
✓ Collecting page data
✓ Generating static pages (5/5)
✓ Collecting build traces
✓ Finalizing page optimization
Route (app) Size First Load JS
┌ ○ / 5.29 kB 92.2 kB
└ ○ /_not-found 871 B 87.8 kB
+ First Load JS shared by all 87 kB
├ chunks/23-0627c91053ca9399.js 31.5 kB
├ chunks/fd9d1056-2821b0f0cabcd8bd.js 53.6 kB
└ other shared chunks (total) 1.86 kB
○ (Static) prerendered as static content
(build.command completed in 38.9s)
@netlify/plugin-nextjs (onBuild event)
@netlify/plugin-nextjs (onEnd event)
(@netlify/plugin-nextjs onEnd completed in 24ms)
Save updated config
(options.onEnd completed in 5ms)
Plugin "@netlify/plugin-nextjs" failed
Error message
Error: Your publish directory cannot be the same as the base directory of your site. Please check your build settings
Plugin details
Package: @netlify/plugin-nextjs
Version: 5.2.1
Repository: git+https://github.com/netlify/next-runtime-minimal.git
npm link: https://www.npmjs.com/package/@netlify/plugin-nextjs
Report issues: https://github.com/netlify/next-runtime-minimal/issues
Error location
In "onBuild" event in "@netlify/plugin-nextjs" from netlify.toml
Resolved config
build:
command: npm run build
commandOrigin: heuristics
publish: C:\Users\paula\git\next-app-test-2
publishOrigin: default
plugins:
- inputs: {}
origin: config
package: '@netlify/plugin-nextjs'
Thus, I set the publish
directory as follows (as the npm build command):
[build]
command = "npm run build"
publish = ".next"
The netlify build
command then runs fine. If I then deploy with netlify build
, the site misses assets like the icons. This can be seen here:
Instead, the content to be deployed lives in the directory .netlify/static
. In order this content gets deployed when running netlify deploy
, I have to set this in netlify.toml:
[build]
publish = ".netlify/static"
[[plugins]]
Now, all assets are available as expected:
But I doubt it is in the creator’s sense to change the publish directory configuration in netlify.toml between building the application and deploying it. What configurations must be set in netlify.toml in order I can build and deploy the site with Netlify CLI?
The code of the Next.js project lives in this repo here:
