Hey Guys -
So I have a small Next.js app I’m trying to deploy to Netlify. My company uses Azure Devops as a repo, which isn’t in Netlify’s GUI walkthrough from hooking up a deployment, so I was just manually uploading it. However, I can’t seem to get the build/deployment correct.
It gives me a ‘Page Not Found’ screen.
I installed the Essential Next.js plugin onto my Netlify site and created a netlify.toml with the following for a build:
[build]
publish = “.next”
[[plugins]]
package = “@netlify/plugin-nextjs”
After that for manual deployment, I just drag my project file onto the deployment screen in Netlify.
Is there a step I’m missing? I thought the plugin would initiate the build automatically, but it doesn’t seem to be doing so.
Any help and guidance would be greatly appriciated.
Thanks
