Hello,
Since few weeks (months?) now, every PR or commit pushed to master fail to automatically deploy on Netlify.
But when I do a manual “clear cache and retry” it always works from the Netlify console.
Here is a failing build:
Full log
9:56:40 AM: build-image version: a66d98133c6610c76fed63f8e57709f519467750 (focal)
9:56:40 AM: buildbot version: a66d98133c6610c76fed63f8e57709f519467750
9:56:40 AM: Fetching cached dependencies
9:56:40 AM: Starting to download cache of 127.7MB
9:56:41 AM: Finished downloading cache in 1.291s
9:56:41 AM: Starting to extract cache
9:56:42 AM: Finished extracting cache in 882ms
9:56:42 AM: Finished fetching cache in 2.237s
9:56:42 AM: Starting to prepare the repo for build
9:56:42 AM: Preparing Git Reference pull/135/head
9:56:44 AM: Starting to install dependencies
9:56:44 AM: Python version set to 3.8
9:56:44 AM: Attempting Ruby version 2.7.8, read from environment
9:56:44 AM: Started restoring cached Ruby version
9:56:44 AM: Finished restoring cached Ruby version
9:56:45 AM: Using Ruby version 2.7.8
9:56:45 AM: Using Bundler version 1.17.3 from Gemfile.lock
9:56:46 AM: Started restoring cached ruby gems
9:56:46 AM: Finished restoring cached ruby gems
9:56:46 AM: Installing gem bundle
9:56:47 AM: Fetching gem metadata from https://rubygems.org/.........
9:56:47 AM: Using concurrent-ruby 1.2.2
9:56:47 AM: Fetching i18n 1.14.1
9:56:47 AM: Installing i18n 1.14.1
9:56:47 AM: Using minitest 5.14.1
9:56:47 AM: Using thread_safe 0.3.6
9:56:47 AM: Using tzinfo 1.2.10
9:56:47 AM: Using activesupport 5.2.4.3
9:56:47 AM: Using public_suffix 5.0.1
9:56:47 AM: Using addressable 2.8.4
9:56:47 AM: Using httpclient 2.8.3
9:56:47 AM: Using json 2.3.1
9:56:47 AM: Using algoliasearch 1.27.5
9:56:47 AM: Using bundler 1.17.3
9:56:47 AM: Using fast-stemmer 1.0.2
9:56:47 AM: Using matrix 0.4.2
9:56:47 AM: Using classifier-reborn 2.3.0
9:56:47 AM: Using colorator 1.1.0
9:56:47 AM: Using crass 1.0.6
9:56:47 AM: Using eventmachine 1.2.7
9:56:47 AM: Using http_parser.rb 0.8.0
9:56:47 AM: Using em-websocket 0.5.3
9:56:47 AM: Using execjs 2.7.0
9:56:47 AM: Using forwardable-extended 2.6.0
9:56:47 AM: Using extras 0.3.0
9:56:47 AM: Using fastimage 2.1.7
9:56:47 AM: Using ffi 1.15.5
9:56:48 AM: Using flickraw 0.9.10
9:56:48 AM: Using gsl 2.1.0.3
9:56:48 AM: Using rb-fsevent 0.11.2
9:56:48 AM: Using rb-inotify 0.10.1
9:56:48 AM: Using sass-listen 4.0.0
9:56:48 AM: Using sass 3.7.4
9:56:48 AM: Using jekyll-sass-converter 1.5.2
9:56:48 AM: Using listen 3.8.0
9:56:48 AM: Using jekyll-watch 2.2.1
9:56:48 AM: Using rexml 3.2.5
9:56:48 AM: Using kramdown 2.4.0
9:56:48 AM: Using liquid 4.0.4
9:56:48 AM: Using mercenary 0.3.6
9:56:48 AM: Using pathutil 0.16.2
9:56:48 AM: Using rouge 3.30.0
9:56:48 AM: Using safe_yaml 1.0.5
9:56:48 AM: Using jekyll 3.9.3
9:56:48 AM: Using jekyll-sanity 1.2.0
9:56:48 AM: Using liquid-tag-parser 1.9.0
9:56:48 AM: Using mini_portile2 2.8.2
9:56:48 AM: Using racc 1.6.2
9:56:48 AM: Fetching nokogiri 1.15.2 (x86_64-linux)
9:56:48 AM: Installing nokogiri 1.15.2 (x86_64-linux)
9:56:48 AM: Using rack 2.2.7
9:56:48 AM: Using sprockets 3.7.2
9:56:48 AM: Using jekyll-assets 3.0.12
9:56:48 AM: Using jekyll-paginate 1.1.0
9:56:48 AM: Using jekyll-sitemap 1.4.0
9:56:48 AM: Fetching loofah 2.21.3
9:56:48 AM: Installing loofah 2.21.3
9:56:48 AM: Fetching rails-html-sanitizer 1.6.0
9:56:48 AM: Installing rails-html-sanitizer 1.6.0
9:56:48 AM: Using redcarpet 3.6.0
9:56:48 AM: Using uglifier 4.2.0
9:56:48 AM: Bundle complete! 14 Gemfile dependencies, 56 gems now installed.
9:56:48 AM: Bundled gems are installed into `/opt/build/cache/bundle`
9:56:48 AM: Gem bundle installed
9:56:48 AM: Started restoring cached go cache
9:56:48 AM: Finished restoring cached go cache
9:56:48 AM: Installing Go version 1.12 (requested 1.12)
9:56:52 AM: go version go1.12 linux/amd64
9:56:53 AM: Using PHP version 8.0
9:56:53 AM: Started restoring cached Node.js version
9:56:54 AM: Finished restoring cached Node.js version
9:56:54 AM: v10.24.1 is already installed.
9:56:55 AM: Now using node v10.24.1 (npm v6.14.12)
9:56:55 AM: Started restoring cached build plugins
9:56:55 AM: Finished restoring cached build plugins
9:56:55 AM: Install dependencies script success
9:56:55 AM: Starting build script
9:56:56 AM: Detected 0 framework(s)
9:56:56 AM: Section completed: initializing
9:56:57 AM:
9:56:57 AM: Netlify Build
9:56:57 AM: ────────────────────────────────────────────────────────────────
9:56:57 AM:
9:56:57 AM: ❯ Version
9:56:57 AM: @netlify/build 29.11.7
9:56:57 AM:
9:56:57 AM: ❯ Flags
9:56:57 AM: baseRelDir: false
9:56:57 AM: buildId: 647d95360939cc0008cfd64d
9:56:57 AM: deployId: 647d95360939cc0008cfd64f
9:56:57 AM:
9:56:57 AM: ❯ Current directory
9:56:57 AM: /opt/build/repo
9:56:57 AM:
9:56:57 AM: ❯ Config file
9:56:57 AM: No config file was defined: using default values.
9:56:57 AM:
9:56:57 AM: ❯ Context
9:56:57 AM: deploy-preview
9:56:57 AM:
9:56:57 AM: Build command from Netlify app
9:56:57 AM:
9:56:57 AM: $ cp _config.yml.dist _config.yml && rake site:build && jekyll build
9:56:58 AM: Failed during stage 'building site': Build script returned non-zero exit code: 2 (https://ntl.fyi/exit-code-2)
9:56:58 AM: /opt/buildhome/.rvm/rubies/ruby-2.7.8/lib/ruby/2.7.0/rubygems.rb:277:in `find_spec_for_exe': can't find gem rake (>= 0.a) with executable rake (Gem::GemNotFoundException)
from /opt/buildhome/.rvm/rubies/ruby-2.7.8/lib/ruby/2.7.0/rubygems.rb:296:in `activate_bin_path'
from /opt/buildhome/.rvm/rubies/ruby-2.7.8/bin/rake:29:in `<main>'
9:56:58 AM: "build.command" failed
9:56:58 AM: ────────────────────────────────────────────────────────────────
9:56:58 AM:
9:56:58 AM: Error message
9:56:58 AM: Command failed with exit code 1: cp _config.yml.dist _config.yml && rake site:build && jekyll build (https://ntl.fyi/exit-code-1)
9:56:58 AM:
9:56:58 AM: Error location
9:56:58 AM: In Build command from Netlify app:
9:56:58 AM: cp _config.yml.dist _config.yml && rake site:build && jekyll build
9:56:58 AM:
9:56:58 AM: Resolved config
9:56:58 AM: build:
9:56:58 AM: command: cp _config.yml.dist _config.yml && rake site:build && jekyll build
9:56:58 AM: commandOrigin: ui
9:56:58 AM: environment:
9:56:58 AM: - ALGOLIA_API_KEY
9:56:58 AM: - ALGOLIA_APP_ID
9:56:58 AM: - FLICKR_ACCESS_SECRET
9:56:58 AM: - FLICKR_ACCESS_TOKEN
9:56:58 AM: - FLICKR_API_KEY
9:56:58 AM: - FLICKR_CACHE_ZIP_URL
9:56:58 AM: - FLICKR_SHARED_SECRET
9:56:58 AM: - REVIEW_ID
9:56:58 AM: - RUBY_VERSION
9:56:58 AM: publish: /opt/build/repo/_site
9:56:58 AM: publishOrigin: ui
9:56:58 AM: Caching artifacts
9:56:58 AM: Started saving ruby gems
9:56:58 AM: Finished saving ruby gems
9:56:58 AM: Started saving build plugins
9:56:58 AM: Finished saving build plugins
9:56:58 AM: Started saving pip cache
9:56:58 AM: Finished saving pip cache
9:56:58 AM: Started saving emacs cask dependencies
9:56:58 AM: Finished saving emacs cask dependencies
9:56:58 AM: Started saving maven dependencies
9:56:58 AM: Finished saving maven dependencies
9:56:58 AM: Started saving boot dependencies
9:56:58 AM: Finished saving boot dependencies
9:56:58 AM: Started saving rust rustup cache
9:56:58 AM: Finished saving rust rustup cache
9:56:58 AM: Started saving go dependencies
9:56:58 AM: Finished saving go dependencies
9:56:58 AM: Build failed due to a user error: Build script returned non-zero exit code: 2
9:56:58 AM: Failing build: Failed to build site
9:56:59 AM: Finished processing build request in 18.932s
And here is a working build when clearing cache manually (image posted as a link because I can’t embed more than one media).
Full log
10:23:50 AM: build-image version: a66d98133c6610c76fed63f8e57709f519467750 (focal)
10:23:50 AM: buildbot version: a66d98133c6610c76fed63f8e57709f519467750
10:23:50 AM: Building without cache
10:23:50 AM: Starting to prepare the repo for build
10:23:51 AM: No cached dependencies found. Cloning fresh repo
10:23:51 AM: git clone --filter=blob:none https://github.com/j0k3r/wildtrip-blog
10:23:51 AM: Preparing Git Reference refs/heads/blog
10:23:53 AM: Starting to install dependencies
10:23:53 AM: Python version set to 3.8
10:23:53 AM: Attempting Ruby version 2.7.8, read from environment
10:23:54 AM: Required ruby-2.7.8 is not installed - installing.
10:23:54 AM: Searching for binary rubies, this might take some time.
10:23:55 AM: Found remote file https://rubies.travis-ci.org/ubuntu/20.04/x86_64/ruby-2.7.8.tar.bz2
10:23:55 AM: Checking requirements for ubuntu.
10:23:55 AM: Requirements installation successful.
10:23:56 AM: ruby-2.7.8 - #configure
10:23:56 AM: ruby-2.7.8 - #download
10:23:57 AM: No checksum for downloaded archive, recording checksum in user configuration.
10:23:57 AM: ruby-2.7.8 - #validate archive
10:23:59 AM: ruby-2.7.8 - #extract
10:24:01 AM: ruby-2.7.8 - #validate binary
10:24:01 AM: ruby-2.7.8 - #setup
10:24:01 AM: ruby-2.7.8 - #gemset created /opt/buildhome/.rvm/gems/ruby-2.7.8@global
10:24:01 AM: ruby-2.7.8 - #importing gemset /opt/buildhome/.rvm/gemsets/global.gems........................................
10:24:02 AM: ruby-2.7.8 - #generating global wrappers........
10:24:02 AM: ruby-2.7.8 - #gemset created /opt/buildhome/.rvm/gems/ruby-2.7.8
10:24:02 AM: ruby-2.7.8 - #importing gemsetfile /opt/buildhome/.rvm/gemsets/default.gems evaluated to empty gem list
10:24:02 AM: ruby-2.7.8 - #generating default wrappers........
10:24:02 AM: Using /opt/buildhome/.rvm/gems/ruby-2.7.8
10:24:03 AM: Using Ruby version 2.7.8
10:24:03 AM: Using Bundler version 1.17.3 from Gemfile.lock
10:24:15 AM: Successfully installed bundler-1.17.3
10:24:15 AM: 1 gem installed
10:24:15 AM: Started restoring cached ruby gems
10:24:15 AM: Finished restoring cached ruby gems
10:24:15 AM: Installing gem bundle
10:24:17 AM: Fetching gem metadata from https://rubygems.org/.........
10:24:17 AM: Fetching concurrent-ruby 1.2.2
10:24:17 AM: Installing concurrent-ruby 1.2.2
10:24:17 AM: Fetching i18n 1.14.0
10:24:17 AM: Installing i18n 1.14.0
10:24:17 AM: Fetching minitest 5.14.1
10:24:17 AM: Installing minitest 5.14.1
10:24:17 AM: Fetching thread_safe 0.3.6
10:24:17 AM: Installing thread_safe 0.3.6
10:24:17 AM: Fetching tzinfo 1.2.10
10:24:17 AM: Installing tzinfo 1.2.10
10:24:17 AM: Fetching activesupport 5.2.4.3
10:24:17 AM: Installing activesupport 5.2.4.3
10:24:17 AM: Fetching public_suffix 5.0.1
10:24:17 AM: Installing public_suffix 5.0.1
10:24:17 AM: Fetching addressable 2.8.4
10:24:17 AM: Installing addressable 2.8.4
10:24:17 AM: Fetching httpclient 2.8.3
10:24:18 AM: Installing httpclient 2.8.3
10:24:18 AM: Fetching json 2.3.1
10:24:18 AM: Installing json 2.3.1 with native extensions
10:24:19 AM: Fetching algoliasearch 1.27.5
10:24:19 AM: Installing algoliasearch 1.27.5
10:24:19 AM: Using bundler 1.17.3
10:24:19 AM: Fetching fast-stemmer 1.0.2
10:24:20 AM: Installing fast-stemmer 1.0.2 with native extensions
10:24:20 AM: Fetching matrix 0.4.2
10:24:20 AM: Installing matrix 0.4.2
10:24:20 AM: Fetching classifier-reborn 2.3.0
10:24:20 AM: Installing classifier-reborn 2.3.0
10:24:20 AM: Fetching colorator 1.1.0
10:24:20 AM: Installing colorator 1.1.0
10:24:20 AM: Fetching crass 1.0.6
10:24:20 AM: Installing crass 1.0.6
10:24:20 AM: Fetching eventmachine 1.2.7
10:24:20 AM: Installing eventmachine 1.2.7 with native extensions
10:24:32 AM: Fetching http_parser.rb 0.8.0
10:24:32 AM: Installing http_parser.rb 0.8.0 with native extensions
10:24:33 AM: Fetching em-websocket 0.5.3
10:24:33 AM: Installing em-websocket 0.5.3
10:24:33 AM: Fetching execjs 2.7.0
10:24:33 AM: Installing execjs 2.7.0
10:24:33 AM: Fetching forwardable-extended 2.6.0
10:24:33 AM: Installing forwardable-extended 2.6.0
10:24:33 AM: Fetching extras 0.3.0
10:24:33 AM: Installing extras 0.3.0
10:24:33 AM: Fetching fastimage 2.1.7
10:24:34 AM: Installing fastimage 2.1.7
10:24:34 AM: Fetching ffi 1.15.5
10:24:34 AM: Installing ffi 1.15.5 with native extensions
10:24:39 AM: Fetching flickraw 0.9.10
10:24:39 AM: Installing flickraw 0.9.10
10:24:39 AM: Fetching gsl 2.1.0.3
10:24:39 AM: Installing gsl 2.1.0.3 with native extensions
10:25:14 AM: Fetching rb-fsevent 0.11.2
10:25:14 AM: Installing rb-fsevent 0.11.2
10:25:14 AM: Fetching rb-inotify 0.10.1
10:25:14 AM: Installing rb-inotify 0.10.1
10:25:14 AM: Fetching sass-listen 4.0.0
10:25:14 AM: Installing sass-listen 4.0.0
10:25:14 AM: Fetching sass 3.7.4
10:25:14 AM: Installing sass 3.7.4
10:25:14 AM: Fetching jekyll-sass-converter 1.5.2
10:25:14 AM: Installing jekyll-sass-converter 1.5.2
10:25:14 AM: Fetching listen 3.8.0
10:25:14 AM: Installing listen 3.8.0
10:25:14 AM: Fetching jekyll-watch 2.2.1
10:25:14 AM: Installing jekyll-watch 2.2.1
10:25:14 AM: Fetching rexml 3.2.5
10:25:14 AM: Installing rexml 3.2.5
10:25:14 AM: Fetching kramdown 2.4.0
10:25:14 AM: Installing kramdown 2.4.0
10:25:15 AM: Fetching liquid 4.0.4
10:25:15 AM: Installing liquid 4.0.4
10:25:15 AM: Fetching mercenary 0.3.6
10:25:15 AM: Installing mercenary 0.3.6
10:25:15 AM: Fetching pathutil 0.16.2
10:25:15 AM: Installing pathutil 0.16.2
10:25:15 AM: Fetching rouge 3.30.0
10:25:15 AM: Installing rouge 3.30.0
10:25:15 AM: Fetching safe_yaml 1.0.5
10:25:15 AM: Installing safe_yaml 1.0.5
10:25:15 AM: Fetching jekyll 3.9.3
10:25:15 AM: Installing jekyll 3.9.3
10:25:15 AM: Fetching jekyll-sanity 1.2.0
10:25:15 AM: Installing jekyll-sanity 1.2.0
10:25:15 AM: Fetching liquid-tag-parser 1.9.0
10:25:15 AM: Installing liquid-tag-parser 1.9.0
10:25:15 AM: Fetching mini_portile2 2.8.2
10:25:15 AM: Installing mini_portile2 2.8.2
10:25:15 AM: Fetching racc 1.6.2
10:25:15 AM: Installing racc 1.6.2 with native extensions
10:25:16 AM: Fetching nokogiri 1.15.2 (x86_64-linux)
10:25:16 AM: Installing nokogiri 1.15.2 (x86_64-linux)
10:25:17 AM: Fetching rack 2.2.7
10:25:17 AM: Installing rack 2.2.7
10:25:17 AM: Fetching sprockets 3.7.2
10:25:17 AM: Installing sprockets 3.7.2
10:25:17 AM: Fetching jekyll-assets 3.0.12
10:25:17 AM: Installing jekyll-assets 3.0.12
10:25:17 AM: Fetching jekyll-paginate 1.1.0
10:25:17 AM: Installing jekyll-paginate 1.1.0
10:25:17 AM: Fetching jekyll-sitemap 1.4.0
10:25:17 AM: Installing jekyll-sitemap 1.4.0
10:25:17 AM: Fetching loofah 2.21.3
10:25:17 AM: Installing loofah 2.21.3
10:25:17 AM: Fetching rails-html-sanitizer 1.6.0
10:25:17 AM: Installing rails-html-sanitizer 1.6.0
10:25:17 AM: Fetching redcarpet 3.6.0
10:25:17 AM: Installing redcarpet 3.6.0 with native extensions
10:25:20 AM: Fetching uglifier 4.2.0
10:25:20 AM: Installing uglifier 4.2.0
10:25:20 AM: Bundle complete! 14 Gemfile dependencies, 56 gems now installed.
10:25:20 AM: Bundled gems are installed into `/opt/build/cache/bundle`
10:25:20 AM: Post-install message from algoliasearch:
10:25:20 AM: A new major version is available for Algolia! Please now use the https://rubygems.org/gems/algolia gem to get the latest features.
10:25:20 AM: Post-install message from gsl:
10:25:20 AM: gsl can be installed with or without narray support. Please install
10:25:20 AM: narray before and reinstall gsl if it is missing.
10:25:20 AM: gsl is also now compatible with NMatrix. Please install nmatrix before
10:25:20 AM: installing gsl.
10:25:20 AM: Post-install message from sass:
10:25:20 AM: Ruby Sass has reached end-of-life and should no longer be used.
10:25:20 AM: * If you use Sass as a command-line tool, we recommend using Dart Sass, the new
10:25:20 AM: primary implementation: https://sass-lang.com/install
10:25:20 AM: * If you use Sass as a plug-in for a Ruby web framework, we recommend using the
10:25:20 AM: sassc gem: https://github.com/sass/sassc-ruby#readme
10:25:20 AM: * For more details, please refer to the Sass blog:
10:25:20 AM: https://sass-lang.com/blog/posts/7828841
10:25:20 AM: Gem bundle installed
10:25:20 AM: Started restoring cached go cache
10:25:20 AM: Finished restoring cached go cache
10:25:20 AM: Installing Go version 1.12 (requested 1.12)
10:25:24 AM: go version go1.12 linux/amd64
10:25:24 AM: Using PHP version 8.0
10:25:25 AM: Downloading and installing node v10.24.1...
10:25:25 AM: Downloading https://nodejs.org/dist/v10.24.1/node-v10.24.1-linux-x64.tar.xz...
10:25:25 AM: Computing checksum with sha256sum
10:25:26 AM: Checksums matched!
10:25:27 AM: Now using node v10.24.1 (npm v6.14.12)
10:25:27 AM: Started restoring cached build plugins
10:25:27 AM: Finished restoring cached build plugins
10:25:27 AM: Install dependencies script success
10:25:27 AM: Starting build script
10:25:28 AM: Detected 0 framework(s)
10:25:28 AM: Section completed: initializing
10:25:29 AM:
10:25:29 AM: Netlify Build
10:25:29 AM: ────────────────────────────────────────────────────────────────
10:25:29 AM:
10:25:29 AM: ❯ Version
10:25:29 AM: @netlify/build 29.11.7
10:25:29 AM:
10:25:29 AM: ❯ Flags
10:25:29 AM: baseRelDir: false
10:25:29 AM: buildId: 647d9b958261883ff0cdbebd
10:25:29 AM: deployId: 647d9b958261883ff0cdbebf
10:25:29 AM:
10:25:29 AM: ❯ Current directory
10:25:29 AM: /opt/build/repo
10:25:29 AM:
10:25:29 AM: ❯ Config file
10:25:29 AM: No config file was defined: using default values.
10:25:29 AM:
10:25:29 AM: ❯ Context
10:25:29 AM: production
10:25:29 AM:
10:25:29 AM: Build command from Netlify app
10:25:29 AM:
10:25:29 AM: $ cp _config.yml.dist _config.yml && rake site:build && jekyll build
10:25:30 AM: Deprecation: You appear to have pagination turned on, but you haven't included the `jekyll-paginate` gem. Ensure you have `plugins: [jekyll-paginate]` in your configuration file.
Configuration file: ./_config.yml
10:25:30 AM: Creating Flickr cache folder
10:25:30 AM: Download Flickr cache
10:25:31 AM: Configuration file: /opt/build/repo/_config.yml
10:25:31 AM: Source: /opt/build/repo
10:25:31 AM: Destination: /opt/build/repo/_site
10:25:31 AM: Incremental build: disabled. Enable with --incremental
10:25:31 AM: Generating...
10:25:36 AM: done in 4.984 seconds.
10:25:36 AM: Auto-regeneration: disabled. Use --watch to enable.
10:25:36 AM:
10:25:36 AM: (build.command completed in 7.1s)
10:25:36 AM:
10:25:36 AM: Deploy site
10:25:36 AM: ────────────────────────────────────────────────────────────────
10:25:36 AM:
10:25:36 AM: Starting to deploy site from '_site'
10:25:36 AM: Calculating files to upload
10:25:37 AM: 4 new files to upload
10:25:37 AM: 0 new functions to upload
10:25:37 AM: Section completed: deploying
10:25:37 AM: Site deploy was successfully initiated
10:25:37 AM:
10:25:37 AM: (Deploy site completed in 554ms)
10:25:37 AM:
10:25:37 AM: Starting post processing
10:25:37 AM: Netlify Build Complete
10:25:37 AM: ────────────────────────────────────────────────────────────────
10:25:37 AM:
10:25:37 AM: (Netlify Build completed in 7.7s)
10:25:37 AM: Skipping HTML post processing
10:25:37 AM: Post processing - header rules
10:25:37 AM: Caching artifacts
10:25:37 AM: Started saving ruby gems
10:25:37 AM: Finished saving ruby gems
10:25:37 AM: Post processing - redirect rules
10:25:37 AM: Started saving build plugins
10:25:37 AM: Finished saving build plugins
10:25:37 AM: Started saving pip cache
10:25:37 AM: Finished saving pip cache
10:25:37 AM: Started saving emacs cask dependencies
10:25:37 AM: Post processing done
10:25:37 AM: Finished saving emacs cask dependencies
10:25:37 AM: Started saving maven dependencies
10:25:37 AM: Finished saving maven dependencies
10:25:37 AM: Started saving boot dependencies
10:25:37 AM: Finished saving boot dependencies
10:25:38 AM: Section completed: postprocessing
10:25:37 AM: Started saving rust rustup cache
10:25:37 AM: Finished saving rust rustup cache
10:25:37 AM: Started saving go dependencies
10:25:37 AM: Finished saving go dependencies
10:25:38 AM: Cached Ruby version 2.7.8
10:25:38 AM: Build script success
10:25:38 AM: Section completed: building
10:25:39 AM: Site is live ✨
10:25:39 AM: Uploading Cache of size 130.4MB
10:25:40 AM: Section completed: cleanup
10:25:40 AM: Finished processing build request in 1m50.192s
BTW, I forced the Ruby version to 2.7.8.
What could be wrong?
How can I force cache clear when building automatically from GitHub? I wasn’t able to find that option in settings deploys.
My Netlify site name: wildtrip-blog.netlify.app
