Hi, I am trying to create a starter site that uses Angular 19 SSR. The site is “https://dailies2.netlify.app/”
I followed the instructions from What's new with Angular 19 on Netlify | Netlify Developers to create my project. The project deploys successfully and the index page loads in a browser.
However, when I try to access an api path like “https://dailies2.netlify.app/api/hello”, I get an error message about an edge function crashing. The edge function is ‘angular-ssr’ which I did not create directly and the only edge function that is built on the site.
Here is the error from the browser:
An unhandled error in the function code triggered the following message:
The deployment failed while serving the request.
Connection details
Netlify internal ID: 01JSJ6TJ1Q4B26MFHSBX3CMRK6
Here is the edge function log:
Additionally, here is the server.ts file in my project:
import {
AngularNodeAppEngine,
createNodeRequestHandler,
isMainModule,
writeResponseToNodeResponse,
} from '@angular/ssr/node';
import express from 'express';
import { dirname, resolve } from 'node:path';
import { fileURLToPath } from 'node:url';
import { AngularAppEngine, createRequestHandler } from '@angular/ssr'
import { getContext } from '@netlify/angular-runtime/context.mjs'
//const serverDistFolder = dirname(fileURLToPath(import.meta.url));
//const browserDistFolder = resolve(serverDistFolder, '../browser');
const app = express();
const angularApp = new AngularNodeAppEngine();
const angularAppEngine = new AngularAppEngine()
export async function netlifyAppEngineHandler(request: Request): Promise<Response> {
const context = getContext()
// Example API endpoints can be defined here.
// Uncomment and define endpoints as necessary.
const pathname = new URL(request.url).pathname;
console.log('path', pathname);
if (pathname === '/api/hello') {
return Response.json({ message: 'Hello from the API' });
const result = await angularAppEngine.handle(request, context)
return result || new Response('Not found', { status: 404 })
* Example Express Rest API endpoints can be defined here.
* Uncomment and define endpoints as necessary.
* Example:
* ```ts
* app.get('/api/**', (req, res) => {
* // Handle API request
* Serve static files from /browser
// app.use(
// express.static(browserDistFolder, {
// maxAge: '1y',
// index: false,
// redirect: false,
// app.use('/test', (req, res) => {
// res.send('test');
// * Handle all other requests by rendering the Angular application.
// app.use('/**', (req, res, next) => {
// angularApp
// .handle(req)
// .then((response) =>
// response ? writeResponseToNodeResponse(response, res) : next(),
// .catch(next);
// * Start the server if this module is the main entry point.
// * The server listens on the port defined by the `PORT` environment variable, or defaults to 4000.
// if (isMainModule(import.meta.url)) {
// const port = process.env['PORT'] || 4000;
// app.listen(port, () => {
// console.log(`Node Express server listening on http://localhost:${port}`);
* The request handler used by the Angular CLI (dev-server and during build).
//export const reqHandler = createNodeRequestHandler(app);
export const reqHandler = createRequestHandler(netlifyAppEngineHandler)
Since this is the edge function that was automatically created for Angular SSR, I don’t know where the function is “reading or writing files” as the error suggests and I can’t change the behavior to fix the error. How can I resolve this issue?
