Continuing the discussion from Exit code 255 & non-zero exit code: 2:
Can anyone help with the error below : 2:50:53 AM: build-image version: 340a5296c836ef3d99ac1d871c6447bb7a417c33 (focal)
2:50:53 AM: buildbot version: 20d735efc756356fd09bbc43982bef2018461b10
2:50:53 AM: Fetching cached dependencies
2:50:53 AM: Failed to fetch cache, continuing with build
2:50:53 AM: Starting to prepare the repo for build
2:50:53 AM: No cached dependencies found. Cloning fresh repo
2:50:53 AM: git clone --filter=blob:none https://github.com/shivamgupta6588/rwn-clothing
2:50:54 AM: Preparing Git Reference refs/heads/deva
2:50:54 AM: Parsing package.json dependencies
2:50:56 AM: Starting to install dependencies
2:50:56 AM: Python version set to 3.8
2:50:56 AM: Attempting Ruby version 2.7.2, read from environment
2:50:56 AM: Using Ruby version 2.7.2
2:50:57 AM: Started restoring cached go cache
2:50:57 AM: Finished restoring cached go cache
2:50:57 AM: Installing Go version 1.19.5 (requested 1.19.5)
2:51:02 AM: go version go1.19.5 linux/amd64
2:51:02 AM: Using PHP version 8.0
2:51:03 AM: v16.20.0 is already installed.
2:51:03 AM: Now using node v16.20.0 (npm v8.19.4)
2:51:03 AM: Enabling Node.js Corepack
2:51:03 AM: Started restoring cached build plugins
2:51:03 AM: Finished restoring cached build plugins
2:51:03 AM: Started restoring cached corepack dependencies
2:51:03 AM: Finished restoring cached corepack dependencies
2:51:03 AM: jq: error (at :75): Cannot iterate over null (null)
2:51:03 AM: No npm workspaces detected
2:51:03 AM: Started restoring cached node modules
2:51:03 AM: Finished restoring cached node modules
2:51:03 AM: Installing npm packages using npm version 8.19.4
2:51:08 AM: npm WARN deprecated w3c-hr-time@1.0.2: Use your platform’s native performance.now() and performance.timeOrigin.npm WARN deprecated stable@0.1.8: Modern JS already guarantees Array#sort() is a stable sort, so this library is deprecated. See the compatibility table on MDN: Array.prototype.sort() - JavaScript | MDN
2:51:08 AM: npm WARN deprecated sourcemap-codec@1.4.8: Please use @jridgewell/sourcemap-codec instead
2:51:08 AM: npm WARN deprecated rollup-plugin-terser@7.0.2: This package has been deprecated and is no longer maintained. Please use @rollup/plugin-terser
2:51:09 AM: npm WARN deprecated svgo@1.3.2: This SVGO version is no longer supported. Upgrade to v2.x.x.
2:51:16 AM: added 1581 packages, and audited 1582 packages in 13s
2:51:16 AM: 235 packages are looking for funding
2:51:16 AM: run npm fund for details
2:51:16 AM: 6 high severity vulnerabilities
2:51:16 AM: To address all issues (including breaking changes), run:
2:51:16 AM: npm audit fix --force
2:51:16 AM: Run npm audit for details.
2:51:16 AM: npm packages installed
2:51:16 AM: Install dependencies script success
2:51:16 AM: Starting build script
2:51:17 AM: Detected 1 framework(s)
2:51:17 AM: “create-react-app” at version “5.0.1”
2:51:17 AM: Section completed: initializing
2:51:19 AM:
2:51:19 AM: Netlify Build
2:51:19 AM: ────────────────────────────────────────────────────────────────
2:51:19 AM:
2:51:19 AM: ❯ Version
2:51:19 AM: @netlify/build 29.11.2
2:51:19 AM:
2:51:19 AM: ❯ Flags
2:51:19 AM: baseRelDir: true
2:51:19 AM: buildId: 645eadb123d90c4315c70d29
2:51:19 AM: deployId: 645eadb123d90c4315c70d2b
2:51:19 AM:
2:51:19 AM: ❯ Current directory
2:51:19 AM: /opt/build/repo
2:51:19 AM:
2:51:19 AM: ❯ Config file
2:51:19 AM: No config file was defined: using default values.
2:51:19 AM:
2:51:19 AM: ❯ Context
2:51:19 AM: production
2:51:19 AM:
2:51:19 AM: Build command from Netlify app
2:51:19 AM:
2:51:19 AM: $ npm run build
2:51:19 AM: > rwn-clothing@0.1.0 build
2:51:19 AM: > react-scripts build
2:51:20 AM: Creating an optimized production build…
2:51:37 AM:
2:51:37 AM: Treating warnings as errors because process.env.CI = true.
2:51:37 AM: Most CI servers set it automatically.
2:51:37 AM:
2:51:37 AM: Failed to compile.
2:51:37 AM:
2:51:37 AM: [eslint]
2:51:37 AM: src/App.js
2:51:37 AM: Line 2:23: ‘Outlet’ is defined but never used no-unused-vars
2:51:37 AM: src/components/navigation/navigation.component.jsx
2:51:37 AM: Line 2:10: ‘Link’ is defined but never used no-unused-vars
2:51:37 AM: src/components/sign-inform/sign-inform.component.jsx
2:51:37 AM: Line 4:3: ‘createUserDocumentFromAuth’ is defined but never used no-unused-vars
2:51:37 AM: Line 29:14: ‘user’ is assigned a value but never used no-unused-vars
2:51:37 AM: src/components/sign-upform/sign-upform.component.jsx
2:51:37 AM: Line 32:18: Expected ‘!==’ and instead saw ‘!=’ eqeqeq
2:51:37 AM: Line 43:22: Expected ‘===’ and instead saw ‘==’ eqeqeq
2:51:37 AM: src/context/user.context.jsx
2:51:37 AM: Line 17:14: ‘unsubscribe’ is assigned a value but never used no-unused-vars
2:51:37 AM: src/routes/authentication/authentication.component.jsx
2:51:37 AM: Line 10:9: ‘logGoogleUser’ is assigned a value but never used no-unused-vars
2:51:37 AM: Line 12:11: ‘userDocRef’ is assigned a value but never used no-unused-vars
2:51:37 AM: src/utils/firebase/firebase.util.js
2:51:37 AM: Line 39:7: ‘app’ is assigned a value but never used no-unused-vars
2:51:37 AM:
2:51:37 AM: “build.command” failed
2:51:37 AM: ────────────────────────────────────────────────────────────────
2:51:37 AM:
2:51:37 AM: Error message
2:51:37 AM: Command failed with exit code 1: npm run build (Search results for '"non-zero exit code: 1"' - Netlify Support Forums)
2:51:37 AM:
2:51:39 AM: Failed during stage ‘building site’: Build script returned non-zero exit code: 2 (Search results for '"non-zero exit code: 2"' - Netlify Support Forums)
2:51:37 AM: Error location
2:51:37 AM: In Build command from Netlify app:
2:51:37 AM: npm run build
2:51:37 AM:
2:51:37 AM: Resolved config
2:51:37 AM: build:
2:51:37 AM: command: npm run build
2:51:37 AM: commandOrigin: ui
2:51:37 AM: publish: /opt/build/repo/build
2:51:37 AM: publishOrigin: ui
2:51:38 AM: Caching artifacts
2:51:38 AM: Started saving node modules
2:51:38 AM: Finished saving node modules
2:51:38 AM: Started saving build plugins
2:51:38 AM: Finished saving build plugins
2:51:38 AM: Started saving corepack cache
2:51:38 AM: Finished saving corepack cache
2:51:38 AM: Started saving pip cache
2:51:38 AM: Finished saving pip cache
2:51:38 AM: Started saving emacs cask dependencies
2:51:38 AM: Finished saving emacs cask dependencies
2:51:38 AM: Started saving maven dependencies
2:51:38 AM: Finished saving maven dependencies
2:51:38 AM: Started saving boot dependencies
2:51:38 AM: Finished saving boot dependencies
2:51:38 AM: Started saving rust rustup cache
2:51:38 AM: Finished saving rust rustup cache
2:51:38 AM: Started saving go dependencies
2:51:38 AM: Finished saving go dependencies
2:51:39 AM: Build failed due to a user error: Build script returned non-zero exit code: 2
2:51:39 AM: Failing build: Failed to build site
2:51:39 AM: Finished processing build request in 46.202s
