Hi, I’m new to web dev and I’ve been trying to create and deploy a starter portfolio page in vue.js. The project works perfectly in my native browser, but when I push my commits to github I keep getting the same deployment error in the netlify console. It is as follows:
7:47:26 PM: build-image version: d7b3813f01c06610bc1723ff1b22446513ee7941 (focal)
7:47:26 PM: build-image tag: v4.14.3
7:47:26 PM: buildbot version: 4dcf475b8df8e5368becf6538fc83d1d4914f8fc
7:47:26 PM: Fetching cached dependencies
7:47:26 PM: Starting to download cache of 80.6MB
7:47:27 PM: Finished downloading cache in 1.198018352s
7:47:27 PM: Starting to extract cache
7:47:28 PM: Finished extracting cache in 591.344271ms
7:47:28 PM: Finished fetching cache in 1.836307899s
7:47:28 PM: Starting to prepare the repo for build
7:47:28 PM: Preparing Git Reference refs/heads/maintenance
7:47:28 PM: Parsing package.json dependencies
7:47:30 PM: Different publish path detected, going to use the one specified in the Netlify configuration file: 'portfolio/dist' versus 'dist' in the Netlify UI
7:47:30 PM: Starting build script
7:47:30 PM: Installing dependencies
7:47:30 PM: Python version set to 2.7
7:47:30 PM: Started restoring cached node version
7:47:31 PM: Finished restoring cached node version
7:47:31 PM: Downloading and installing node v16.18.1...
7:47:31 PM: Downloading https://nodejs.org/dist/v16.18.1/node-v16.18.1-linux-x64.tar.xz...
7:47:32 PM: Computing checksum with sha256sum
7:47:33 PM: Checksums matched!
7:47:34 PM: Now using node v16.18.1 (npm v8.19.2)
7:47:34 PM: Enabling node corepack
7:47:35 PM: Started restoring cached build plugins
7:47:35 PM: Finished restoring cached build plugins
7:47:35 PM: Attempting ruby version 2.7.2, read from environment
7:47:35 PM: Using ruby version 2.7.2
7:47:35 PM: Using PHP version 8.0
7:47:36 PM: No npm workspaces detected
7:47:36 PM: Started restoring cached node modules
7:47:36 PM: Finished restoring cached node modules
7:47:36 PM: Installing NPM modules using NPM version 8.19.2
7:47:37 PM: changed 18 packages, and audited 216 packages in 1s
7:47:37 PM: 37 packages are looking for funding
7:47:37 PM: run `npm fund` for details
7:47:37 PM: found 0 vulnerabilities
7:47:37 PM: NPM modules installed
7:47:37 PM: Creating package sha
7:47:37 PM: Started restoring cached go cache
7:47:37 PM: Finished restoring cached go cache
7:47:38 PM: Installing Go version 1.17 (requested 1.17)
7:47:43 PM: unset GOOS;
7:47:43 PM: unset GOARCH;
7:47:43 PM: export GOROOT='/opt/buildhome/.gimme/versions/go1.17.linux.amd64';
7:47:43 PM: export PATH="/opt/buildhome/.gimme/versions/go1.17.linux.amd64/bin:${PATH}";
7:47:43 PM: go version >&2;
7:47:43 PM: export GIMME_ENV="/opt/buildhome/.gimme/env/go1.17.linux.amd64.env"
7:47:43 PM: go version go1.17 linux/amd64
7:47:43 PM: Detected 1 framework(s)
7:47:43 PM: "vite" at version "3.2.2"
7:47:43 PM: Installing missing commands
7:47:43 PM: Verify run directory
7:47:44 PM:
7:47:44 PM: ────────────────────────────────────────────────────────────────
7:47:44 PM: Netlify Build
7:47:44 PM:
7:47:44 PM: ❯ Version
7:47:44 PM: @netlify/build 28.1.7
7:47:44 PM:
7:47:44 PM: ❯ Flags
7:47:44 PM: baseRelDir: true
7:47:44 PM: buildId: 63656c4b3077fd0008fe59ee
7:47:44 PM: deployId: 63656c4b3077fd0008fe59f0
7:47:44 PM:
7:47:44 PM: ❯ Current directory
7:47:44 PM: /opt/build/repo/portfolio
7:47:44 PM:
7:47:44 PM: ❯ Config file
7:47:44 PM: /opt/build/repo/portfolio/netlify.toml
7:47:44 PM:
7:47:44 PM: ❯ Context
7:47:44 PM: production
7:47:44 PM:
7:47:44 PM: 1. Build command from Netlify app
7:47:44 PM:
7:47:44 PM: $ npm run build
7:47:45 PM: > portfolio@0.0.0 build
7:47:45 PM: > vite build
7:47:45 PM: vite v3.2.2 building for production...
7:47:45 PM: transforming...
7:47:45 PM: ✓ 6 modules transformed.
7:47:45 PM: Could not resolve './views/Maintenance.vue' from src/main.js
7:47:45 PM: error during build:
7:47:45 PM: Error: Could not resolve './views/Maintenance.vue' from src/main.js
7:47:45 PM: at error (file:///opt/build/repo/portfolio/node_modules/rollup/dist/es/shared/rollup.js:1858:30)
7:47:45 PM: at ModuleLoader.handleResolveId (file:///opt/build/repo/portfolio/node_modules/rollup/dist/es/shared/rollup.js:22156:24)
7:47:45 PM: at file:///opt/build/repo/portfolio/node_modules/rollup/dist/es/shared/rollup.js:22119:26
7:47:45 PM:
7:47:45 PM: ────────────────────────────────────────────────────────────────
7:47:45 PM: "build.command" failed
7:47:45 PM:
7:47:45 PM: Error message
7:47:45 PM: Command failed with exit code 1: npm run build (https://ntl.fyi/exit-code-1)
7:47:45 PM:
7:47:45 PM: Error location
7:47:45 PM: In Build command from Netlify app:
7:47:45 PM: npm run build
7:47:45 PM:
7:47:45 PM: Resolved config
7:47:45 PM: build:
7:47:45 PM: base: /opt/build/repo/portfolio
7:47:45 PM: command: npm run build
7:47:45 PM: commandOrigin: ui
7:47:47 PM: Creating deploy upload records
7:47:45 PM: publish: /opt/build/repo/portfolio/dist
7:47:45 PM: publishOrigin: ui
7:47:45 PM: redirects:
7:47:45 PM: - from: /* status: 200 to: /index.html redirectsOrigin: configCaching artifacts
7:47:45 PM: Started saving node modules
7:47:47 PM: Failed during stage 'building site': Build script returned non-zero exit code: 2 (https://ntl.fyi/exit-code-2)
7:47:45 PM: Finished saving node modules
7:47:45 PM: Started saving build plugins
7:47:45 PM: Finished saving build plugins
7:47:45 PM: Started saving pip cache
7:47:45 PM: Finished saving pip cache
7:47:45 PM: Started saving emacs cask dependencies
7:47:45 PM: Finished saving emacs cask dependencies
7:47:45 PM: Started saving maven dependencies
7:47:46 PM: Finished saving maven dependencies
7:47:46 PM: Started saving boot dependencies
7:47:46 PM: Finished saving boot dependencies
7:47:46 PM: Started saving rust rustup cache
7:47:46 PM: Finished saving rust rustup cache
7:47:46 PM: Started saving go dependencies
7:47:46 PM: Finished saving go dependencies
7:47:46 PM: Build failed due to a user error: Build script returned non-zero exit code: 2
7:47:47 PM: Failing build: Failed to build site
7:47:47 PM: Finished processing build request in 20.843714057s
I am sure that I have imported all files correctly, so I am wondering what this error might relate to and why it may have come about. I’d appreciate any help at all ![]()
Thanks in advance!
