Vue.JS routing issue where URIs with more than one q param do not route on page reload
Vue.JS routing issue where URIs with more than one q param do not route on page reload but load a blank page that is a 404 in the dev tools->network tab.
  1. I am not using Netlify functions or other advanced routing.
  2. I have a _redirects file that is verified to be in the root directory of the latest deploy file browser (adjacent the the index.html file) and contains:
    /assets/* /assets/:splat 200
    /* /index.html 200
  3. The vue.JS router/index.js file is using web history.
import { createRouter, createWebHistory } from ‘vue-router’;
const router = createRouter({
history: createWebHistory(),
routes: [
path: ‘/’,
component: HomeView,
  1. in the deploy summary, I see:
    2 redirect rules processed
    All redirect rules deployed without errors.
  2. If I reload a page that is two q params deep then in browser dev tools->console I see:
    Failed to load module script: Expected a JavaScript-or-Wasm module script but the server responded with a MIME type of “text/html”. Strict MIME type checking is enforced for module scripts per HTML spec.
    index-DN-zPD7V.js:1
    Which in the dev tool->network tab is located at https://elliott-cv3.netlify.app/course/assets/index-DN-zPD7V.js but in the deploy file browser is located at https://elliott-cv3.netlify.app/assets/index-DN-zPD7V.js
  3. My vite config.js file reads as follows:
    import { fileURLToPath, URL } from 'node:url'
    import { defineConfig } from 'vite'
    import vue from '@vitejs/plugin-vue'
    import vueDevTools from 'vite-plugin-vue-devtools'
    import tailwindcss from '@tailwindcss/vite'
    export default defineConfig({
      plugins: [
        vue(),
        vueDevTools(),
        tailwindcss(),
      resolve: {
        alias: {
          '@': fileURLToPath(new URL('./src', import.meta.url))
      build: {
        assetsDir: 'assets',
        outDir: 'dist'
      base: './'
  4. if I try and force the route then nothing loads./assets/* /assets/:splat 200
    /* /index.html 200!
Any help in understanding why this routing is going wrong would be greatly appreciated. TIA.
You don’t need the first redirect at all. Only the second one is needed.
No, I have already tried this and the issue is exactly the same.
Feel free to share a minimal reproduction of the issue and we can check.
HEllo, I have rebuilt the App to only have one URI Q param as a workaround. Not sure what you mean by provide a minimum build to reproduce the issue? Is there a specific code block or file that I can add that would help troubleshoot? I am not sure of what you are asking for exactly.
Hi EL,
My guess here is in your Vite config. Having your “base” set to ‘./’ is I think what causes the confusion in redirection. Maybe turning your base to just ‘/’ would have difference but I see that you have worked on a work around and I think its great!.
Best of luck!
Kiyo
huge huge thanks. yes the dot before the base url in the vite config file was the issue. Again, huge huge thanks.
