Using PDFKit in a netlify function
Netlify Site (function only)
I’m trying to build some functions that return PDFs using PDFkit. I’ve found a few examples for implementing this directly with AWS lambdas but I’m getting the following error when running the functions server with both netlify dev & netlify functions:serve
Error: ENOENT: no such file or directory, open '/Users/blackcatstudio1/code/ts-pdfgen-lamda/.netlify/functions-serve/pdfgen/src/functions/pdfgen/data.trie'
  Object.openSync (fs.js:476:3)
  Object.readFileSync (fs.js:377:35)
  node_modules/unicode-properties/unicode-properties.cjs.js (/Users/blackcatstudio1/code/ts-pdfgen-lamda/node_modules/unicode-properties/node.js:6:33)
  __require (/Users/blackcatstudio1/code/ts-pdfgen-lamda/.netlify/functions-serve/pdfgen/src/functions/pdfgen/index.js:9:44)
  node_modules/fontkit/index.js (/Users/blackcatstudio1/code/ts-pdfgen-lamda/.netlify/functions-serve/pdfgen/src/functions/pdfgen/index.js:136732:35)
  node_modules/pdfkit/js/pdfkit.js (/Users/blackcatstudio1/code/ts-pdfgen-lamda/.netlify/functions-serve/pdfgen/src/functions/pdfgen/index.js:148922:19)
  Object.<anonymous> (/Users/blackcatstudio1/code/ts-pdfgen-lamda/functions/pdfgen/index.ts:2:25)
  Module._compile (internal/modules/cjs/loader.js:1063:30)
Any idea what might be causing this? I have the repo here - it’s the only function in the project currently. Thanks!
Hi @stordahl
The cause is related to UnicodeTrie of which there are two references in the shipped function
var trie = new UnicodeTrie(fs.readFileSync(__dirname + "/data.trie"));
// more ...
var trie = new UnicodeTrie(require("fs").readFileSync(__dirname + "/data.trie"));
There is an issue here though it is related specifically to Webpack, and another here which doesn’t have a solution per se. unicode-trie is dependency of both fontkit and linebreak which are in turn both dependencies of pdfkit. I did try the code from this thread (which the OP appears to have gotten working) with the same result as well as trying this code.
This is an old post, but I just wrestled with this issue, so in the hope that it helps others. Sort of a nuclear option, but hey, it works:
  • Copy all the triefiles into your functions directory. For me, with a functions dir of src/functions (from my project root) this was:
cp ./node_modules/fontkit/*trie src/functions
cp ./node_modules/linebreak/src/*trie src/functions
  • Then, because pdfkit will still look for its fonts, you need to copy those too:
cp -r ./node_modules/pdfkit/js/data ./node_modules/pdfkit/js/font src/functions
Now, use the included_files prop on [functions] in netlify.toml to include all that:
[functions]
  included_files = ["src/functions/**/*"]
Clever! I did some digging and it seems you can have npm doing the ‘copying’ for you, according to this post:
Thank you @mfan and @tomrutgers for chiming in here! This will definitely be beneficial for future forums members who encounter something similar. Happy building :rocket:
I’m a beginner in netlify function. I got the same error when using pdfkit. please help me to solve this issue.
Error: ENOENT: no such file or directory, open ‘/Users/goutamsamal/Documents/workspace/resume-maker/.netlify/functions-serve/pdf-maker/src/functions/data/Helvetica.afm’
Object.openSync (node:fs:590:3)
Object.readFileSync (node:fs:458:35)
Object.Helvetica (/Users/goutamsamal/Documents/workspace/resume-maker/node_modules/pdfkit/lib/font/standard.js:20:15)
new StandardFont (/Users/goutamsamal/Documents/workspace/resume-maker/node_modules/pdfkit/lib/font/standard.js:60:49)
Function.open (/Users/goutamsamal/Documents/workspace/resume-maker/node_modules/pdfkit/lib/font_factory.js:11:16)
PDFDocument.font (/Users/goutamsamal/Documents/workspace/resume-maker/node_modules/pdfkit/lib/mixins/fonts.js:51:33)
PDFDocument.initFonts (/Users/goutamsamal/Documents/workspace/resume-maker/node_modules/pdfkit/lib/mixins/fonts.js:17:12)
new PDFDocument (/Users/goutamsamal/Documents/workspace/resume-maker/node_modules/pdfkit/lib/document.js:88:10)
/Users/goutamsamal/Documents/workspace/resume-maker/functions/helper/makePdf.js:6:17
new Promise ()
import pdfDocuments from 'pdfkit';
const makePDF = async () => {
  return new Promise(resolve => {
    const doc = new pdfDocuments({
      bufferPages: true,
      autoFirstPage: false
    doc.fontSize(24)
    .text('Hello World!', 100, 100);
    doc.addPage({
      margins: {
        top: 50,
        bottom: 50,
        left: 62,
        right: 72
      layout: 'portrait'
    const buffers = []
    doc.on('data', buffers.push.bind(buffers))
    doc.on('end', () => {
      const pdf = Buffer.concat(buffers)
      resolve(pdf)
    doc.end()
export default makePDF;
import makePDF from './helper/makePdf.js'
export async function handler (event, context, callback) {
  const stream = await makePDF()
  const response = {
    statusCode: 200,
    headers: {
      /* Required for CORS support to work "*.eval.team, eval.team, *localhost*" */
      'Access-Control-Allow-Origin': '*',
      'Access-Control-Allow-Methods': 'OPTIONS, POST, GET',
      /* Required for cookies, authorization headers with HTTPS */
      'Access-Control-Allow-Credentials': true,
      'Access-Control-Allow-Headers': '*',
      'Content-Type': 'application/pdf',
      'Content-Disposition': `attachment;filename=invoice.pdf`
    body: stream.toString('base64'),
    isBase64Encoded: true
  return response
Is it a manual process?
I don’t see this path referenced anywhere in your code, have you shared the complete example?
In any case, debugging custom code is out of our Scope of Support.
