Using Netlify Dev CLI with unbundled functions and a static site
I may be conflating a few different features/docs, but I’d like to use something like this directory structure to dev locally and have Netlify deploy on github hooks:
|- functions/
    |- foo/
        |- node_modules/
        |- index.js
        |- package.json
    |- bar/
        |- node_modules/
        |- index.js
        |- package.json
|- publish/
    |- index.html
Essentially, I’d like to call both foo and bar functions from index.html while I work locally on my machine on all three. Bonus: Netlify would build and deploy as I have it now working from master branch and Github pull requests.
Maybe I’m asking for too much magic here :smile: but is this possible?
Thanks!
@tbeseda, if you configure a functions directory, this should “just work”:
This is done with the magic (okay, not really) zip-it-and-ship-it functionality in our build image.
Quoting that repo’s README below (the CLI section):
A minimal CLI version of zip-it-and-ship-it is provided for use inside the build-image, although this is automatically invoked on users behalf during builds and you typically do not need to run this yourself.
Have you configured a functions directory in netlify.toml or the UI?
Ended up being super simple. Just needed to make sure the .js file in my function subdirectory had the same file name as its parent folder: functions/foo/foo.js, functions/bar/bar.js, etc.
It mentions this in the docs but I overlooked it.
