Site name : https://owenlebec.netlify.app*
Build Log :
1:39:54 PM: build-image version: 3b96229e32b19cdf63f20dc1fc9331cd240c2d01 (focal)
1:39:54 PM: buildbot version: 3b96229e32b19cdf63f20dc1fc9331cd240c2d01
1:39:54 PM: Fetching cached dependencies
1:39:54 PM: Failed to fetch cache, continuing with build
1:39:54 PM: Starting to prepare the repo for build
1:39:54 PM: No cached dependencies found. Cloning fresh repo
1:39:54 PM: git clone --filter=blob:none https://github.com/OwenLB/portfolio-master
1:39:55 PM: Preparing Git Reference refs/heads/main
1:39:56 PM: Custom edge functions path detected. Proceeding with the specified path: ‘netlify/edge-functions’
1:39:57 PM: Starting to install dependencies
1:39:57 PM: Python version set to 3.8
1:39:57 PM: Attempting Ruby version 2.7.2, read from environment
1:39:58 PM: Using Ruby version 2.7.2
1:39:59 PM: Started restoring cached go cache
1:39:59 PM: Finished restoring cached go cache
1:39:59 PM: go version go1.19.10 linux/amd64
1:39:59 PM: Using PHP version 8.0
1:40:00 PM: v18.16.0 is already installed.
1:40:01 PM: Now using node v18.16.0 (npm v9.5.1)
1:40:01 PM: Enabling Node.js Corepack
1:40:01 PM: Started restoring cached build plugins
1:40:01 PM: Finished restoring cached build plugins
1:40:01 PM: Started restoring cached corepack dependencies
1:40:01 PM: Finished restoring cached corepack dependencies
1:40:01 PM: No npm workspaces detected
1:40:01 PM: Started restoring cached node modules
1:40:01 PM: Finished restoring cached node modules
1:40:01 PM: Installing npm packages using npm version 9.5.1
1:40:10 PM: > postinstall
1:40:10 PM: > nuxt prepare
1:40:10 PM: [log] Nuxi 3.5.0
1:40:12 PM: [success] Types generated in .nuxt
1:40:12 PM: added 804 packages, and audited 805 packages in 10s
1:40:12 PM: 200 packages are looking for funding
1:40:12 PM: run npm fund for details
1:40:12 PM: 1 high severity vulnerability
1:40:12 PM: To address all issues, run:
1:40:12 PM: npm audit fix
1:40:12 PM: Run npm audit for details.
1:40:12 PM: npm packages installed
1:40:13 PM: Install dependencies script success
1:40:13 PM: Starting build script
1:40:13 PM: Detected 1 framework(s)
1:40:14 PM: “nuxt” at version “3.6.0-28102821.c6a7527e”
1:40:14 PM: Section completed: initializing
1:40:15 PM:
1:40:15 PM: Netlify Build
1:40:15 PM: ────────────────────────────────────────────────────────────────
1:40:15 PM:
1:40:15 PM: ❯ Version
1:40:15 PM: @netlify/build 29.12.1
1:40:15 PM:
1:40:15 PM: ❯ Flags
1:40:15 PM: baseRelDir: true
1:40:15 PM: buildId: 6481be08b16c621d20ec3bef
1:40:15 PM: deployId: 6481be08b16c621d20ec3bf1
1:40:15 PM:
1:40:15 PM: ❯ Current directory
1:40:15 PM: /opt/build/repo
1:40:15 PM:
1:40:15 PM: ❯ Config file
1:40:15 PM: No config file was defined: using default values.
1:40:15 PM:
1:40:15 PM: ❯ Context
1:40:15 PM: production
1:40:15 PM:
1:40:15 PM: Build command from Netlify app
1:40:15 PM:
1:40:15 PM: $ nuxt build
1:40:15 PM: [log] Nuxi 3.5.0
1:40:15 PM: [log] Nuxt 3.5.0 with Nitro 2.4.1
1:40:17 PM: [info] Building client…
1:40:17 PM: [info] vite v4.3.9 building for production…
1:40:17 PM: [info] transforming…
1:40:20 PM: Use of eval in “node_modules/@lottiefiles/lottie-player/dist/lottie-player.esm.js” is strongly discouraged as it poses security risks and may cause issues with minification.
1:40:20 PM: [info] ✓ 301 modules transformed.
1:40:21 PM: [info] rendering chunks…
1:40:21 PM: [info] computing gzip size…
1:40:21 PM: [info] .nuxt/dist/client/_nuxt/Strawford-Regular.cf806d34.woff2 16.34 kB
1:40:21 PM: [info] .nuxt/dist/client/_nuxt/Strawford-Light.44d1ec15.woff2 16.61 kB
1:40:21 PM: [info] .nuxt/dist/client/_nuxt/Strawford-Medium.00916dd2.woff2 16.70 kB
1:40:21 PM: [info] .nuxt/dist/client/_nuxt/PPFormulaCondensed-Bold.ce6ed53c.woff2 24.42 kB
1:40:21 PM: [info] .nuxt/dist/client/_nuxt/PPFormulaCondensed-Light.a2f88c2d.woff2 24.61 kB
1:40:21 PM: [info] .nuxt/dist/client/manifest.json 27.49 kB │ gzip: 2.38 kB
1:40:21 PM: [info] .nuxt/dist/client/_nuxt/owen.3feeb77d.webp 66.18 kB
1:40:21 PM: [info] .nuxt/dist/client/_nuxt/ProseCode.e63e49c6.css 0.05 kB │ gzip: 0.07 kB
1:40:21 PM: [info] .nuxt/dist/client/_nuxt/Image.8714c36b.css 1.22 kB │ gzip: 0.45 kB
1:40:21 PM: [info] .nuxt/dist/client/_nuxt/error-component.f9070b93.css 1.25 kB │ gzip: 0.49 kB
1:40:21 PM: [info] .nuxt/dist/client/_nuxt/legal.8a493242.css 1.43 kB │ gzip: 0.54 kB
1:40:21 PM: [info] .nuxt/dist/client/_nuxt/Text.af1cac24.css 2.09 kB │ gzip: 0.73 kB
1:40:21 PM: [info] .nuxt/dist/client/_nuxt/slug.a16903c6.css 2.57 kB │ gzip: 0.86 kB
1:40:21 PM: [info] .nuxt/dist/client/_nuxt/Project.72c8c08b.css 2.75 kB │ gzip: 0.91 kB
1:40:21 PM: [info] .nuxt/dist/client/_nuxt/entry.0b568c42.css 3.15 kB │ gzip: 1.14 kB
1:40:21 PM: [info] .nuxt/dist/client/_nuxt/about.210c8b14.css 3.20 kB │ gzip: 0.79 kB
1:40:21 PM: [info] .nuxt/dist/client/_nuxt/index.17dc242b.css 6.80 kB │ gzip: 1.56 kB
1:40:21 PM: [info] .nuxt/dist/client/_nuxt/Footer.b25c9584.css 6.90 kB │ gzip: 1.18 kB
1:40:21 PM: [info] .nuxt/dist/client/_nuxt/_plugin-vue_export-helper.c27b6911.js 0.09 kB │ gzip: 0.10 kB
1:40:21 PM: [info] .nuxt/dist/client/_nuxt/DocumentDrivenNotFound.e2e802f7.js 0.16 kB │ gzip: 0.15 kB
1:40:21 PM: [info] .nuxt/dist/client/_nuxt/ProseHr.95d961eb.js 0.20 kB │ gzip: 0.18 kB
1:40:21 PM: [info] .nuxt/dist/client/_nuxt/index.20bc4a9b.js 0.23 kB │ gzip: 0.18 kB
1:40:21 PM: [info] .nuxt/dist/client/_nuxt/ProseTr.2d58c897.js 0.23 kB │ gzip: 0.19 kB
1:40:21 PM: [info] .nuxt/dist/client/_nuxt/ProseP.a67d9f56.js 0.24 kB │ gzip: 0.20 kB
1:40:21 PM: [info] .nuxt/dist/client/_nuxt/ProseUl.c56251ab.js 0.24 kB │ gzip: 0.20 kB
1:40:21 PM: [info] .nuxt/dist/client/_nuxt/ProseLi.ea56c901.js 0.24 kB │ gzip: 0.20 kB
1:40:21 PM: [info] .nuxt/dist/client/_nuxt/ProseEm.267084d1.js 0.24 kB │ gzip: 0.20 kB
1:40:21 PM: [info] .nuxt/dist/client/_nuxt/ProseTh.437a896f.js 0.24 kB │ gzip: 0.20 kB
1:40:21 PM: [info] .nuxt/dist/client/_nuxt/ProseOl.05c5ff2c.js 0.24 kB │ gzip: 0.20 kB
1:40:21 PM: [info] .nuxt/dist/client/_nuxt/ProseTd.c4bbfb78.js 0.24 kB │ gzip: 0.20 kB
1:40:21 PM: [info] .nuxt/dist/client/_nuxt/ProseCodeInline.4e7df7d1.js 0.24 kB │ gzip: 0.20 kB
1:40:21 PM: [info] .nuxt/dist/client/_nuxt/ProseTbody.fdd33ebc.js 0.24 kB │ gzip: 0.20 kB
1:40:21 PM: [info] .nuxt/dist/client/_nuxt/ProseTable.ef7b4b2d.js 0.24 kB │ gzip: 0.20 kB
1:40:21 PM: [info] .nuxt/dist/client/_nuxt/ProseThead.1ad339b5.js 0.24 kB │ gzip: 0.20 kB
1:40:21 PM: [info] .nuxt/dist/client/_nuxt/ProseStrong.41c7c838.js 0.24 kB │ gzip: 0.20 kB
1:40:21 PM: [info] .nuxt/dist/client/_nuxt/ProseBlockquote.ad9593d2.js 0.25 kB │ gzip: 0.21 kB
1:40:21 PM: [info] .nuxt/dist/client/_nuxt/DocumentDrivenEmpty.bf3b1b3a.js 0.29 kB │ gzip: 0.24 kB
1:40:21 PM: [info] .nuxt/dist/client/_nuxt/project.6be15ffb.js 0.33 kB │ gzip: 0.26 kB
1:40:21 PM: [info] .nuxt/dist/client/_nuxt/Markdown.283e44af.js 0.39 kB │ gzip: 0.28 kB
1:40:21 PM: [info] .nuxt/dist/client/_nuxt/ProseA.3696a032.js 0.39 kB │ gzip: 0.28 kB
1:40:21 PM: [info] .nuxt/dist/client/_nuxt/ProseCode.38239d85.js 0.40 kB │ gzip: 0.26 kB
1:40:21 PM: [info] .nuxt/dist/client/_nuxt/ProseH4.f15e3132.js 0.42 kB │ gzip: 0.31 kB
1:40:21 PM: [info] .nuxt/dist/client/_nuxt/ProseH3.2cd55536.js 0.42 kB │ gzip: 0.31 kB
1:40:21 PM: [info] .nuxt/dist/client/_nuxt/ProseH2.eddd39e6.js 0.42 kB │ gzip: 0.31 kB
1:40:21 PM: [info] .nuxt/dist/client/_nuxt/ProseH5.73c0433a.js 0.42 kB │ gzip: 0.31 kB
1:40:21 PM: [info] .nuxt/dist/client/_nuxt/ProseH6.f2012d94.js 0.42 kB │ gzip: 0.31 kB
1:40:21 PM: [info] .nuxt/dist/client/_nuxt/ProseH1.4259b786.js 0.42 kB │ gzip: 0.31 kB
1:40:21 PM: [info] .nuxt/dist/client/_nuxt/Image.98c7603f.js 0.52 kB │ gzip: 0.36 kB
1:40:21 PM: [info] .nuxt/dist/client/_nuxt/preview.3304c1d3.js 0.54 kB │ gzip: 0.29 kB
1:40:21 PM: [info] .nuxt/dist/client/_nuxt/ProseImg.4cf8d3fc.js 0.54 kB │ gzip: 0.34 kB
1:40:21 PM: [info] .nuxt/dist/client/_nuxt/index.a6ef77ff.js 0.62 kB │ gzip: 0.37 kB
1:40:21 PM: [info] .nuxt/dist/client/_nuxt/Text.f43ea79e.js 0.80 kB │ gzip: 0.49 kB
1:40:21 PM: [info] .nuxt/dist/client/_nuxt/ContentList.3b870ce9.js 0.95 kB │ gzip: 0.52 kB
1:40:21 PM: [info] .nuxt/dist/client/_nuxt/ContentSlot.d853bee1.js 1.03 kB │ gzip: 0.60 kB
1:40:21 PM: [info] .nuxt/dist/client/_nuxt/Project.517ff250.js 1.05 kB │ gzip: 0.61 kB
1:40:21 PM: [info] .nuxt/dist/client/_nuxt/legal.3576be5d.js 1.19 kB │ gzip: 0.70 kB
1:40:21 PM: [info] .nuxt/dist/client/_nuxt/ContentRenderer.fe82331c.js 1.26 kB │ gzip: 0.64 kB
1:40:21 PM: [info] .nuxt/dist/client/_nuxt/utils.a4978af1.js 1.42 kB │ gzip: 0.72 kB
1:40:21 PM: [info] .nuxt/dist/client/_nuxt/ContentNavigation.81195887.js 1.82 kB │ gzip: 0.95 kB
1:40:21 PM: [info] .nuxt/dist/client/_nuxt/ContentDoc.8b681903.js 2.06 kB │ gzip: 0.96 kB
1:40:21 PM: [info] .nuxt/dist/client/_nuxt/asyncData.80d2208d.js 2.25 kB │ gzip: 1.00 kB
1:40:21 PM: [info] .nuxt/dist/client/_nuxt/ContentQuery.97357860.js 2.32 kB │ gzip: 0.97 kB
1:40:21 PM: [info] .nuxt/dist/client/_nuxt/nuxt-img.9001ddc6.js 2.70 kB │ gzip: 1.06 kB
1:40:21 PM: [info] .nuxt/dist/client/_nuxt/about.5605ffdd.js 2.74 kB │ gzip: 1.39 kB
1:40:21 PM: [info] .nuxt/dist/client/_nuxt/slug.d963e115.js 2.97 kB │ gzip: 1.41 kB
1:40:21 PM: [info] .nuxt/dist/client/_nuxt/nuxt-link.137b314e.js 4.32 kB │ gzip: 1.84 kB
1:40:21 PM: [info] .nuxt/dist/client/_nuxt/Footer.vue.a831387b.js 5.92 kB │ gzip: 2.64 kB
1:40:21 PM: [info] .nuxt/dist/client/_nuxt/query.08751b2c.js 11.66 kB │ gzip: 4.91 kB
1:40:21 PM: [info] .nuxt/dist/client/_nuxt/client-db.4a0ddd7a.js 18.60 kB │ gzip: 7.85 kB
1:40:21 PM: [info] .nuxt/dist/client/_nuxt/ContentRendererMarkdown.3c348d15.js 22.42 kB │ gzip: 7.97 kB
1:40:21 PM: [info] .nuxt/dist/client/_nuxt/index.c5c5e457.js 155.00 kB │ gzip: 65.23 kB
1:40:21 PM: [info] .nuxt/dist/client/_nuxt/entry.1ca8926a.js 159.47 kB │ gzip: 58.82 kB
1:40:21 PM: [info] .nuxt/dist/client/_nuxt/error-component.1aaa535f.js 331.37 kB │ gzip: 86.25 kB
1:40:21 PM: [info] ✓ built in 3.97s
1:40:21 PM: [success] Client built in 3979ms
1:40:21 PM: [info] Building server…
1:40:21 PM: [info] vite v4.3.9 building SSR bundle for production…
1:40:21 PM: [info] transforming…
1:40:21 PM: [info] ✓ 1 modules transformed.
1:40:21 PM: [info] .nuxt/dist/server/styles.mjs 0.07 kB
1:40:21 PM: [info] .nuxt/dist/server/server.mjs 0.10 kB │ map: 0.22 kB
1:40:21 PM: [info] ✓ built in 13ms
1:40:21 PM: [success] Server built in 23ms
1:40:21 PM: [success] [nitro] Generated public dist
1:40:21 PM: [info] [nitro] Initializing prerenderer
1:40:22 PM: [info] [nitro] Prerendering 1 routes
1:40:22 PM: [warn] JSON array is not supported in content:socials.json, moving the array into the body key
1:40:22 PM: [log] [nitro] ├─ /api/_content/cache.1686224416374.json (123ms)
1:40:22 PM: [nitro] Nitro now uses isr option to configure ISR behavior on Netlify. Backwards-compatible support for static and swr support with Builder Functions will be removed in the future versions.
1:40:22 PM: [info] [nitro] Building Nitro Server (preset: netlify)
1:40:25 PM: [success] [nitro] Nitro server built
1:40:26 PM: ├─ .netlify/functions-internal/server/chunks/app/client.manifest.mjs (29.3 kB) (2.48 kB gzip)
1:40:26 PM: ├─ .netlify/functions-internal/server/chunks/app/client.manifest.mjs.map (19.2 kB) (1.55 kB gzip)
1:40:26 PM: ├─ .netlify/functions-internal/server/chunks/app/styles.mjs (86 B) (93 B gzip)
1:40:26 PM: ├─ .netlify/functions-internal/server/chunks/app/styles.mjs.map (152 B) (136 B gzip)
1:40:26 PM: ├─ .netlify/functions-internal/server/chunks/error-500.mjs (4.26 kB) (1.82 kB gzip)
1:40:26 PM: ├─ .netlify/functions-internal/server/chunks/error-500.mjs.map (1.06 kB) (392 B gzip)
1:40:26 PM: ├─ .netlify/functions-internal/server/chunks/handlers/renderer.mjs (9.73 kB) (3.15 kB gzip)
1:40:26 PM: ├─ .netlify/functions-internal/server/chunks/handlers/renderer.mjs.map (10.1 kB) (2.14 kB gzip)
1:40:26 PM: ├─ .netlify/functions-internal/server/chunks/nitro/netlify.mjs (131 kB) (34.6 kB gzip)
1:40:26 PM: ├─ .netlify/functions-internal/server/chunks/nitro/netlify.mjs.map (136 kB) (19.5 kB gzip)
1:40:26 PM: ├─ .netlify/functions-internal/server/chunks/raw/about.mjs (5.02 kB) (1.93 kB gzip)
1:40:26 PM: ├─ .netlify/functions-internal/server/chunks/raw/about.mjs.map (97 B) (100 B gzip)
1:40:26 PM: ├─ .netlify/functions-internal/server/chunks/raw/about2.mjs (5.44 kB) (2.05 kB gzip)
1:40:26 PM: ├─ .netlify/functions-internal/server/chunks/raw/about2.mjs.map (98 B) (101 B gzip)
1:40:26 PM: ├─ .netlify/functions-internal/server/chunks/raw/airbnb-mockup.mjs (1.8 kB) (848 B gzip)
1:40:26 PM: ├─ .netlify/functions-internal/server/chunks/raw/airbnb-mockup.mjs.map (105 B) (105 B gzip)
1:40:26 PM: ├─ .netlify/functions-internal/server/chunks/raw/airbnb-mockup2.mjs (1.92 kB) (900 B gzip)
1:40:26 PM: ├─ .netlify/functions-internal/server/chunks/raw/airbnb-mockup2.mjs.map (106 B) (106 B gzip)
1:40:26 PM: ├─ .netlify/functions-internal/server/chunks/raw/content-index.mjs (664 B) (269 B gzip)
1:40:26 PM: ├─ .netlify/functions-internal/server/chunks/raw/content-index.mjs.map (105 B) (103 B gzip)
1:40:26 PM: ├─ .netlify/functions-internal/server/chunks/raw/content-navigation.mjs (716 B) (354 B gzip)
1:40:26 PM: ├─ .netlify/functions-internal/server/chunks/raw/content-navigation.mjs.map (110 B) (105 B gzip)
1:40:26 PM: ├─ .netlify/functions-internal/server/chunks/raw/home.mjs (1.2 kB) (612 B gzip)
1:40:26 PM: ├─ .netlify/functions-internal/server/chunks/raw/home.mjs.map (96 B) (99 B gzip)
1:40:26 PM: ├─ .netlify/functions-internal/server/chunks/raw/home2.mjs (1.24 kB) (686 B gzip)
1:40:26 PM: ├─ .netlify/functions-internal/server/chunks/raw/home2.mjs.map (97 B) (100 B gzip)
1:40:26 PM: ├─ .netlify/functions-internal/server/chunks/raw/legal.mjs (3.91 kB) (791 B gzip)
1:40:26 PM: ├─ .netlify/functions-internal/server/chunks/raw/legal.mjs.map (97 B) (99 B gzip)
1:40:26 PM: ├─ .netlify/functions-internal/server/chunks/raw/legal2.mjs (3.92 kB) (800 B gzip)
1:40:26 PM: ├─ .netlify/functions-internal/server/chunks/raw/legal2.mjs.map (98 B) (101 B gzip)
1:40:26 PM: ├─ .netlify/functions-internal/server/chunks/raw/safewalk.mjs (5.49 kB) (1.94 kB gzip)
1:40:26 PM: ├─ .netlify/functions-internal/server/chunks/raw/safewalk.mjs.map (100 B) (102 B gzip)
1:40:26 PM: ├─ .netlify/functions-internal/server/chunks/raw/safewalk2.mjs (6.05 kB) (2.15 kB gzip)
1:40:26 PM: ├─ .netlify/functions-internal/server/chunks/raw/safewalk2.mjs.map (101 B) (103 B gzip)
1:40:26 PM: ├─ .netlify/functions-internal/server/chunks/raw/socials.mjs (538 B) (321 B gzip)
1:40:26 PM: ├─ .netlify/functions-internal/server/chunks/raw/socials.mjs.map (99 B) (100 B gzip)
1:40:26 PM: ├─ .netlify/functions-internal/server/chunks/raw/weather-app.mjs (4.85 kB) (1.51 kB gzip)
1:40:26 PM: ├─ .netlify/functions-internal/server/chunks/raw/weather-app.mjs.map (103 B) (103 B gzip)
1:40:26 PM: ├─ .netlify/functions-internal/server/chunks/raw/weather-app2.mjs (5.46 kB) (1.69 kB gzip)
1:40:26 PM: ├─ .netlify/functions-internal/server/chunks/raw/weather-app2.mjs.map (104 B) (104 B gzip)
1:40:26 PM: ├─ .netlify/functions-internal/server/chunks/rollup/_virtual_head-static.mjs (301 B) (217 B gzip)
1:40:26 PM: ├─ .netlify/functions-internal/server/chunks/rollup/_virtual_head-static.mjs.map (111 B) (112 B gzip)
1:40:26 PM: ├─ .netlify/functions-internal/server/chunks/spotify.mjs (2.7 kB) (1.06 kB gzip)
1:40:26 PM: ├─ .netlify/functions-internal/server/chunks/spotify.mjs.map (1.61 kB) (436 B gzip)
1:40:26 PM: ├─ .netlify/functions-internal/server/package.json (5.11 kB) (1.46 kB gzip)
1:40:26 PM: └─ .netlify/functions-internal/server/server.mjs (1.28 kB) (483 B gzip)
1:40:26 PM: Σ Total size: 11.1 MB (2.3 MB gzip)
1:40:26 PM:
1:40:26 PM: (build.command completed in 10.7s)
1:40:26 PM:
1:40:26 PM: Functions bundling
1:40:26 PM: ────────────────────────────────────────────────────────────────
1:40:26 PM:
1:40:26 PM: Packaging Functions from .netlify/functions-internal directory:
1:40:26 PM: - server/server.mjs
1:40:26 PM:
1:40:29 PM:
1:40:29 PM: (Functions bundling completed in 3.2s)
1:40:29 PM:
1:40:29 PM: Edge Functions bundling
1:40:29 PM: ────────────────────────────────────────────────────────────────
1:40:29 PM:
1:40:29 PM: Packaging Edge Functions from netlify/edge-functions directory:
1:40:29 PM: - spotify
1:40:32 PM:
1:40:32 PM: (Edge Functions bundling completed in 2.9s)
1:40:32 PM:
1:40:32 PM: Deploy site
1:40:32 PM: ────────────────────────────────────────────────────────────────
1:40:32 PM:
1:40:32 PM: Section completed: deploying
1:40:32 PM:
1:40:32 PM: Configuration error
1:40:32 PM:
1:40:32 PM: Error message
1:40:32 PM: Deploy did not succeed: Deploy directory ‘output’ does not exist
1:40:32 PM:
1:40:32 PM: Resolved config
1:40:32 PM: build:
1:40:32 PM: command: nuxt build
1:40:32 PM: commandOrigin: ui
1:40:32 PM: edge_functions: /opt/build/repo/netlify/edge-functions
1:40:32 PM: publish: /opt/build/repo/output
1:40:32 PM: publishOrigin: ui
1:40:33 PM: Caching artifacts
1:40:33 PM: Started saving node modules
1:40:33 PM: Finished saving node modules
1:40:33 PM: Started saving build plugins
1:40:33 PM: Finished saving build plugins
1:40:33 PM: Started saving corepack cache
1:40:33 PM: Finished saving corepack cache
1:40:33 PM: Started saving pip cache
1:40:33 PM: Finished saving pip cache
1:40:33 PM: Started saving emacs cask dependencies
1:40:33 PM: Finished saving emacs cask dependencies
1:40:33 PM: Started saving maven dependencies
1:40:33 PM: Finished saving maven dependencies
1:40:33 PM: Started saving boot dependencies
1:40:33 PM: Finished saving boot dependencies
1:40:33 PM: Started saving rust rustup cache
1:40:33 PM: Finished saving rust rustup cache
1:40:33 PM: Started saving go dependencies
1:40:33 PM: Finished saving go dependencies
1:40:34 PM: Build failed due to a user error: Build script returned non-zero exit code: 2
1:40:34 PM: Failing build: Failed to build site
1:40:34 PM: Failed during stage ‘building site’: Build script returned non-zero exit code: 2 (Search results for '"non-zero exit code: 2"' - Netlify Support Forums)
1:40:34 PM: Finished processing build request in 40.151s
I can’t upload my nuxt project, it seems that the nuxt configuration file isn’t correct.
Do you have any suggestions?
