I’m getting
TypeError: (0 , _requireHook).default is not a function
at Object.<anonymous> (/var/task/node_modules/next/dist/server/next-server.js:1160:26)
at Module._compile (node:internal/modules/cjs/loader:1105:14)
at Object.Module._extensions..js (node:internal/modules/cjs/loader:1159:10)
at Module.load (node:internal/modules/cjs/loader:981:32)
at Function.Module._load (node:internal/modules/cjs/loader:822:12)
at Module.require (node:internal/modules/cjs/loader:1005:19)
at require (node:internal/modules/cjs/helpers:102:18)
at getNextServer (/var/task/.netlify/functions-internal/___netlify-handler/handlerUtils.js:151:22)
at getBridge (/var/task/.netlify/functions-internal/___netlify-handler/___netlify-handler.js:54:28)
at Runtime.handler (/var/task/.netlify/functions-internal/___netlify-handler/___netlify-handler.js:84:46)
When I click any of my links on the sidenav the website crashes. I’m not sure why this is happening, on my local machine I click on any of the links and it filters to movies or series like it should.
