I cant get my DecapCMS up and running, I enabled indenty, to my knowledge i did all the steps, however im getting a 404 message, im using hugo starter template, and nelify any suggestions. netlify site name - https://earnmoneyonlinefree.netlify.app/
Heres my build
4:53:32 AM: Starting post processing
4:53:32 AM: Skipping HTML post processing
4:53:32 AM: Post processing - header rules
4:53:32 AM: Post processing - redirect rules
4:53:33 AM: Post processing done
4:53:33 AM: Section completed: postprocessing
4:53:34 AM: Site is live
4:53:06 AM: build-image version: 20e1f1f500e4cbad9ea8a99bd40807bef3093551 (focal)
4:53:06 AM: buildbot version: 00a030bf3c001e3c0d5d2d5931d77655af9653ed
4:53:06 AM: Fetching cached dependencies
4:53:07 AM: Starting to download cache of 188.2MB
4:53:08 AM: Finished downloading cache in 1.222s
4:53:08 AM: Starting to extract cache
4:53:09 AM: Finished extracting cache in 1.487s
4:53:09 AM: Finished fetching cache in 2.766s
4:53:09 AM: Starting to prepare the repo for build
4:53:09 AM: Preparing Git Reference refs/heads/master
4:53:11 AM: Starting to install dependencies
4:53:11 AM: Python version set to 3.8
4:53:11 AM: Attempting Ruby version 2.7.2, read from environment
4:53:12 AM: Using Ruby version 2.7.2
4:53:12 AM: Started restoring cached go cache
4:53:12 AM: Finished restoring cached go cache
4:53:13 AM: Installing Go version 1.19.12 (requested 1.19.x)
4:53:19 AM: go version go1.19.12 linux/amd64
4:53:19 AM: Using PHP version 8.0
4:53:19 AM: Installing Hugo 0.109.0
4:53:20 AM: hugo v0.109.0-47b12b83e636224e5e601813ff3e6790c191e371+extended linux/amd64 BuildDate=2022-12-23T10:38:11Z VendorInfo=gohugoio
4:53:20 AM: Started restoring cached Node.js version
4:53:21 AM: Finished restoring cached Node.js version
4:53:21 AM: v18.17.1 is already installed.
4:53:22 AM: Now using node v18.17.1 (npm v9.6.7)
4:53:22 AM: Enabling Node.js Corepack
4:53:22 AM: Started restoring cached build plugins
4:53:22 AM: Finished restoring cached build plugins
4:53:22 AM: Started restoring cached corepack dependencies
4:53:22 AM: Finished restoring cached corepack dependencies
4:53:22 AM: No npm workspaces detected
4:53:22 AM: Started restoring cached node modules
4:53:22 AM: Finished restoring cached node modules
4:53:22 AM: Installing npm packages using npm version 9.6.7
4:53:23 AM: npm WARN ERESOLVE overriding peer dependency
4:53:23 AM: npm WARN While resolving: ajv-keywords@5.1.0
4:53:23 AM: npm WARN Found: ajv@8.1.0
4:53:23 AM: npm WARN node_modules/netlify-cms-core/node_modules/ajv
4:53:23 AM: npm WARN ajv@8.1.0 from netlify-cms-core@2.55.2
4:53:23 AM: npm WARN netlify-cms-core@^2.55.2 from netlify-cms-app@2.15.72
4:53:23 AM: npm WARN node_modules/netlify-cms-app
4:53:23 AM: npm WARN 1 more (ajv-errors)
4:53:23 AM: npm WARN Could not resolve dependency:
4:53:23 AM: npm WARN peer ajv@^8.8.2 from ajv-keywords@5.1.0
4:53:23 AM: npm WARN node_modules/netlify-cms-core/node_modules/ajv-keywords
4:53:23 AM: npm WARN ajv-keywords@^5.0.0 from netlify-cms-core@2.55.2
4:53:23 AM: npm WARN Conflicting peer dependency: ajv@8.12.0
4:53:23 AM: npm WARN node_modules/ajv
4:53:23 AM: npm WARN While resolving: react-codemirror2@7.2.1
4:53:23 AM: npm WARN Found: react@17.0.2
4:53:23 AM: npm WARN node_modules/react
4:53:23 AM: npm WARN peer react@>=16.3.0 from @emotion/core@10.3.1
4:53:23 AM: npm WARN node_modules/@emotion/core
4:53:23 AM: npm WARN peer @emotion/core@^10.0.27 from @emotion/styled@10.3.0
4:53:23 AM: npm WARN node_modules/@emotion/styled
4:53:23 AM: npm WARN 23 more (@emotion/styled-base, netlify-cms-app, …)
4:53:23 AM: npm WARN 58 more (@emotion/react, @emotion/styled, @emotion/styled-base, …)
4:53:23 AM: npm WARN peer react@>=15.5 <=16.x from react-codemirror2@7.2.1
4:53:23 AM: npm WARN node_modules/netlify-cms-widget-code/node_modules/react-codemirror2
4:53:23 AM: npm WARN react-codemirror2@^7.0.0 from netlify-cms-widget-code@1.3.4
4:53:23 AM: npm WARN Conflicting peer dependency: react@16.14.0
4:53:24 AM: up to date, audited 669 packages in 2s
4:53:24 AM: 149 packages are looking for funding
4:53:24 AM: run npm fund
for details
4:53:24 AM: 6 high severity vulnerabilities
4:53:24 AM: To address issues that do not require attention, run:
4:53:24 AM: npm audit fix
4:53:24 AM: Some issues need review, and may require choosing
4:53:24 AM: a different dependency.
4:53:24 AM: Run npm audit
for details.
4:53:24 AM: npm packages installed
4:53:24 AM: Install dependencies script success
4:53:24 AM: Starting build script
4:53:25 AM: Detected 2 framework(s)
4:53:25 AM: hugo at version unknown
4:53:25 AM: zola at version unknown
4:53:25 AM: Section completed: initializing
4:53:27 AM:
4:53:27 AM: Netlify Build
4:53:27 AM: ────────────────────────────────────────────────────────────────
4:53:27 AM:
4:53:27 AM: ❯ Version
4:53:27 AM: @netlify/build 29.19.0
4:53:27 AM:
4:53:27 AM: ❯ Flags
4:53:27 AM: baseRelDir: true
4:53:27 AM: buildId: 64d8c420c143ae0008fbb4dd
4:53:27 AM: deployId: 64d8c420c143ae0008fbb4df
4:53:27 AM:
4:53:27 AM: ❯ Current directory
4:53:27 AM: /opt/build/repo
4:53:27 AM:
4:53:27 AM: ❯ Config file
4:53:27 AM: /opt/build/repo/netlify.toml
4:53:27 AM:
4:53:27 AM: ❯ Context
4:53:27 AM: production
4:53:27 AM:
4:53:27 AM: build.command from netlify.toml
4:53:27 AM:
4:53:27 AM: $ cd exampleSite && hugo --minify --gc --themesDir …/…
4:53:27 AM: Start building sites …
4:53:27 AM: hugo v0.109.0-47b12b83e636224e5e601813ff3e6790c191e371+extended linux/amd64 BuildDate=2022-12-23T10:38:11Z VendorInfo=gohugoio
4:53:32 AM: | EN
4:53:32 AM: -------------------±-----
4:53:32 AM: Pages | 52
4:53:32 AM: Paginator pages | 2
4:53:32 AM: Non-page files | 0
4:53:32 AM: Static files | 5
4:53:32 AM: Processed images | 993
4:53:32 AM: Aliases | 16
4:53:32 AM: Sitemaps | 1
4:53:32 AM: Cleaned | 0
4:53:32 AM: Total in 5052 ms
4:53:32 AM:
4:53:32 AM: (build.command completed in 5.1s)
4:53:32 AM:
4:53:32 AM: Deploy site
4:53:32 AM: ────────────────────────────────────────────────────────────────
4:53:32 AM:
4:53:32 AM: Starting to deploy site from ‘exampleSite/public’
4:53:32 AM: Calculating files to upload
4:53:32 AM: 0 new files to upload
4:53:32 AM: 0 new functions to upload
4:53:32 AM: Section completed: deploying
4:53:32 AM: Site deploy was successfully initiated
4:53:32 AM:
4:53:32 AM: (Deploy site completed in 134ms)
4:53:32 AM:
4:53:32 AM: Netlify Build Complete
4:53:32 AM:
4:53:32 AM: (Netlify Build completed in 5.3s)
4:53:32 AM: Caching artifacts
4:53:32 AM: Started saving node modules
4:53:32 AM: Finished saving node modules
4:53:32 AM: Started saving build plugins
4:53:32 AM: Finished saving build plugins
4:53:32 AM: Started saving corepack cache
4:53:32 AM: Finished saving corepack cache
4:53:32 AM: Started saving pip cache
4:53:32 AM: Finished saving pip cache
4:53:32 AM: Started saving emacs cask dependencies
4:53:33 AM: Finished saving emacs cask dependencies
4:53:33 AM: Started saving maven dependencies
4:53:33 AM: Finished saving maven dependencies
4:53:33 AM: Started saving boot dependencies
4:53:33 AM: Finished saving boot dependencies
4:53:33 AM: Started saving rust rustup cache
4:53:33 AM: Finished saving rust rustup cache
4:53:33 AM: Started saving go dependencies
4:53:33 AM: Finished saving go dependencies
4:53:33 AM: Build script success
4:53:33 AM: Section completed: building
4:53:34 AM: Uploading Cache of size 188.2MB
4:53:35 AM: Section completed: cleanup
4:53:35 AM: Finished processing build request in 28.488s
