I want to edit my blog using decap cms. However, Im not able to login after adding all the variables.
- netlify site name - https://earnmoneyonlinefree.netlify.app
*domain name https://earnonlinemoney.org
11:02:54 PM: Starting post processing
11:02:55 PM: Skipping HTML post processing
11:02:55 PM: Post processing - header rules
11:02:55 PM: Post processing - redirect rules
11:02:55 PM: Post processing done
11:02:55 PM: Section completed: postprocessing
11:02:56 PM: Site is live
11:02:28 PM: build-image version: 20e1f1f500e4cbad9ea8a99bd40807bef3093551 (focal)
11:02:28 PM: buildbot version: 00a030bf3c001e3c0d5d2d5931d77655af9653ed
11:02:28 PM: Fetching cached dependencies
11:02:28 PM: Starting to download cache of 188.3MB
11:02:30 PM: Finished downloading cache in 1.512s
11:02:30 PM: Starting to extract cache
11:02:31 PM: Finished extracting cache in 1.669s
11:02:31 PM: Finished fetching cache in 3.25s
11:02:31 PM: Starting to prepare the repo for build
11:02:31 PM: Preparing Git Reference refs/heads/master
11:02:33 PM: Starting to install dependencies
11:02:33 PM: Python version set to 3.8
11:02:33 PM: Attempting Ruby version 2.7.2, read from environment
11:02:34 PM: Using Ruby version 2.7.2
11:02:34 PM: Started restoring cached go cache
11:02:34 PM: Finished restoring cached go cache
11:02:36 PM: Installing Go version 1.19.12 (requested 1.19.x)
11:02:40 PM: go version go1.19.12 linux/amd64
11:02:40 PM: Using PHP version 8.0
11:02:40 PM: Installing Hugo 0.109.0
11:02:40 PM: hugo v0.109.0-47b12b83e636224e5e601813ff3e6790c191e371+extended linux/amd64 BuildDate=2022-12-23T10:38:11Z VendorInfo=gohugoio
11:02:41 PM: Started restoring cached Node.js version
11:02:43 PM: Finished restoring cached Node.js version
11:02:43 PM: v18.17.1 is already installed.
11:02:43 PM: Now using node v18.17.1 (npm v9.6.7)
11:02:43 PM: Enabling Node.js Corepack
11:02:43 PM: Started restoring cached build plugins
11:02:44 PM: Finished restoring cached build plugins
11:02:44 PM: Started restoring cached corepack dependencies
11:02:44 PM: Finished restoring cached corepack dependencies
11:02:44 PM: No npm workspaces detected
11:02:44 PM: Started restoring cached node modules
11:02:44 PM: Finished restoring cached node modules
11:02:44 PM: Installing npm packages using npm version 9.6.7
11:02:45 PM: npm WARN ERESOLVE overriding peer dependency
11:02:45 PM: npm WARN While resolving: ajv-keywords@5.1.0
11:02:45 PM: npm WARN Found: ajv@8.1.0
11:02:45 PM: npm WARN node_modules/netlify-cms-core/node_modules/ajv
11:02:45 PM: npm WARN ajv@8.1.0 from netlify-cms-core@2.55.2
11:02:45 PM: npm WARN netlify-cms-core@^2.55.2 from netlify-cms-app@2.15.72
11:02:45 PM: npm WARN node_modules/netlify-cms-app
11:02:45 PM: npm WARN 1 more (ajv-errors)
11:02:45 PM: npm WARN Could not resolve dependency:
11:02:45 PM: npm WARN peer ajv@^8.8.2 from ajv-keywords@5.1.0
11:02:45 PM: npm WARN node_modules/netlify-cms-core/node_modules/ajv-keywords
11:02:45 PM: npm WARN ajv-keywords@^5.0.0 from netlify-cms-core@2.55.2
11:02:45 PM: npm WARN Conflicting peer dependency: ajv@8.12.0
11:02:45 PM: npm WARN node_modules/ajv
11:02:45 PM: npm WARN While resolving: react-codemirror2@7.2.1
11:02:45 PM: npm WARN Found: react@17.0.2
11:02:45 PM: npm WARN node_modules/react
11:02:45 PM: npm WARN peer react@>=16.3.0 from @emotion/core@10.3.1
11:02:45 PM: npm WARN node_modules/@emotion/core
11:02:45 PM: npm WARN peer @emotion/core@^10.0.27 from @emotion/styled@10.3.0
11:02:45 PM: npm WARN node_modules/@emotion/styled
11:02:45 PM: npm WARN 23 more (@emotion/styled-base, netlify-cms-app, …)
11:02:45 PM: npm WARN 58 more (@emotion/react, @emotion/styled, @emotion/styled-base, …)
11:02:45 PM: npm WARN peer react@>=15.5 <=16.x from react-codemirror2@7.2.1
11:02:45 PM: npm WARN node_modules/netlify-cms-widget-code/node_modules/react-codemirror2
11:02:45 PM: npm WARN react-codemirror2@^7.0.0 from netlify-cms-widget-code@1.3.4
11:02:45 PM: npm WARN Conflicting peer dependency: react@16.14.0
11:02:46 PM: up to date, audited 669 packages in 2s
11:02:46 PM: 149 packages are looking for funding
11:02:46 PM: run npm fund
for details
11:02:46 PM: 6 high severity vulnerabilities
11:02:46 PM: To address issues that do not require attention, run:
11:02:46 PM: npm audit fix
11:02:46 PM: Some issues need review, and may require choosing
11:02:46 PM: a different dependency.
11:02:46 PM: Run npm audit
for details.
11:02:46 PM: npm packages installed
11:02:47 PM: Install dependencies script success
11:02:47 PM: Starting build script
11:02:47 PM: Detected 2 framework(s)
11:02:47 PM: hugo at version unknown
11:02:47 PM: zola at version unknown
11:02:47 PM: Section completed: initializing
11:02:49 PM:
11:02:49 PM: Netlify Build
11:02:49 PM: ────────────────────────────────────────────────────────────────
11:02:49 PM:
11:02:49 PM: ❯ Version
11:02:49 PM: @netlify/build 29.19.0
11:02:49 PM:
11:02:49 PM: ❯ Flags
11:02:49 PM: baseRelDir: true
11:02:49 PM: buildId: 64d871d66adfd70007ba42be
11:02:49 PM: deployId: 64d871d66adfd70007ba42c0
11:02:49 PM:
11:02:49 PM: ❯ Current directory
11:02:49 PM: /opt/build/repo
11:02:49 PM:
11:02:49 PM: ❯ Config file
11:02:49 PM: /opt/build/repo/netlify.toml
11:02:49 PM:
11:02:49 PM: ❯ Context
11:02:49 PM: production
11:02:49 PM:
11:02:49 PM: build.command from netlify.toml
11:02:49 PM:
11:02:49 PM: $ cd exampleSite && hugo --minify --gc --themesDir …/…
11:02:49 PM: Start building sites …
11:02:49 PM: hugo v0.109.0-47b12b83e636224e5e601813ff3e6790c191e371+extended linux/amd64 BuildDate=2022-12-23T10:38:11Z VendorInfo=gohugoio
11:02:54 PM: | EN
11:02:54 PM: -------------------±------
11:02:54 PM: Pages | 52
11:02:54 PM: Paginator pages | 2
11:02:54 PM: Non-page files | 0
11:02:54 PM: Static files | 5
11:02:54 PM: Processed images | 1008
11:02:54 PM: Aliases | 16
11:02:54 PM: Sitemaps | 1
11:02:54 PM: Cleaned | 0
11:02:54 PM: Total in 4947 ms
11:02:54 PM:
11:02:54 PM: (build.command completed in 4.9s)
11:02:54 PM:
11:02:54 PM: Deploy site
11:02:54 PM: ────────────────────────────────────────────────────────────────
11:02:54 PM:
11:02:54 PM: Starting to deploy site from ‘exampleSite/public’
11:02:54 PM: Calculating files to upload
11:02:54 PM: 34 new files to upload
11:02:54 PM: 0 new functions to upload
11:02:54 PM: Section completed: deploying
11:02:54 PM: Site deploy was successfully initiated
11:02:54 PM:
11:02:54 PM: (Deploy site completed in 497ms)
11:02:54 PM:
11:02:54 PM: Netlify Build Complete
11:02:54 PM:
11:02:54 PM: (Netlify Build completed in 5.5s)
11:02:55 PM: Caching artifacts
11:02:55 PM: Started saving node modules
11:02:55 PM: Finished saving node modules
11:02:55 PM: Started saving build plugins
11:02:55 PM: Finished saving build plugins
11:02:55 PM: Started saving corepack cache
11:02:55 PM: Finished saving corepack cache
11:02:55 PM: Started saving pip cache
11:02:55 PM: Finished saving pip cache
11:02:55 PM: Started saving emacs cask dependencies
11:02:55 PM: Finished saving emacs cask dependencies
11:02:55 PM: Started saving maven dependencies
11:02:55 PM: Finished saving maven dependencies
11:02:55 PM: Started saving boot dependencies
11:02:55 PM: Finished saving boot dependencies
11:02:55 PM: Started saving rust rustup cache
11:02:55 PM: Finished saving rust rustup cache
11:02:55 PM: Started saving go dependencies
11:02:55 PM: Finished saving go dependencies
11:02:55 PM: Build script success
11:02:55 PM: Section completed: building
11:02:56 PM: Uploading Cache of size 188.2MB
11:02:57 PM: Section completed: cleanup
11:02:57 PM: Finished processing build request in 29.246s
