When running the following serverless function in production…
const fetch = require('node-fetch')
const API_ENDPOINT = 'https://api.themoviedb.org/3/discover/movie?'
const API_KEY = process.env.MOVIEDB_API_KEY
exports.handler = async (event, context) => {
try {
console.log(response)
const response = await fetch(API_ENDPOINT + API_KEY)
const data = await response.json()
return { statusCode: 200, body: JSON.stringify({ data }) }
} catch (error) {
console.log(error)
return {
statusCode: 500,
body: JSON.stringify({ error: 'Failed fetching data' }),
… I get an error message in the Netlify function log:
4:38:08 PM: 2022-01-14T15:38:08.520Z undefined ERROR Uncaught Exception {"errorType":"Error","errorMessage":"Must use import to load ES Module: /var/task/node_modules/node-fetch/src/index.js\nrequire() of ES modules is not supported.\nrequire() of /var/task/node_modules/node-fetch/src/index.js from /var/task/.netlify/functions/api.js is an ES module file as it is a .js file whose nearest parent package.json contains \"type\": \"module\" which defines all .js files in that package scope as ES modules.\nInstead rename index.js to end in .cjs, change the requiring code to use import(), or remove \"type\": \"module\" from /var/task/node_modules/node-fetch/package.json.\n","code":"ERR_REQUIRE_ESM","stack":["Error [ERR_REQUIRE_ESM]: Must use import to load ES Module: /var/task/node_modules/node-fetch/src/index.js","require() of ES modules is not supported.","require() of /var/task/node_modules/node-fetch/src/index.js from /var/task/.netlify/functions/api.js is an ES module file as it is a .js file whose nearest parent package.json contains \"type\": \"module\" which defines all .js files in that package scope as ES modules.","Instead rename index.js to end in .cjs, change the requiring code to use import(), or remove \"type\": \"module\" from /var/task/node_modules/node-fetch/package.json.",""," at new NodeError (internal/errors.js:322:7)"," at Object.Module._extensions..js (internal/modules/cjs/loader.js:1102:13)"," at Module.load (internal/modules/cjs/loader.js:950:32)"," at Function.Module._load (internal/modules/cjs/loader.js:790:12)"," at Module.require (internal/modules/cjs/loader.js:974:19)"," at require (internal/modules/cjs/helpers.js:93:18)"," at Object.<anonymous> (/var/task/.netlify/functions/api.js:1:15)"," at Module._compile (internal/modules/cjs/loader.js:1085:14)"," at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)"," at Module.load (internal/modules/cjs/loader.js:950:32)"]}
There is no “require” statement in the node-fetch package index.js file.
So I tried changing to an “import” statement in the serverless function file. Got this error message in the function log in the Netlify admin UI:
4:52:36 PM: 2022-01-14T15:52:36.655Z undefined ERROR Uncaught Exception {"errorType":"Runtime.UserCodeSyntaxError","errorMessage":"SyntaxError: Cannot use import statement outside a module","stack":["Runtime.UserCodeSyntaxError: SyntaxError: Cannot use import statement outside a module"," at _loadUserApp (/var/runtime/UserFunction.js:200:13)"," at Object.module.exports.load (/var/runtime/UserFunction.js:242:17)"," at Object.<anonymous> (/var/runtime/index.js:43:30)"," at Module._compile (internal/modules/cjs/loader.js:1085:14)"," at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)"," at Module.load (internal/modules/cjs/loader.js:950:32)"," at Function.Module._load (internal/modules/cjs/loader.js:790:12)"," at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:76:12)"," at internal/main/run_main_module.js:17:47"]}
So my question is: How can I import/require fetch from node-fetch without errors?
Thanks,
/David
