System error on deploy
My site was deploying for a while but recently fails every time even after clearing cache and retrying.
It has a bunch of quite large files - although nothing over 100mb.
I appreciate that others were having the same issue a few months ago but, unlike then, there are no indications that netlify servers are having issues.
12:03:05 PM: Build ready to start
12:03:06 PM: build-image version: 2dbd444fcdce00cf06325060a8238d5ae3e86774
12:03:06 PM: build-image tag: v3.3.7
12:03:06 PM: buildbot version: 134ec431c6a3ff76e87cc4dc34007fe13842272f
12:03:07 PM: Fetching cached dependencies
12:03:07 PM: Starting to download cache of 254.9KB
12:03:07 PM: Finished downloading cache in 57.554366ms
12:03:07 PM: Starting to extract cache
12:03:07 PM: Failed to fetch cache, continuing with build
12:03:07 PM: Starting to prepare the repo for build
12:03:07 PM: No cached dependencies found. Cloning fresh repo
12:03:07 PM: git clone https://github.com/entozoon/gamewave-archive
12:07:12 PM: Preparing Git Reference refs/heads/master
12:07:13 PM: No build command found, continuing to publishing
12:07:13 PM: Starting to deploy site from '/'
12:07:40 PM: Creating deploy tree
12:07:40 PM: Creating deploy upload records
12:07:40 PM: 31 new files to upload
12:07:40 PM: 0 new functions to upload
12:24:33 PM: System Error
Hi there!
Cheers for reaching out. You’re right, this is a slightly different System Error issue however it’s likely due to the large file sizes.
Point 4 in this useful guide might steer you in the right direction. We’ve got a couple of means of handling large files.
