My site is antigamestudiesgamestudiesgame.netlify.app, with the repo currently available here.
When building on Netlify, the build fails to resolve imports using rollup:
When building locally with a fresh clone of the repo, & same node version, it succeeds with no issues.
The full build log:
4:11:52 AM: Build ready to start
4:11:53 AM: build-image version: d2c6dbeac570350a387d832f64bc980dc964ad65 (focal)
4:11:53 AM: build-image tag: v4.8.0
4:11:53 AM: buildbot version: 29e546ddee264a16af472b38ccba15b350150213
4:11:53 AM: Fetching cached dependencies
4:11:53 AM: Failed to fetch cache, continuing with build
4:11:53 AM: Starting to prepare the repo for build
4:11:54 AM: No cached dependencies found. Cloning fresh repo
4:11:54 AM: git clone https://github.com/Sxxov/aggg
4:11:54 AM: Preparing Git Reference refs/heads/master
4:11:55 AM: Parsing package.json dependencies
4:11:55 AM: Different build dir detected, going to use the one specified in the Netlify configuration file: '' versus '.' in the Netlify UI
4:11:56 AM: Starting build script
4:11:56 AM: Installing dependencies
4:11:56 AM: Python version set to 2.7
4:11:56 AM: Downloading and installing node v16.15.0...
4:11:56 AM: Downloading https://nodejs.org/dist/v16.15.0/node-v16.15.0-linux-x64.tar.xz...
4:11:57 AM: Computing checksum with sha256sum
4:11:57 AM: Checksums matched!
4:11:59 AM: Now using node v16.15.0 (npm v8.5.5)
4:11:59 AM: Started restoring cached build plugins
4:11:59 AM: Finished restoring cached build plugins
4:11:59 AM: Attempting ruby version 2.7.2, read from environment
4:12:00 AM: Using ruby version 2.7.2
4:12:00 AM: Using PHP version 8.0
4:12:01 AM: No npm workspaces detected
4:12:01 AM: Started restoring cached node modules
4:12:01 AM: Finished restoring cached node modules
4:12:01 AM: Installing NPM modules using NPM version 8.5.5
4:12:02 AM: npm WARN EBADENGINE Unsupported engine {
4:12:02 AM: npm WARN EBADENGINE package: 'amqplib@0.5.2',
4:12:02 AM: npm WARN EBADENGINE required: { node: '>=0.8 <=9' },
4:12:02 AM: npm WARN EBADENGINE current: { node: 'v16.15.0', npm: '8.5.5' }
4:12:02 AM: npm WARN EBADENGINE }
4:12:07 AM: npm WARN deprecated source-map-url@0.4.1: See https://github.com/lydell/source-map-url#deprecated
4:12:07 AM: npm WARN deprecated urix@0.1.0: Please see https://github.com/lydell/urix#deprecated
4:12:07 AM: npm WARN deprecated resolve-url@0.2.1: https://github.com/lydell/resolve-url#deprecated
4:12:07 AM: npm WARN deprecated source-map-resolve@0.5.3: See https://github.com/lydell/source-map-resolve#deprecated
4:12:09 AM: npm WARN deprecated uuid@3.3.2: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
4:12:10 AM: npm WARN deprecated querystring@0.2.0: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
4:12:11 AM: npm WARN deprecated extract-text-webpack-plugin@3.0.2: Deprecated. Please use https://github.com/webpack-contrib/mini-css-extract-plugin
4:12:13 AM: npm WARN deprecated chokidar@2.1.8: Chokidar 2 does not receive security updates since 2019. Upgrade to chokidar 3 with 15x fewer dependencies
4:12:17 AM: npm WARN deprecated core-js@2.6.12: core-js@<3.4 is no longer maintained and not recommended for usage due to the number of issues. Because of the V8 engine whims, feature detection in old core-js versions could cause a slowdown up to 100x even if nothing is polyfilled. Please, upgrade your dependencies to the actual version of core-js.
4:12:29 AM: > aggg-client@0.0.0 postinstall
4:12:29 AM: > patch-package
4:12:29 AM: patch-package 6.4.7
4:12:29 AM: Applying patches...
4:12:29 AM: @types/javascript-astar@0.0.31 ✔
4:12:29 AM: javascript-astar@0.4.1 ✔
4:12:29 AM: kursor@0.1.6 ✔
4:12:29 AM: lottie-web@5.9.1 ✔
4:12:29 AM: svelte@3.47.0 ✔
4:12:29 AM: > aggg-client@0.0.0 prepare
4:12:29 AM: > ts-patch install -s
4:12:30 AM: added 1047 packages, and audited 1048 packages in 29s
4:12:30 AM: 118 packages are looking for funding
4:12:30 AM: run `npm fund` for details
4:12:30 AM: 28 vulnerabilities (10 moderate, 15 high, 3 critical)
4:12:30 AM: To address issues that do not require attention, run:
4:12:30 AM: npm audit fix
4:12:30 AM: To address all issues possible (including breaking changes), run:
4:12:30 AM: npm audit fix --force
4:12:30 AM: Some issues need review, and may require choosing
4:12:30 AM: a different dependency.
4:12:30 AM: Run `npm audit` for details.
4:12:30 AM: NPM modules installed
4:12:30 AM: Started restoring cached go cache
4:12:30 AM: Finished restoring cached go cache
4:12:30 AM: go version go1.16.5 linux/amd64
4:12:30 AM: Installing missing commands
4:12:30 AM: Verify run directory
4:12:32 AM:
4:12:32 AM: ────────────────────────────────────────────────────────────────
4:12:32 AM: Netlify Build
4:12:32 AM:
4:12:32 AM: ❯ Version
4:12:32 AM: @netlify/build 27.1.1
4:12:32 AM:
4:12:32 AM: ❯ Flags
4:12:32 AM: baseRelDir: true
4:12:32 AM: buildId: 62782408858f79000974795f
4:12:32 AM: deployId: 62782408858f790009747961
4:12:32 AM:
4:12:32 AM: ❯ Current directory
4:12:32 AM: /opt/build/repo
4:12:32 AM:
4:12:32 AM: ❯ Config file
4:12:32 AM: /opt/build/repo/netlify.toml
4:12:32 AM:
4:12:32 AM: ❯ Context
4:12:32 AM: production
4:12:32 AM:
4:12:32 AM: 1. build.command from netlify.toml
4:12:32 AM:
4:12:32 AM: $ npm run build
4:12:32 AM: > aggg-client@0.0.0 build
4:12:32 AM: > svelte-kit build
4:12:32 AM: vite v2.9.8 building for production...
4:12:32 AM: transforming...
4:12:35 AM: ✓ 88 modules transformed.
4:12:35 AM: Could not resolve '../core/tailwinder/Tailwinder.js' from src/routes/__layout.svelte
4:12:35 AM: > Could not resolve '../core/tailwinder/Tailwinder.js' from src/routes/__layout.svelte
4:12:35 AM: at error (/opt/build/repo/node_modules/rollup/dist/shared/rollup.js:198:30)
4:12:35 AM: at ModuleLoader.handleResolveId (/opt/build/repo/node_modules/rollup/dist/shared/rollup.js:22417:24)
4:12:35 AM: at /opt/build/repo/node_modules/rollup/dist/shared/rollup.js:22380:26
4:12:35 AM:
4:12:35 AM: ────────────────────────────────────────────────────────────────
4:12:35 AM: "build.command" failed
4:12:35 AM:
4:12:35 AM: Error message
4:12:35 AM: Command failed with exit code 1: npm run build (https://ntl.fyi/exit-code-1)
4:12:35 AM:
4:12:35 AM: Error location
4:12:35 AM: In build.command from netlify.toml:
4:12:35 AM: npm run build
4:12:35 AM:
4:12:35 AM: Resolved config
4:12:35 AM: build:
4:12:35 AM: base: /opt/build/repo
4:12:35 AM: command: npm run build
4:12:35 AM: commandOrigin: config
4:12:35 AM: publish: /opt/build/repo/build
4:12:35 AM: publishOrigin: config
4:12:36 AM: Caching artifacts
4:12:36 AM: Started saving node modules
4:12:36 AM: Finished saving node modules
4:12:36 AM: Started saving build plugins
4:12:36 AM: Finished saving build plugins
4:12:36 AM: Started saving pip cache
4:12:36 AM: Finished saving pip cache
4:12:36 AM: Started saving emacs cask dependencies
4:12:36 AM: Finished saving emacs cask dependencies
4:12:36 AM: Started saving maven dependencies
4:12:36 AM: Finished saving maven dependencies
4:12:36 AM: Started saving boot dependencies
4:12:36 AM: Finished saving boot dependencies
4:12:36 AM: Started saving rust rustup cache
4:12:36 AM: Finished saving rust rustup cache
4:12:36 AM: Started saving go dependencies
4:12:36 AM: Finished saving go dependencies
4:12:37 AM: Build failed due to a user error: Build script returned non-zero exit code: 2
4:12:37 AM: Creating deploy upload records
4:12:37 AM: Failing build: Failed to build site
4:12:37 AM: Failed during stage 'building site': Build script returned non-zero exit code: 2 (https://ntl.fyi/exit-code-2)
4:12:38 AM: Finished processing build request in 44.23584375s
